Dust Collection - Tools & Equipment - Contractor Talk
Dust Collection
Old 04-07-2015, 10:26 AM   #1
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 352
Dust Collection
Trying to get a little bit cleaner with my dust collection for woodworking and also on the jobsite. I don't have a real dust collector but do have a ridgid shop vac and recently bought a laguna cyclone dust collector. So right now I can hook my shop vac up to the cyclone. But need to get another hose to go from cyclone to tool. I have about 6 shop vacs but some use a smaller hose and my other big 2" vac has a weird hose that doesn't work. That part I can handle, either just get another shop vac hose or have read a pool cleaning hose works good.
But the problem I have is that I have a 6" jointer and a 15" planer that have a 4" dust collector outlet. I bought one of these 4" to 2" adapters, http://www.amazon.com/Woodstock-W104...lector+adapter. The 4" side is the same diameter as the outlets on my machines. For now I used a fernco plumbing fitting to hook it onto the machine. But there has to be a better way that I don't know about. I believe the outlets on the machines and the adapter I bought are meant to go inside actual dust collection hose. But I don't have a dedicated dust collector and also don't have my machines in dedicated spots. They are on wheels and get rolled out when needed, shop isn't big enough for a full wood working setup.
So I guess my questions are what is the best way to adapt my 4" dust outlets on my machines to my shop vac/cyclone setup? And second what is a good second hose to get to use on the pick up side of my cyclone dust collector? I will use this hose to go to the table saw, jointer, planer when at the shop but also will be using it on job sites for things like grinding floors and other stuff. So thinking a longer 20ft hose would be nice.
platinumLLC is offline
Old 04-07-2015, 11:46 AM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,799
Re: Dust Collection
Cut a hole in a block of wood that fits the vacuum hose. Screw the pc of wood onto the output chute of the jointer. Tada.
Most woodworking machinery needs a lot of CFM to get the chips extracted properly. A vacuum isn't it. You'll need a dust collector eventually.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
The Following 2 Users Say Thank You to Leo G For This Useful Post:
pinwheel (04-07-2015), PrestigeR&D (04-12-2015)
Old 04-07-2015, 12:43 PM   #3
improving homes
Rewards Points: 352
Re: Dust Collection
I know a dust collector is the right tool for the job but I really don't do a lot of fine wood working. Little projects here and there and the occasional "custom" stuff for jobs that need a quick run through the jointer or planer. And I really don't have room for a dust collector right now. The shop vac and cyclone collector do a pretty decent job with the planer and jointer, not ideal like a dust collector but not completely useless.
Old 04-07-2015, 01:30 PM   #4
Railman's Avatar
Trade: Railing
Rewards Points: 1,161
Re: Dust Collection
I'm not sure exactly what you trying to adapt, but One of these should work:
http://www.pennstateind.com/store/abs-adapters.html
They have a nice collection of dust collectors and accesories at very reasonable prices.
Railman is offline
Old 04-12-2015, 07:58 AM   #5
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Re: Dust Collection
I think you would be better off with a DC system. Going from 4" ( as is engineered into your machinery) is there for a reason. As Leo pointed out- CFPM is what you have to pay attention to. A shop vac is no where near the proper CFPM for your machines. Just get a DC system and some flex hose so you can hook it up anywhere in your shop. The dust collection machines that Leo posted are on a mobile base so you can move it around. You will be a lot happier with a DC system.
Jmpo,
B,
PrestigeR&D is offline
Old 04-12-2015, 11:09 AM   #6
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Re: Dust Collection
When I was going through this dilemma I ended up with a Delta DC from Lowes that I paid about $250 for, plus some of the Rockler Dust Right hose and fittings. No comparison to the Shop Vac. You need large volumes of air, not air speed to move the dust and chips from jointers and planers.
If you search "portable dust collector" on Amazon you'll find quite a few options that aren't too expensive, and are quite compact and transportable.
Rustbucket is offline
Bosch miter saw? mnjconstruction Tools & Equipment 55 04-10-2015 09:04 AM
Dust Collection Systems Barbary Coast Tools & Equipment 25 11-15-2012 05:54 PM
Dust Collection question j_sims Tools & Equipment 11 09-09-2011 07:55 AM
Dust Collection Tech Dawg Finish Carpentry 4 04-17-2011 09:25 AM
Anyone use this?: 5 Gal Bucket Dust Separator for Shop Vac Based Dust Collection Remodelor Tools & Equipment 7 12-07-2010 10:06 PM
