-   Tools & Equipment (https://www.contractortalk.com/f40/)
-   -   Dust collection (https://www.contractortalk.com/f40/dust-collection-186641/)
platinumLLC 04-07-2015 10:26 AM
Dust collection
4 Attachment(s)
Trying to get a little bit cleaner with my dust collection for woodworking and also on the jobsite. I don't have a real dust collector but do have a ridgid shop vac and recently bought a laguna cyclone dust collector. So right now I can hook my shop vac up to the cyclone. But need to get another hose to go from cyclone to tool. I have about 6 shop vacs but some use a smaller hose and my other big 2" vac has a weird hose that doesn't work. That part I can handle, either just get another shop vac hose or have read a pool cleaning hose works good.
But the problem I have is that I have a 6" jointer and a 15" planer that have a 4" dust collector outlet. I bought one of these 4" to 2" adapters, http://www.amazon.com/Woodstock-W104...lector+adapter. The 4" side is the same diameter as the outlets on my machines. For now I used a fernco plumbing fitting to hook it onto the machine. But there has to be a better way that I don't know about. I believe the outlets on the machines and the adapter I bought are meant to go inside actual dust collection hose. But I don't have a dedicated dust collector and also don't have my machines in dedicated spots. They are on wheels and get rolled out when needed, shop isn't big enough for a full wood working setup.
So I guess my questions are what is the best way to adapt my 4" dust outlets on my machines to my shop vac/cyclone setup? And second what is a good second hose to get to use on the pick up side of my cyclone dust collector? I will use this hose to go to the table saw, jointer, planer when at the shop but also will be using it on job sites for things like grinding floors and other stuff. So thinking a longer 20ft hose would be nice.
Leo G 04-07-2015 11:46 AM
Cut a hole in a block of wood that fits the vacuum hose. Screw the pc of wood onto the output chute of the jointer. Tada.
Most woodworking machinery needs a lot of CFM to get the chips extracted properly. A vacuum isn't it. You'll need a dust collector eventually.
http://g-ecx.images-amazon.com/image...CK-main-sm.jpg
platinumLLC 04-07-2015 12:43 PM
4 Attachment(s)
I know a dust collector is the right tool for the job but I really don't do a lot of fine wood working. Little projects here and there and the occasional "custom" stuff for jobs that need a quick run through the jointer or planer. And I really don't have room for a dust collector right now. The shop vac and cyclone collector do a pretty decent job with the planer and jointer, not ideal like a dust collector but not completely useless.
Railman 04-07-2015 01:30 PM
I'm not sure exactly what you trying to adapt, but One of these should work:
http://www.pennstateind.com/store/abs-adapters.html
They have a nice collection of dust collectors and accesories at very reasonable prices.
PrestigeR&D 04-12-2015 07:58 AM
I think you would be better off with a DC system. Going from 4" ( as is engineered into your machinery) is there for a reason. As Leo pointed out- CFPM is what you have to pay attention to. A shop vac is no where near the proper CFPM for your machines. Just get a DC system and some flex hose so you can hook it up anywhere in your shop. The dust collection machines that Leo posted are on a mobile base so you can move it around. You will be a lot happier with a DC system.
Jmpo,;)
Rustbucket 04-12-2015 11:09 AM
Dust Collection
When I was going through this dilemma I ended up with a Delta DC from Lowes that I paid about $250 for, plus some of the Rockler Dust Right hose and fittings. No comparison to the Shop Vac. You need large volumes of air, not air speed to move the dust and chips from jointers and planers.
If you search "portable dust collector" on Amazon you'll find quite a few options that aren't too expensive, and are quite compact and transportable.
