Dump Trailer Opinions And Options! - Tools & Equipment - Contractor Talk
Old 03-19-2019, 06:06 AM   #1
SearchforSignal's Avatar
Trade: Low voltage
Rewards Points: 744
Last year I got myself an enclosed trailer for my business, this year I will be investing in a dump trailer.
There are a lot of brands out there but I'm pretty sure I will be going with Lamar.
PJ and a few of the larger manufacturers just have a lot of people who complain about their quality it seams.
Here is the dump I am looking at ordering.
Low profile dump. 14ft or 16ft ?
7k Torsion axles
Tarp Kit
7 gauge single piece floor
Led package
Spreader gate w/slide in ramps
8" I-Beam frame
8" I-Beam Tongue
12" on center crossmembers
235/85 R16 14ply Tires with spare and mount
10k drop leg jack
24" Solid side extensions (debris removale)
8 D Rings welded on side
Power up/down with voltage meter
Wireless remote...? Not sure if I need it.
Anything anyone else would recommend or do without? These are expensive and I only want to buy it once.
Picture is just for reference
SearchforSignal is offline
The Following User Says Thank You to SearchforSignal For This Useful Post:
Dockguy (06-20-2019)
Old 03-19-2019, 06:10 AM   #2
TheGrizz's Avatar
Trade: Remodeling and handyman
Rewards Points: 985
Re: Dump Trailer Opinions And Options!
Good call on the low profile. I donít have to deal with it regularly, as Iím more of a finisher, not a demo guy, but our dump trailer is nearly 7 feet from ground to top. I canít imagine having to demo stuff into it.
TheGrizz is offline
Old 03-19-2019, 07:05 AM   #3
tgeb's Avatar
Rewards Points: 1,288
Those specs look good to me.
As far as the wireless remote, it could come in handy if you ever intend on spreading stone. You can raise the bed while moving the truck.
www.gebcon.com
tgeb is offline
Old 03-19-2019, 07:33 AM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Iíd go wireless remote. The first time you run over your remote wires and pull them off the pump is one too many times. And believe me, it will be the most inopportune moment.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
hammer7896 (03-19-2019)
Old 03-19-2019, 08:12 AM   #5
diplomat
Golden view's Avatar
Rewards Points: 1,550
Everyone's business is different, but every way I run the numbers, a dump trailer isn't worth it for me. When I had $5k in dump fees a year and now that I have $20k.
Golden view is offline
Old 03-19-2019, 08:33 AM   #6
Lettusbee's Avatar
Rewards Points: 1,862
I've had my Travalong Dump trailer for 10 years with no complaints. I sometimes wish I had gone with wireless remote. Mine is 7x14 with 21" sides, and the low profile is definitely the way to go for residential demo. Can load it with shorter reach equipment when needed, and if you need more height, easy to do with stake pockets.
One of the biggest complaints about cheaper trailers, is the finish. My 10 y.o. trailer has a better finish still, than most 5 year PJs. Buy it once, don't let the concrete guy use it, and it should last forever.
That trailer in the picture looks indestructible.
Lettusbee is offline
Old 03-19-2019, 12:09 PM   #7
Trade: Low voltage
Rewards Points: 744
Well I will be doing wireless remote.
Yes that one pictured is exactly what I will be getting unless I go with a 16ft. Also thinking of getting a longer tongue. Larger toolbox ect.
Old 03-19-2019, 01:40 PM   #8
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 492
That looks like a great trailer, and definitely better built than my Brimar.
for me I like the deck over with fold-down sides, I can have things loaded from the side... my trailer has held up pretty well, but I won't let just anyone use it, and I don't haul much rock or fill with it
Jonbuild is online now
Old 03-19-2019, 07:07 PM   #9
Donohue Const's Avatar
Rewards Points: 1,726
not sure if I would go with torsion axles if I was getting a dump trailer
I would have to do a lot of research first, my gn tool trailer has torsion axles.
seems like I get ta lot of trailer bounce
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 03-19-2019, 07:35 PM   #10
Trade: Low voltage
Rewards Points: 744
Yeah I'm still am thinking things over. I just want the trailer over built so I never have to buy another. These things are expensive.
Old 03-19-2019, 07:45 PM   #11
TheGrizz's Avatar
Rewards Points: 985
Iím almost afraid to tell you this, but youíll probably buy another one. No matter how much you think about it now, and how much you think youíve got everything nailed down, once youíre actually using it, youíll probably find something you want to change. The GC I work for has had I think 4 dump trailers in the 6 years Iíve worked for him. His first one was small, and the whole box sat above the wheels, so it was crazy tall. The next one was shorter, wider, and longer, and the box sat down just above the axels. Iím not sure why that one went away, but his current one is almost a mini roll off, permanently mounted to a trailer. You might also look into getting a roll-off trailer. From what Iíve seen, you could use them just like a dump trailer, but you can also drop the bed off without the transport mechanism, which would make it harder to steal.
TheGrizz is offline
Old 03-19-2019, 07:45 PM   #12
I would go 16'
better to use if your hauling any lumber
Ryan
Old 03-19-2019, 11:34 PM   #13
Juan80's Avatar
Trade: General contractor
I have a 12í Imago , great trailer.
Never loan it out , it will last longer.
One bit of advice , get expanded metal on the ramps , real easy to run a wheelbarrow up.
Good looking trailer you are thinking about.
Charlie
Sent from my iPad using Tapatalk Pro
Juan80 is offline
Old 03-20-2019, 12:27 AM   #14
Stunt Carpenter's Avatar
Rewards Points: 3,146
I have a 12 ft dump that I bought of a farmer. New pair of axles and spring and it hauls everything I ask it to.
Agree on the low sides. If you canít load bins over the side itís going to be a pain for residential stuff
https://builddaley.com/
Stunt Carpenter is offline
Old 03-20-2019, 07:48 AM   #15
builditguy's Avatar
Rewards Points: 2,162
We had a 1 ton dump truck. Sold it last year and bought a dump trailer. I like the idea of a trailer better, but the truck was alot handier.
With the truck, it would dump alot easier and quicker. Back up, push the button, pull the tailgate, dump and drive away. As long as the tarp wasn't up. Never had a problem.
The reason we got rid of it, was because it wasn't real handy for the in between stuff. One person had to go get it. When they came back, their work truck was at the shop. If they needed any tools, they didn't have them. With the trailer, they can pick it up and still have all of their stuff. I don't like amount of room it takes to manuver, but it's ok. The insurance is cheaper and it doesn't really break down. Charge a battery, buy a new one, once in a while and good to go. Our truck never broke down, but there is more maintenance with vehicles.
I have a DooLittle. Probably not available in your area. The one you pictured looks great. I wouldn't have any reservations.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
SearchforSignal (03-20-2019)
Old 03-20-2019, 09:10 AM   #16
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,892
I have a Lamar trailer as well and in my opinion the dump trailer was a very good investment. Mine is only a 5x10 but it has a 10k Gross. i use it to haul primarily masonry and concrete debris and when I dump it is usually right at 8000 pounds of payload putting it at 10k gross
Dump trailers are very easy to overload
Your options sound good but I wouldnít hesitate to get the wireless remote because you will have to pull forward to get all the debris out when you dump it so it will be nice to be able to push the up button while sitting in your truck and just pull forward.
Currently I have to open the barn doors, get in the truck and back up to the pile, get out to push the up button then get in the truck pull forward, get out and push the down button and to close the gates
The wireless remote would save one time from getting in n out
Windycity is offline
Old 03-20-2019, 06:16 PM   #17
the one in the pic has a scissor hoist on it
that's what mine has, I've been told it's better then the kind with two rams on it for dumping power
Ryan
The Following User Says Thank You to Donohue Const For This Useful Post:
tgeb (03-21-2019)
Old 03-20-2019, 06:19 PM   #18
Trade: Low voltage
Rewards Points: 744
Charlie
Will definitely get expanded ramps. Thanks
Old 03-20-2019, 06:20 PM   #19
Trade: Low voltage
Rewards Points: 744
Yes I want stability when the load is high as well.
Old 03-20-2019, 06:23 PM   #20
Trade: Low voltage
Rewards Points: 744
Yes that us a mandatory option now. Thanks.
