Dump Trailer - Gooseneck Vs Bumper Pull - Tools & Equipment - Contractor Talk
Old Today, 10:20 AM   #1
Kasay's Avatar
Trade: Residential/Commercial General Contractor
Rewards Points: 4
Looking at moving up from my 6x10 dump trailer to a larger one. Preferably 14-16’. Can’t decide between a gooseneck or bumper pull and potentially adding drop down sides so it can be used to haul material as well.
Kasay is online now
Old Today, 05:17 PM   #2
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 304
Re: Dump Trailer - Gooseneck Vs Bumper Pull
In terms of capacity and stability you're getting a lot more with a fifth-wheel. You're distributing the tongue weight directly over your trucks rear axle and in turn a percentage to the fronts. With a ball hitch its all on the rear wheels and lifts the front end which isn't ideal as you start hauling really heavy loads.
The downside to fifth-wheels is you have a giant heavy steel hitch taking up 75% of the usable space in the bed of your truck. If you don't use the bed much that's not an issue, if you do it can be a PITA to work around. They're not too terribly difficult to remove but they are pretty heavy if you're trying to do it solo.
TRThomas is online now
Old Today, 06:05 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,264
Probably why he said gooseneck not 5th wheel.
Inner10 is online now
Old Today, 06:26 PM   #4
TRThomas's Avatar
Rewards Points: 304
Well i feel dumb. Disregard the part about taking up the bed space when not towing and removale being a PITA. Everything else still applies.
Old Today, 06:39 PM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 9,594
If I was getting a 16 goose dump it would have tandem duals. You will overload that thing with 7-8k axles every time you haul fill or stone. Demo probably not.
Morning Wood is online now
Old Today, 06:41 PM   #6
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 356
That's not true about a goose neck ball taking up all the space in the bed, my last one was just a ball that stuck up from the bed and when not in use it could be turned over and set down so the bed was empty you could not even tell I had a goose neck hitch.
Still "Shakin" the tree boss
sunkist is online now
Dump Trailer Questions BOBONTUESDAY Vehicles 21 02-25-2017 08:34 PM
Dump trailer rolling tarp installation instructions? Roofcheck Tools & Equipment 5 08-11-2013 07:11 PM
low boy trailer kauai88 Sandblasting 24 05-08-2013 07:54 AM
about dump trailer hrufero Tools & Equipment 11 12-13-2011 09:41 AM
Is a Carryon dump trailer decent? ranagent Vehicles 7 01-27-2011 07:16 AM
