Drilling 1/8" Steel - Tools & Equipment - Contractor Talk
Drilling 1/8" Steel
Old 02-09-2014, 03:56 PM   #1
dkillianjr's Avatar
Rewards Points: 2,464
Drilling 1/8" Steel
I wasn't sure where to put this. Ok I am adding two small led work lights in the bumper on my utility body. The bumper is 1/8" powder coated steel.
Long story short, I added some to the body, but the bumper has clipped corners. So these lights will shine out to the sides a lil for backing trailers at night. I don't want to put them under the bumper because its pretty low.
I have to drill two 2 1/8" holes. Do you guys think a high quality hole saw and cutting oil will handle this? I would even buy one hole saw for each hole.
I would hate to start drilling and have the hole saws not work
Thanks, Dave
dkillianjr is offline
Old 02-09-2014, 04:01 PM   #2
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Drilling 1/8" Steel
Thy these
http://www.emisupply.com/catalog/mor...FcpZ7AodslYAPQ
jlsconstruction is offline
Old 02-09-2014, 04:08 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,020
Yeah, a good hole saw will do it. But pack a lunch if you're not using a drill press.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
jlsconstruction (02-09-2014), woodchuck2 (02-11-2014)
Old 02-09-2014, 04:11 PM   #4
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 2,670
I watched my plumber drill a 4 1/2" hole in a 3/16" steel panel on a grease trap the other day. Took him 2 $40 Lenox hole saws, but he went slow and kept spraying water on it, and he got it done.
Bearded Wonder is offline
Old 02-09-2014, 04:16 PM   #5
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Dave, I have, and, only buy the Lenox bits! worth the price ya pay!
If it is not hard steel, one bit should be fine! Go low pressure and slow. Get 2, save the trip to HD for the other! lol IF ya need a gorilla to help out, My son is available!! LOL ya know who he is!!!! Chad. ask dad!
Dave in Pa is offline
Old 02-09-2014, 04:21 PM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Hole saw will do it no prob.
Inner10 is offline
Old 02-09-2014, 05:03 PM   #7
dkillianjr's Avatar
Thanks for the input guys, that's good news!
I learned that a year ago drilling 3/4" holes in a 3/8" steel flitch plate
Needless to say after about one hole I went and rented one of those electromagnetic drill presses
Old 02-09-2014, 05:07 PM   #8
dkillianjr's Avatar
Hey Dave,
Yup the lenox is usually all I get. Yup you know it! I was deffinetly gonna get two, I always can use the 2 1/8 for door locks.
I will stop in the fire hall and put him to work lol!!
I seen one of you guys vans the other day, I think it was on babcock blvd. I was going to try and get next to it, but there was too much traffic lol.
Old 02-09-2014, 05:54 PM   #9
SouthonBeach's Avatar
Rewards Points: 1,167
Good Lenox hole saw and something to cool and lubricate. Heat is going to be your enemy drilling it.
SouthonBeach is offline
Old 02-10-2014, 09:05 AM   #10
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
I find that a hole cutter usually works much better than a hole saw for 1/8 steel, especially if you're using it with a portable drill. They cut cleaner and faster with less heat and run out than hole saws so your lights will fit in the holes better. Hougan is the brand I use, so they are what I would recommend.
Hole Cutter:
http://www.amazon.com/Hougen-14266-H...40963&sr=1-113
Arbor:
http://www.amazon.com/Hougen-14009-H...041137&sr=1-36
DuMass is offline
The Following User Says Thank You to DuMass For This Useful Post:
rustyjames (02-10-2014)
Old 02-10-2014, 09:20 AM   #11
rustyjames's Avatar
Rewards Points: 1,832
^^^^^^Thats the ticket, I've used their annular cutters in my mag drill and they cut steel like butter.
rustyjames is offline
Old 02-10-2014, 11:29 AM   #12
Railman's Avatar
Trade: Railing
Rewards Points: 1,189
Hole Cutter:
Arbor:
Wouldn't he better off with the carbide version for 1/8" steel?
http://www.ohiopowertool.com/p-459-h...ize-pilot.aspx
http://www.ohiopowertool.com/p-889-h...lect-size.aspx
The 2 1/8" HS version is $27 at above site, & the carbide is $54.
I've cut more than a few with a std carbide hole saw. You just need to use max 500 rpm, spray with WD40 now & then, & do a sloooow wobble so as to get enough pressure on the teeth to cut, instead of just dragging off fines. It's kinda similar to rocking a hand saw when you cut wood. The tooth pressure has to be right to dig in.
Joe
Railman is offline
Old 02-10-2014, 04:58 PM   #13
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
https://www.ohiopowertool.com/Shoppi...6cartrecid%3d0
Joe
Joe that link is just to your shopping cart.
basswood is offline
The Following User Says Thank You to basswood For This Useful Post:
Railman (02-10-2014)
Old 02-10-2014, 05:03 PM   #14
rustyjames's Avatar
I think the Hougen cutter in HSS will be fine, just keep the RPMs down, and use a cutting fluid.
Old 02-10-2014, 05:16 PM   #15
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Joe..... We filled it for you.... and confirmed sale..... but we did change the mail-to address.
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
The Following 3 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
dkillianjr (02-10-2014), Railman (02-10-2014), rex (02-10-2014)
Old 02-10-2014, 09:49 PM   #16
dkillianjr's Avatar
Thanks again guys I will check those cutters out. I have a couple other projects planned for my trailer, so it may be worth it.
Old 02-10-2014, 09:50 PM   #17
dkillianjr's Avatar
Lmao
Old 02-10-2014, 10:02 PM   #18
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,819
$28 for 2 lenox hole saws or $70 for the kit for the Hougen kit. Especially if you have the mandrel for the holesaw already. You can get the holesaw sharpened again for about $4-6 at your local sharpening place.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 02-10-2014, 10:04 PM   #19
Railman's Avatar
Trade: Railing
Your more than welcome to use my cart! Just YOUR card to check out, & have shipped to my shop. I'll hold your stuff for ya!
I figure if you have my credit card info, it woulda been used by now anyway.
I'm actually going to go right by that store tomorrow on a delivery & measure run in Columbus. I might have to stop in & look around.
Joe
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Old 02-10-2014, 11:22 PM   #20
dkillianjr's Avatar
Thanks leo, I didn't realize hole saws could be resharpened. I'm heading to pick up one of my saw blades from my sharpening guy this week, I'm gonna ask him about the holes saws while im there.
Railman, Just post you credit card info here so we can make sure we didn't use yours
13oz Estwing Ultralight Steel Hammer 2ndGen Tools & Equipment 11 02-16-2013 09:12 PM
Framing with steel article. Rich D. Decks & Fencing 6 02-02-2013 05:51 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
