Drill Bit Test. Under $40. - Tools & Equipment - Contractor Talk
Old 01-18-2020, 01:47 PM   #1
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,891
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
AustinDB (01-19-2020), Calidecks (01-18-2020), Inner10 (01-18-2020)
Old 01-19-2020, 09:36 AM   #2
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 28
Re: Drill Bit Test. Under $40.
Interesting test.....
Porterfarm is offline
Old 01-19-2020, 09:52 AM   #3
AustinDB's Avatar
Rewards Points: 1,430
not to sound repetitive, but interesting test.
I switched to the Milwaukee bits this year out of convenience so I can set doors with the 12v impact driver. Used a Bosch for drilling 3/8" angle on last years dock job and was happy with it's longevity.
AustinDB is online now
Old 01-19-2020, 10:07 AM   #4
LRG WoodCrafting
Leo G's Avatar
Probably best to just by 2 sets of the DeWalts.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-19-2020, 10:52 AM   #5
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I’ve had good luck with the DeWalt bits.
EricBrancard is offline
Old 01-19-2020, 01:26 PM   #6
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
I've been buying the DeWalt titanium bits for ever, but I buy Bosch masonry bits
For me the amount of metal I drill is small, most of my stuff is wood and masonry..
Watching the video shows why drill speed and feed are so important of course I can't recall the last time i used a drill press.
When drilling and grinding metal I use Cut-Eze comes in a tube like grease and is like a hard wax
Still "Shakin" the tree boss
sunkist is offline
Old 01-19-2020, 04:44 PM   #7
LRG WoodCrafting
Leo G's Avatar
When I was making the embossing machine I was drilling metal. The 1st round of drilling was for the shaft to go though and the two holes for the bolts that would hold on the pillow block bearings. I used a 1 1/2" Milwaukee hole saw for the shaft hole and Ryobi bits for the 3/8" holes, the index was given to me for Christmas a few years back. Drilled in this steel OK.
Then the 2nd round of drilling got more challenging. After the pcs of steel were welded together. I wanted to drill three 3/16" holes in the base that I would use to secure the machine to a table. I figured I'd just go for it. Got about half way through and she didn't go no more. I got out my Triumph bits and started with the 1/8". That went through pretty easy. Then bumped up to the next bit and had trouble. Went to the 3/16 and still couldn't get through. Figured the welding hardened the steel.
Borrowed an Acetylene torch and made the metal around the holes I was drilling low level red hot. Let it cool and drilled it like it was a hot knife through butter. You know when you are drilling and you see sparks you're in trouble.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
