Dewalt Chop Saw Stand Brackets - Tools & Equipment - Contractor Talk
Old 03-26-2019, 08:08 AM   #1
DN BROWN's Avatar
Trade: Remodeling/Home Improvement
Rewards Points: 2
The lever in the locking system of the bracket on the Dewalt Chop Saw Stand fail over time.
Is there a fix for this problem?
DN BROWN is offline
Old 03-26-2019, 08:27 AM   #2
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 228
Re: Dewalt Chop Saw Stand Brackets
Buy a new bracket.
How long are they lasting for you?
I just replaced the ones on both my saws, I got almost 3 years
mrcat is offline
Old 03-27-2019, 08:29 AM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 940
If you are talking about the little plastic thig-a-ma-jig that prevents you from depressing the release lever, I taped it down with electrical tape .
Iím sure there is a better fix but, this has worked for a couple of years for me
I have some older ones of a slightly different design, never had a problem with those
Idothat is online now
Old 03-27-2019, 08:05 PM   #4
Mordekyle's Avatar
Rewards Points: 5,614
I usually cut off the spring loaded lever that pops up and tends to bind.
Mordekyle is online now
Old 03-27-2019, 11:04 PM   #5
duburban's Avatar
Trade: building
Rewards Points: 1,776
I was just thinking about this as Iím building a new stand and these are getting bad reviews.
Iíll attempt to explain what Iíve come up with
Cut out the whole black plastic deal. Screw a block of wood in there with a threaded insert which you can use to cam down another wooden tab onto the stand.
duburban is offline
Old 04-12-2019, 11:42 AM   #6
David-Remodeler's Avatar
Trade: Residential Remodeling Contractor
Rewards Points: 16
Duburban,
Any chance you have a photo of your fix that you could share? Last time I used my Dewalt saw and stand I thought I was going to have cut them apart with a sawzall at the end of the day and this sounds like it could be a good option for fixing it without buying new brackets.
David-Remodeler is offline
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
Dewalt Customer Service Tylerwalker32 Tools & Equipment 3 02-14-2013 08:16 PM
Dewalt Tough System Vs Bosch L Boxx madmax718 Tools & Equipment 25 01-15-2013 10:41 PM
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 01:11 PM
Makita 18v, Bosch 18v, DeWalt 20v....head to head.... CrpntrFrk Tools & Equipment 469 07-12-2012 08:12 AM
