DEWALT 20-Volt Propane Radiant Heater DXH12B With Fan, LED Light & USB Charging Ports - Tools & Equipment - Contractor Talk
Old 12-08-2018, 11:22 PM   #1
test
cedarboarder's Avatar
Trade: General
Rewards Points: 813
this is crazy! I must have one.
Ultimate Heater - The ultimate in cordless portable heaters that can work indoors was made better with DEWALT. The new DEWALT Propane Radiant Heater has more options because of the addition of it being able to take a DEWALT 20-volt or FelxVolt battery. While the heater can be used without a battery, with a battery installed you get a single speed 135 cfm fan, LED work light built into the handle and three 2 amp USB charging ports. DEWALT designed this unit for the jobsite, but any outdoor enthusiast will enjoy the extra features while hunting or camping.
No heater these days is worth buying without some sort of safety device just in case an accident happens. The DEWALT DXH12B has an ODS and a thermoelectric safety valve so you can feel comfortable using this certified indoor safe heater anywhere. If the heater were to tip forward, all gas is shut off and the possibility of a fire is reduced. This is a propane fired heater, so even though it is approved for indoor use, there still should be some sort of fresh air intake if used in small areas.
DEWALT DXH12B Features
3-USB ports for charging personal electronics and accessories
Dual tank capacity provides up to 7 hours of run-time on Low
Integrated fan to effectively disperse convective heat
Powerful LED light bar provides ideal working conditions
Mr. Heater
Do you call a circular saw a Skilsaw? Would you call this heater a Mr. Heater? They look the same, right? Well, in this case, you are correct for as much as we can gather. If you read the manual there are multiple references to using Mr. Heater products and adaptors to hook up to a larger 20-pound propane tank. If you read the Mr. Heater website, you will also not they truly want you to only use their accessories for safety. We have to assume this is a licensed product related to the Mr. Heater brand. We look at that as a great thing because Mr. Heater clearly has the market share in this type of heater and knows what they are building. There is no guesswork here and the product is that of quality. What you get is a solid heater that can be run without a battery, but with a battery installed, you get a fan to help move heat, 3 USB charging ports and also a light. That makes this an outdoors person dream!
There will be no more excuses for not having a charged phone while in the ice fishing shanty. This heater solves a problem for many people from the jobsite to the relaxing outdoors at a price that is in line with the other branded heaters.
_workshop addict
cedarboarder is offline
Old 12-09-2018, 01:44 AM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,064
Re: DEWALT 20-Volt Propane Radiant Heater DXH12B With Fan, LED Light & USB Charging Ports
This one is better. 68,000 BTU.
https://www.amazon.com/DeWALT-DXH70C.../dp/B00ETPDCJ8
Big Johnson is offline
cedarboarder (12-09-2018)
Old 12-10-2018, 08:06 PM   #3
test
Trade: General
Rewards Points: 813
I'm still amazed these can be used inside... must be a catch. do they have co2 sensors that shut it down?
I like how the mini heater you can hide the small tanks and the customer won't be worried about gas haha
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 12-26-2018, 05:59 PM   #4
Moze's Avatar
Trade: Sign Installation
Rewards Points: 484
They have an ODS (oxygen depletion sensor). If levels get to a certain point, it shuts off.
The thing works great.
Moze is offline
Old 01-04-2019, 04:56 PM   #5
madmax718's Avatar
Trade: General
Rewards Points: 3,276
This is just a modified big buddy- thing is with the big buddy, you can run the fan with D sized batteries. I really not want to keep my cell phone next to my heater anyways, and, I already have a big buddy.
I have to say though, I do really like the ridgid one, as it requires way more power, and thus a battery pack makes it more of a reason to do so.
madmax718 is offline
Old 01-09-2019, 01:07 PM   #6
test
Trade: General
Rewards Points: 813
Ya usb would be good camping but other than that... the light could be handy.
This model is priced to high here in Canada
Propane Heater SteveCuth Health & Safety 5 11-17-2016 08:19 PM
propane water heater lockout skytech21 Plumbing 1 01-12-2014 02:39 AM
Foil "insulation"? Tinstaafl Insulation 22 03-07-2011 11:01 PM
Hot Water Heater Propane or Electric? robertc65 Plumbing 11 02-19-2008 12:15 AM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
