DCN680 Not Setting Brads - Tools & Equipment - Contractor Talk
Old 08-11-2019, 10:02 PM   #1
Thadayus's Avatar
Trade: Trim carpenter
So as the title says, my 20v brad nailer isn't setting brads. It not only doesn't set them, but it looks like the drive pin is only catching part of the head of the brad so it leaves a larger hole that normal. I have the depth adjustment as low as it can go, even trimmed a bit of the no mar nose off. Any thoughts?
Thadayus is offline
Old 08-11-2019, 10:12 PM   #2
pizalm's Avatar
Rewards Points: 818
Re: DCN680 Not Setting Brads
I havenít had that problem. I have the depth adjustment maxed out the opposite way and it drives the brads to deep still.
pizalm is offline
Old 08-11-2019, 10:18 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,081
Lubrication, maybe? Could be that the nails are not sliding fully forward after each shot.
I just had that happen with a rental carpet stapler. I had to reset the clip after every shot in order to tack down three steps worth of carpet.
MarkJames is online now
Old 08-12-2019, 05:09 AM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 636
Did it get dropped? I know on the 20v framing nailers, the magazine would get shifted back from a fall, causing similar feed issues.
The fix was to remove the magazine from the nailer, split it in half, and re-install, there is a couple tabs on the nose of the nailer the magazine clips into.
mrcat is online now
Old 08-12-2019, 08:07 AM   #5
Thadayus's Avatar
I'll give those two ideas a shot. Thanks peoples
Thadayus is offline
Old 08-12-2019, 12:33 PM   #6
pizalm's Avatar
Rewards Points: 818
Where do you have the brads sitting in the magazine? All the way against the front or further towards the back?
pizalm is offline
Old 08-12-2019, 07:48 PM   #7
Thadayus's Avatar
So I took the plastic off tonight to make sure it was clean, put it all back together, fired a shot and this came out. Fired it a few more times, no problem and finally got a hole only the size of the brad. Looks like it's been jammed in there for a bit. I don't know if it's important or a mistake from the factory, but it shoots good now!
Thadayus is offline
The Following 2 Users Say Thank You to Thadayus For This Useful Post:
Defenestrate (08-18-2019), mrcat (08-12-2019)
Old 08-12-2019, 10:31 PM   #8
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 774
No matter what your mind tells you...never add oil or any lubricant to any Dewalt cordless nailer!!
Sent from my SM-T380 using Tapatalk
overanalyze is online now
