Cutting Pavers. - Tools & Equipment - Contractor Talk
Cutting Pavers.
Old 04-15-2020, 06:35 PM   #1
VinylHanger's Avatar
Rewards Points: 13,424
Cutting Pavers.
Doing a small paver job with 6x8 pavers.
What's the best tool for it. Grinder? Diamond saw in regular saw?
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
Old 04-15-2020, 06:47 PM   #2
TPS BOCO's Avatar
Trade: Fencing, woodwork
Rewards Points: 84
Re: Cutting Pavers.
Done a bunch of pavers before and HATE them, but it all depends how precise and what the perimeter is. Rated roughest to most precise..........
-Demo saw,(wet after pavers laid to define edge)
-Grinder,(preferably wet, after pavers laid to define edge)
-Wet brick saw on table,(cut all edge pieces before you lay them down)
I'm not great with the demo saw, but good masonry buddy can basically get wet brick saw results running a demo saw- but he's been doing high end flagstone work for 20 yrs....... A lot of the issue is the context of the situation and pattern- F**king herringbone!
TPS BOCO is offline
Old 04-15-2020, 06:52 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
Re: Cutting Pavers.
if you have a junker scms a diamond cutoff blade works very well.
clean accurate cuts.
second choice would be a diamond wheel in a 4" grinder.
you can use a straight edge to help achieve clean cuts
griz is online now
Old 04-15-2020, 07:12 PM   #4
Re: Cutting Pavers.
I do need a new grinder. Might be a reason to get one.
Old 04-15-2020, 07:18 PM   #5
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,406
Re: Cutting Pavers.
i have an old 7 1/4" worm drive i keep a concrete blade in . this tends to be my go to for this work . i drill a small hole in the lower edge of a 5 gallon bucket .fill it with water and let the water run out as i cut .put a screw in the hole when you stop cutting .
JFM constr is online now
The Following User Says Thank You to JFM constr For This Useful Post:
asevereid (04-16-2020)
Old 04-15-2020, 08:27 PM   #6
TPS BOCO's Avatar
Rewards Points: 84
Re: Cutting Pavers.
That's a pretty sweet work around for wet-cutting without a hose connection I haven't heard of before and bet it works good!
http://img.contractortalk.com/smilies/thumbup.gif
TPS BOCO is offline
Old 04-15-2020, 09:07 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,004
Re: Cutting Pavers.
Even that small, I'd use a demo saw if it's going to be more than half a dozen cuts. Git 'er done.
Diamond blade in a sidewinder will work, but it won't do the saw motor any good.
Tinstaafl is offline
Old 04-15-2020, 10:16 PM   #8
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,798
Re: Cutting Pavers.
Using a grinder sucks for cutting bricks
Concrete saw with a diamond cuts them like butter
Use a magic marker to mark the cut so any water spray from the blade wont vanish your line before the blade touches it for dust free cutting
Windycity is online now
Old 04-15-2020, 10:52 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,122
Re: Cutting Pavers.
My phone works best for cutting pavers. I've had great results.
Mike.
_______________
Calidecks is offline
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Dirtywhiteboy (04-19-2020), SouthonBeach (04-20-2020)
Old 04-15-2020, 11:35 PM   #10
Frank Castle's Avatar
Rewards Points: 686
Re: Cutting Pavers.
Mike.
_______________
Now that's funny right d'ere.
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following User Says Thank You to Frank Castle For This Useful Post:
Calidecks (04-15-2020)
Old 04-16-2020, 02:40 AM   #11
Re: Cutting Pavers.
Well, I needed an excuse to get a new grinder anyway for my shower doors.
Picked up the 4.5/5 M18 Fuel. It's a small job, so it should work fine.
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 04-18-2020, 11:34 PM   #12
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,971
Re: Cutting Pavers.
See if the yard where the pavers were sold from, will lend you a guillotine. A quick hit with a cordless grinder and you're in business.
rescraft is offline
Old 04-19-2020, 07:38 AM   #13
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,448
Re: Cutting Pavers.
I mark them on the ground after they are all placed and cut them with a wet saw.
If there is any super tight cuts or weird stuff I mark and cut them like doing tile, but try to avoid it, much more efficient to cut your borders in on the ground, way easier to mark them out too.
NYCB is offline
Old 04-19-2020, 09:17 AM   #14
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Cutting Pavers.
I've cut countless footings (about 10 lf of cutting each) in basements with a sidewinder with a concrete blade. Then got the medusaw which is just a skill saw with a plunge base and a water system. Both work surprisingly well and haven't burned any motors up. Pavers probably cut easier than old slabs.
Golden view is offline
Old 04-19-2020, 11:45 AM   #15
Re: Cutting Pavers.
I do have one of these in my kit. Is the cut depth 1 3/8 inches deep enough for 2 inch pavers? I assume I can cut, then split with a chisel?
https://www.homedepot.com/p/DEWALT-4...860W/203164110
Already bought the grinder though. What a bummer. Hate it when I do that.
