Crown Molding Stops For 10 Non Sliding Mitre Boxes - Tools & Equipment - Contractor Talk
Old 05-10-2011, 10:55 AM   #1
cabinet runner's Avatar
Trade: cabinet installer
Rewards Points: 150
I am looking to add a 10 in regular compound mitre box to my arsenal so I don't have to carry the heavy DW706 in for the smaller kitchens I install . However many of these small kitchens get small crown molding on them so I need a 10 inch box that has crown stops available .
I've done quite a few searches and the best option is the DEwalt 703 which uses the same stops as my 706 BUT it is no longer in production . I have a bid in on Ebay for a 703 but in case I lose it I need a backup plan . I'm not brand loyal on this but have yet to find a manufactuer that offers crown stops for their 10 inch non sliding boxes . Worst case i could drilll and tap out a 10 inch Dewalt to accept the stops from my 706 but I'd prefer to find a box that offers it's own stops .
anyone ?
cabinet runner is offline
Old 05-10-2011, 12:11 PM   #2
Feedin the geese
Joining_heads's Avatar
Trade: Finish Carpenter
Rewards Points: 286
Re: Crown Molding Stops For 10 Non Sliding Mitre Boxes
anyone ?
Depending on what type of stand you are putting your saw, you can custom make some great crown stops. My stand is a custom one of my design and I integrated Kreg aluminum channels - perpendicular to the fence on both sides of my wooden wings - that take Kreg knobs and so forth. The board has holes drilled for the Kreg knobs which get tightend- holding the board at the correct spot for the crown's spring. My crown stop works similar to this but without using clamps
+ YouTube Video
Joining_heads is offline
The Following User Says Thank You to Joining_heads For This Useful Post:
HandyHails (05-10-2011)
Old 05-10-2011, 04:35 PM   #3
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Just make your own... and the best 10" non slider is the Delta Industrial 36-585
10" DUAL bevel, all up front controls, belt drive motor. They don't make them anymore, but see if you can find one. Its nothing like the cheap Delta saws they have out now.
Here is my crown jig. Its just ply wood that forms a table and fence with and adjustable stop. The saw can do up to 4 5/8" crown nested (45 degree spring angle)
The DW703 feels like a cheap POS if you ask me....actually all the 10" saws that are made now feel like junk....
TBFGhost is offline
Old 05-10-2011, 07:27 PM   #4
Rewards Points: 150
I agree most of the 10 inch non sliders feel junky but I just need a lightweight say for cutting toekick , scribemolding and small crown molding on many of the kitchens I am currently installing . I have actaully had good luck with the older DeWalt boxes . My 706 is over 10 years old and until the bearing went it was a fine accuarate saw . It's just to heavy to lug into townhouses on a daily basis and it's capacities are not needed in these units .
I have 2 old 705s that work well but again they aren't that much lighter than the 706 . So I just need a decent 10 inch mitre box that takes adjustable crown stops . I know I could make my own but I'd rather just bolt on the ones off the 706 which work fine . I have never used he 703 but I know it is from the same older family as the 705 and 706 which IMO are superior to the newer versions . They don't make the 703 anymore but I am trying to snag one off E-bay but $90 is my limit . The crown in these units is 1 1/2 to 2 5/8 so I just don't need the big 12 inch saw to do these jobs esp since I am currently not using a helper .
I'm back to using my cabinet lift and throwing a few bucks at anyone on the job for help lifting a large vanity or countertop . So far so good and I must say i don't miss either of my last 2 helpers one bit .
Thanks for the responses
Old 05-11-2011, 06:03 PM   #5
Five Star's Avatar
Rewards Points: 1,010
When I was doing production cab installs I still have a light little hitachi non slider , with the laser , it has the higher fences and is pretty accurate , I would look at a makita 1013 or a hitachi 10" before dewalt 703 , it's a lame saw !
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
The Following User Says Thank You to Five Star For This Useful Post:
Dirtywhiteboy (06-15-2011)
Old 05-11-2011, 06:08 PM   #6
kowality
kowality's Avatar
Trade: I am a Professional Contractor
Rewards Points: 25
+ YouTube Video
I can't say enough about this video. It is spot on, great quality and informative. I have seen so many guys use the bevel setting and get into trouble. Crown Mold is just upside down baseboard. Excellent Video Thumbs Up!!
kowality is offline
Old 05-11-2011, 06:17 PM   #7
Finish Carpenter
TBFGhost's Avatar
Yeah, I use the same setup as gary on my "Shop" saw, with the full support wings. But I make a whole jig for the saws that sit on the fold-up stands. The jig has an adjustable stop and make it just large enough to hold the largest crown the saw can cut. One jig = any crown.
TBFGhost is offline
Old 05-12-2011, 09:55 PM   #8
Dirtywhiteboy's Avatar
Rewards Points: 5,150
+ YouTube Video
Clamps and I've been hot gluing mine down all this time
Dirtywhiteboy is offline
Old 05-14-2011, 08:58 AM   #9
Rewards Points: 150
Not sure why you think it is a lame saw . I won the bid on ebay $95 and the saw looks hardly used . Had to put a decent blade on it but it cut great and was square and true and it accepts the crown stops off of my DW 706 .. Now I only used it on one townhouse kitchen but it seemed fine to me . In fact it seems like the direct decendant of the original 12 inch 705 . I have 2 of those that are over 15 years old and still work great . Ofcourse I/ve had to replace the brushes a few times and a trigger switch on one of them .
I looked at the 713 which is the new 10 inch model but I just don't like the paddle that replaced the knob on the older models for some reason . I guess I'm used to the knob . I also looked at the hitachis and I am a fan of hitachi drills and impacts but their 10 inch saws have a curved base plate and I woulda had to make a crown jig . I just wanted to swap out the stops I already have and be done with it .
Kinda sucks but the prices on the hitachis are really resonable . Never used any of thier newer saws . Only the old monster tank that was the only saw that could cut big base back in the day and the 1st slider that came out but that was many years ago . Those saws were made to last . I wonder about the new ones . They had the 10 inch on sale for about $110.00 .
Old 06-12-2011, 07:32 AM   #10
Finish Carpenter
TBFGhost's Avatar
I don't know if your still looking but I bumped into this...
http://newjersey.craigslist.org/tls/2415413756.html
You will not find a better saw...
TBFGhost is offline
Old 06-12-2011, 10:44 AM   #11
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
you can always drill and tap the holes and use the dewalt stops.
blackbear is offline
Old 07-22-2011, 10:32 PM   #12
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
I do a search for Makita 7 1/2" slider and this thread pops up?
Doubt you're looking still. But the makita 7 would be light, portable, and cut the toe-kicks. But, it's got a small table and you'd have to cut crown flat. The dewalt 8 1/2" cuts base 3 1/4" and crown nested 4 1/4" (I think). The dewalt is like 47lbs. The makita is 27(?).
As far as stops, I've tossed around making my own. Never got around. Just nest flat edges and cut.
Guilford, CT Remodeler and Carpenter Web-site [email protected]
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Crown Molding installation Beausdogs Finish Carpentry 12 07-08-2010 07:51 PM
Need help on Crown Molding on Trey Ceiling pcumming Finish Carpentry 52 01-31-2010 08:42 PM
plaster crown molding install prices... CREATE NYC Finish Carpentry 21 01-27-2010 05:28 PM
plaster crown molding install prices... CREATE NYC Painting & Finish Work 2 01-19-2009 06:43 AM
Flexible Foam Crown Molding pshammond Finish Carpentry 11 08-06-2006 10:53 PM
