Countertop Suction Cups - Tools & Equipment - Contractor Talk
Old 02-02-2010, 06:42 PM   #1
Master Baiter
FowlOne's Avatar
Trade: Commercial/Residential Subcontractor
Rewards Points: 75
or seam setters. Looks like i'm going to be forced to invest in some, was wondering if any of you guys have used these. http://www.toolocity.com/images/view.aspx?productId=997
or this one
http://www.toolocity.com/images/view.aspx?productId=998
If so, what do you think of them? If not, what do you recommend?
Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. - Ronald Reagan
FowlOne is offline
Old 02-02-2010, 07:07 PM   #2
genecarp's Avatar
Rewards Points: 2,000
Re: Countertop Suction Cups
Dont know why, but i like the looks of the second one, more basic design i guess, GMOD
genecarp is offline
Old 02-02-2010, 08:23 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,748
I have used one's that came in a yellow tool box and were some sort of venturi suction system.
I will give you a link that talks about various kinds.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
FowlOne (02-02-2010)
Old 02-02-2010, 08:56 PM   #4
Master Baiter
FowlOne's Avatar
Rewards Points: 75
Me too, it's about $200 cheaper also
FowlOne is offline
Old 02-02-2010, 09:12 PM   #5
slave driver
glassman's Avatar
Trade: project manager commercial contract glazier
Rewards Points: 75
The Woods power grip suction cups are used by counter top installers for marble, granite, stone and the synthetic resins also.
They were originally designed for the glass handling market.
The standard 8'' cup will lift a rated 280 lbs, will stick to any flat, non porous surface.
I have used them to lift and move appliances, flat aluminum and steel sheet stock. They will also stick to Formica and other laminates.
Best of all they only cost $58.00.
Some rental centers carry them and my company rents/lends them out to our contractors.
glassman is offline
Old 02-03-2010, 12:06 AM   #6
Master Baiter
FowlOne's Avatar
Rewards Points: 75
Thanks for the info I'm familiar with these, unfortunatly they wont serve my purpose, Material handling's not what i'm looking for, it's the ability to hold "field seams" together while also holding them flush at the same time.
FowlOne is offline
Old 02-03-2010, 05:44 AM   #7
Kent Whitten's Avatar
Rewards Points: 2,040
I believe those are Gorilla Grips. I'm not sure if that's what Fowl is looking for to spend. I think they are the Festool of seam setting.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 02-03-2010, 05:57 PM   #8
Master Baiter
FowlOne's Avatar
Rewards Points: 75
I'd expect nothing but the finest coming from Warner, and as sweet as those are you're right, it would be overkill for what i'm doing.
FowlOne is offline
Old 02-03-2010, 10:40 PM   #9
wayne3434's Avatar
Trade: carpenter/remodeling
Rewards Points: 91
i need something to move a 600lb concrete countertop?? will any suction cups hold that wieght?
wayne3434 is offline
Old 02-03-2010, 10:53 PM   #10
I like Green things
Thanks, but, just what are you doing?
Warner Mill Works
Facebook
YouTube
Old 02-04-2010, 09:39 AM   #11
Master Baiter
FowlOne's Avatar
Rewards Points: 75
Heh, guess that information woulda been helpful. I'm dealing with corian. The jobs I'm doing have multiple field seams(average 8 seams per job), and the more seams I can do at the same time the better. The countertop manufacturer was using a plywood base with "dogbones" at the seams to pull them tight, however, (due to price) they've changed they way these things go together, MDF base(which sucks) and have eliminated the dogbones, so now I'm in need of something to pull the seams together when I apoxy them.
FowlOne is offline
Old 02-04-2010, 10:25 AM   #12
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Get a glue gun and hot melt scrap blocks on each side of the seam. Clamp and let set. Knock the blocks off and clean the seams.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Outlets in countertop genecarp Electrical 26 05-08-2011 10:27 AM
Concrete Countertop 7' x 10' x 1 1/2" Point of Views Masonry 6 09-18-2009 08:58 PM
When to grind a concrete countertop Bazooka Joe Concrete & Paving 2 09-06-2009 06:09 AM
countertop Traditions2 Painting & Finish Work 1 07-29-2009 09:12 PM
Custom Concrete Countertop Mixes duburban Concrete & Paving 6 06-09-2009 05:39 PM
