Coredrill Vacuum Base And Flatwork Seams - Tools & Equipment - Contractor Talk
Old 06-14-2011, 08:55 PM   #1
Metalguy63's Avatar
Trade: Metalscape, Inc.
I have a Hilti DD200 core drill with the vacuum base. Terrific tool but I constantly run into problems catching a vacuum on flatwork. I'm drilling for pipe rail posts and any time the hole must be near an expansion seam the base won't seal and it breaks the vacuum and I have to do it by hand. I'm talking the seams where they use the plastic stuff that leaves about a 1/2" double radius when its pulled. Anyone come up with a way to span these and keep a seal? I've tried plugging and sealing them with the foam rod stuff for filling big gaps when caulking but to no avail.
Metalguy63 is offline
Old 06-15-2011, 04:23 AM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Coredrill Vacuum Base And Flatwork Seams
Unfortunately it's hand held in these areas.
Wanna try a real fun one...try using the vacuum on an ICF wall!!! It doesn't work unless you mount a piece of 3/4" ply and then I can have it hanging there
Chris
Chris Johnson is offline
Cold Weather Flatwork??? Sar-Con Excavation & Site Work 7 12-09-2010 08:42 PM
Flatwork prices Same Old Concrete & Paving 10 03-26-2008 07:19 PM
