Cordless SDS Dust Extraction Options - Tools & Equipment - Contractor Talk
Old 11-14-2018, 08:50 AM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,250
Almost every remodel I do includes adding seismic hold downs with 100 or 150 1/2" holes in concrete. I want to avoid exposure to silica dust.
I like using my Milwaukee cordless rotary hammer and staying cordless is preferred.
My options seem to be:
The m18 hamervac which is powered directly from the 1 1/8" rotary hammer. Middle weight and bulk
The M12 hammervac which is universal but heaviest and bulkiest
The Milwaukee dust trap, which is a simple non powered option, super light, but maybe only somewhat effective
The SDS Max dust extraction attachment, which requires a separate vacuum. Maybe the new backpack vacuum would be best for lowest fatigue.
Anyone have any experience with these and preferences, or other solutions?
Golden view is offline
Old 11-14-2018, 09:11 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,084
Re: Cordless SDS Dust Extraction Options
That's a lot of holes, how about a vac with a dust collector head like a Bosch HDC200.
You will choke out a drill mounted collector before you finish your first cup of coffee that day....heck my little festool vac is choked out after 10x 1/2" holes.
Inner10 is offline
Old 11-14-2018, 01:56 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
If you are drilling 1/2" holes you must be using Titen HD's? Or? Just curious...
As I understand it the strongest option is a 3/4" hole with an epoxied in 5/8" all threaded rod. Therefore it requires using a brush, then blowing the hole out at the same time as running a dust collector. I use something similar to the Bosch HDC200 mentioned above that I quickly made from wood by drilling three holes in a 4x4 with some weatherstripping at the bottom, but I probably should just buy the Bosch. Been using a small cheap Ridgid vac for crappy work for years and other than tearing through bags and filters it won't die. If working on a dirt floor I ALWAYS wear a respirator anyhow. Amazing how much dust is kicked up just moving around under a house, let alone the dust knocked off from above hammering on stuff.
A vac with a thumper built in is best for concrete dust. Milwaukee, Festool CT36 AC, Starmix, etc.
Will be interesting to see how the new Milwaukee backpack vac works as it functions more like a Dyson by not using bags. Will the filters plug with the fine dust? Gotta dump it though which will create a dust cloud. Bags have a purpose. Makita uses bags on their 36 volt backpack.
Another option is to get a really long hose and leave the "plugged in" dust collector far away, which would mean a Festool as they offer the Bluetooth remote.
Peter_C is offline
Old 11-14-2018, 06:49 PM   #4
edward trowelhands
Trade: Diplomat
I do have an auto cleaning hepa vac. It can fill with 50 pounds of concrete dust without getting clogged, but I was wondering if I could do something more mobile. Drilling holes doesn't make that much dust, compared to cup wheels on floors anyway.
I'm doing titen HDs. Horizontally. Usually I have a couple vertical 5/8 threaded rod with brush/blow repeat 10 times and special inspections too. But these plates are way easier since you don't need to drill from inside the wood wall above.
The Titens go into Simpson FJA and URFP. They are loaded in shear, not tension.
cordless SDS dust extraction options-simpson-strong-tie-construction-connectors-urfp-sds3-64_1000.jpg   cordless SDS dust extraction options-fsa_layer.jpeg
Peter_C (11-14-2018)
Old 11-17-2018, 11:33 PM   #5
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,930
how is the strap used .looks like two titans into concrete and lag screws into the pony wall studs .but foundation is not generally flush to the pony wall
JFM constr is offline
Old 11-18-2018, 10:53 AM   #6
edward trowelhands
Trade: Diplomat
It's for joists over a basement concrete wall when there's not a pony wall. It attaches to the concrete and the floor joists. The other one attaches to concrete and the mud sill. The shape of it works if the mud sill is not flush to the inside of the foundation by up to almost two inches.
Old 11-29-2018, 02:50 PM   #7
madmax718's Avatar
Trade: General
Rewards Points: 3,272
cant see how removing 1/2" material in a hole doesn't make some decent amount of dust. I got the bosch 200- as a plus, it sucks in place by itself. The 300 is just way too large for anything I do.
I don't even use a cordless SDS for the reason that every small dust collector vac clogs up too quick.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Golden view (11-29-2018)
Cordless Drill - Dust Containment ? mobiledynamics Tools & Equipment 8 01-20-2014 08:02 PM
Dust Collectors mattsk8 Tools & Equipment 10 02-03-2012 04:45 PM
floor sanders and dust extraction Erikfsn Tools & Equipment 10 12-27-2010 04:12 PM
looking at a festool cordless drill fr8train Tools & Equipment 31 05-10-2009 02:28 PM
