Completely Unacceptable Bosch! - Tools & Equipment - Contractor Talk
Old 11-21-2014, 02:40 PM   #1
Nail Driving Fool
Robinson1's Avatar
Rewards Points: 1,333
I don't do a lot of work with metal but this morning I needed to anchor some brackets to some 1 1/2" square steel tubing, 1/8" sidewall. Grabbed my Bosch Impactor and a 5/16" nutsetter.
I was using #12 self tappers that were supplied with the brackets. Quickly became apparent that the Impactor really didn't like what I was asking it to do. 28 screws later I had 4 dead batteries and the job was finished.
This is BS Bosch.
To make matters worse the homeowner was standing beside me the entire time. Even made the comment that "He would have never dreamed the screws would have been that hard to put in."
I was so pissed off I almost stopped at Hilti on the way home.
ROBINSON
CARPENTRY & PAINTING
Jackson, KY
606-568-7202
Robinson1 is offline
Old 11-21-2014, 04:49 PM   #2
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Re: Completely Unacceptable Bosch!
Probably could have saved some trouble with pilot holes.
EricBrancard is offline
The Following 6 Users Say Thank You to EricBrancard For This Useful Post:
CarpenterSFO (11-22-2014), Dustincoc (11-21-2014), Jaws (11-21-2014), jhark123 (11-21-2014), mgb (11-22-2014), Pako (11-21-2014)
Old 11-21-2014, 05:16 PM   #3
madmax718's Avatar
Trade: General
Rewards Points: 3,276
without holes, im surprised you made it anywhere, and really surprised you didn't snap a screw.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Old 11-21-2014, 05:30 PM   #4
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
He must have drilled pilot holes with the #12's into steel. Was this the 12V or 18V?
Rustbucket is offline
Old 11-21-2014, 05:56 PM   #5
rustyjames's Avatar
Rewards Points: 1,816
Perhaps you were using the wrong self tappers? There are those for drilling sheet metal, and then there's the type for structural steel
rustyjames is online now
Old 11-21-2014, 06:00 PM   #6
TimelessQuality's Avatar
Rewards Points: 1,730
I have good luck with Tek self-drillers
-Steve
TimelessQuality is offline
The Following 2 Users Say Thank You to TimelessQuality For This Useful Post:
Inner10 (11-22-2014), mikeswoods (11-22-2014)
Old 11-21-2014, 06:06 PM   #7
Nail Driving Fool
Robinson1's Avatar
18v and yeah I drilled pilot holes.
Screws supplied with the brackets.
They were NOT sheet metal screws.
ROBINSON
Jackson, KY
606-568-7202
Old 11-21-2014, 06:09 PM   #8
Nail Driving Fool
Robinson1's Avatar
Drilled pilot holes.
ROBINSON
Jackson, KY
606-568-7202
Old 11-21-2014, 06:18 PM   #9
So...
You hammered through 4 batteries to put in 28 screws that already had pilot holes??
Maybe your pilot was too small..
-Steve
Old 11-21-2014, 06:55 PM   #10
Kevin M.'s Avatar
Rewards Points: 2,164
Robinson,
A self tapping screw is not necessarily a self drilling screw. A self drilling screw may also be a self tapping screw.
You should park that impact driver when metal applications are involved. A self drilling screw will go through 1/8 inch steel easily if you have the right fastener. Self Drilling means use a drill. When the threads catch you will be aware that is happening. Switch your drill to low and finish it using your clutch so you don't break the screw.
Try that next time.
Google Fastenal self drilling screws if you need to see what a self drilling screw looks like.
Kevin M. is offline
The Following User Says Thank You to Kevin M. For This Useful Post:
Tom Struble (11-21-2014)
Old 11-21-2014, 07:04 PM   #11
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Yeah self drilling and self taping are completely different screws. You need a high speed drill and corded would be best for self drilling. If you were using self taping then you either had the wrong size pilot hole or you had the drill in reverse lol
I have put hundreds of these screws in with my 3ah packs so the Bosch should easy be able to do that on one pack.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Kevin M. (11-21-2014)
Old 11-21-2014, 07:07 PM   #12
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,302
Just a thought...were the batteries cold...as in real cold?
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is offline
Old 11-21-2014, 09:04 PM   #13
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
You gotta use a drill not am impact. I install tek screws by the hundreds. Typically I get at least 100 # 12s per charge. (Makita) I never put in a pilot hole either
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
The Following User Says Thank You to JT Wood For This Useful Post:
Old 11-21-2014, 09:45 PM   #14
tjbnwi's Avatar
Rewards Points: 4,006
Installing 14x3/4 self drilling Tek screws into 1/8" aluminum, my CSK 10.8v drill out preformed a Makita 18v impact 2 to 1. Side by side comparison, each tool running at the same time (I was using my CSX, someone else was using his Makita impact). This is one of those applications where a drill is the right tool.
tjbnwi is offline
Old 11-21-2014, 10:01 PM   #15
Trade: Construction
That's weird my 18v makita Impact puts about 3-4x as many screws in per charge than my CXS. But my CXS is sooo much nicer to use.
Old 11-21-2014, 10:03 PM   #16
NCMCarpentry's Avatar
Rewards Points: 860
Sounds defective...
NCMCarpentry is offline
Old 11-21-2014, 10:08 PM   #17
tjbnwi's Avatar
TEK self drilling?
I no longer own a cordless impact. After burning up 3 Bosch 18v in a year I gave up. Can't stand the noise anyways. If I need an impact I break out the air powered ones. I have them in 3/8-3/4 drive up to 1200 foot pounds.
tjbnwi is offline
Old 11-21-2014, 10:24 PM   #18
Trade: Construction
TEK self drilling?
I know longer own a cordless impact. After burning up 3 Bosch 18v in a year I gave up. Can't stand the noise anyways. If I need an impact I break out the air powered ones. I have them in 3/8-3/4 drive up to 1200 foot pounds.
I'm using like for like screws as a comparison. As an example I put about 500 1.5" spax wood screws into some sub floor with my makita on 6 year old pack before a need a recharge. I got about 200 out of the CXS before battery cut off. Not that I expect a 1.3ah 10.8v drill to perform like a 18v 3ah impact. 200 was pretty good for the CXS in my eyes though. There's just no way I would expect to see the CXS out do the makita on anything but weight.
Old 11-21-2014, 10:37 PM   #19
tjbnwi's Avatar
The CSX spun the screws in faster, total of 50 screws. I ran 35 to his 15, I know the count, we were installing E-track in my trailer.
I believe the Mikita would have run in more screws per charge.
tjbnwi is offline
Old 11-21-2014, 11:03 PM   #20
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 18,626
This is a good question.
They always keel over real fast if you left them in the truck on a freezing night.
Easy Gibson is offline
Worth It? Bosch 1640VS (Fine Cut Power saw) David7586 Tools & Equipment 34 03-05-2017 09:03 PM
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
Bosch Drill 99 dollars JonM Tools & Equipment 21 02-21-2013 01:19 PM
bosch table saw problem Mrmac204 Tools & Equipment 15 01-20-2013 09:47 AM
Dewalt Tough System Vs Bosch L Boxx madmax718 Tools & Equipment 25 01-15-2013 10:41 PM
