Chalk Line With A Fine Line? - Page 2 - Tools & Equipment - Contractor Talk
Old 04-28-2015, 12:09 PM   #21
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Re: Chalk Line With A Fine Line?
Originally Posted by tjbnwi View Post
I wait until I need $500.00 worth of stuff, then I don't feel so bad about spending $1000.00.
You did get a Tajima dripless caulk gun??? If not you should have.
Does that caulking gun actually work well? I always thought it was a gimmick.
TaylorMadeAB is offline
Old 04-28-2015, 12:40 PM   #22
TheGrizz's Avatar
Trade: Remodeling and handyman
Rewards Points: 967
I don't have a Tajima dripless gun, but I do have a Dripless brand gun. I have moved it to my backup in favor of a Kobalt that keeps consistent pressure on the tube on the recommendation of Super Seal on here. I find it easier to make a nice clean bead because I have a consistent flow of caulk as opposed to it starting and stopping every time I grab/release the trigger.
TheGrizz is offline
Old 04-28-2015, 12:45 PM   #23
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,156
Put this in your chalk box. Snaps about a 0.05 mm line.
http://www.amazon.com/100LB-Dyneema-...0136811&sr=1-7
We use Spider Wire braided line.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 04-28-2015, 02:04 PM   #24
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
What is a good size fishing line for snapping lines on concrete. that's about 90% of what I use a box for
scottktmrider is offline
Old 04-28-2015, 02:28 PM   #25
Spyrus's Avatar
Rewards Points: 92
I find the tajima caulking guns are good for warm weather. Once it's freezing and colder I find them a little too stiff for my liking.
As for their chalk lines I started getting the black plastic jam free ones and they keep going 2+ years later of framing. My red one didn't barely make a year.
Spyrus is offline
Old 04-28-2015, 05:02 PM   #26
tjbnwi's Avatar
Rewards Points: 3,846
Depends on how wide of a line you like. Any braided fishing line will work. TNT mentioned the Spyder Wire line, I think I have that in one of my boxes.
tjbnwi is offline
Old 04-28-2015, 05:03 PM   #27
tjbnwi's Avatar
Yes, I've used Justins', finally got my own.
tjbnwi is offline
Old 04-28-2015, 05:04 PM   #28
tjbnwi's Avatar
I'm an old guy, don't work outside when it's freezing.
tjbnwi is offline
Old 04-28-2015, 07:29 PM   #29
tjbnwi's Avatar
For any chalk line the Tajima chalk will give you a better line. It is ground much finer than any other chalk I've seen.
tjbnwi is offline
Old 04-28-2015, 08:12 PM   #30
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
I tried some old Fireline brand braided fishing line before and it didn't hold the chalk that well. I ended doing what Tom said and loaded up my Irwin's with Tajima chalk and they snap much nicer lines now.
BBuild is offline
Old 04-28-2015, 10:12 PM   #31
Hair Splitter
Trade: General
Spiderwire
Old 04-29-2015, 12:13 PM   #32
Rewards Points: 295
What's different about the tajima chalk, I do metal framing so most of my use is snapping lines on concrete but I still like a bold and semi fine line. and snapping long walls I like to pull it tight and make the apprentices finger bleed, lol
Old 04-29-2015, 01:08 PM   #33
tjbnwi's Avatar
I think Tajima grinds it much finer than other chalks I have used.
tjbnwi is offline
Old 04-29-2015, 06:34 PM   #34
JR Shepstone's Avatar
Rewards Points: 1,552
I have both the chalk, and the snap line dye, if I'm not mistaken.
The chalk seems a little finer, and lighter in color than an Irwin brand.
The dyes snap nice crisp lines, they don't wash away easy, either.
Don't pull a tajima line tooooo tight, it won't snap well. They even mention that on the box.
Only drink 23, that way they won't have a case against you.
JR Shepstone is offline
Old 04-29-2015, 06:47 PM   #35
BBuild's Avatar
The Tajima chalk definitely seems finer than other brands. It's like baby powder and gives a more crisp and bold line.
I've found if I don't overfill it I get much better results . Too much chalk gives a fuzzy and blurry line. If the line seems to be holding too much chalk I give it a light flick before laying it on the mark.
BBuild is offline
Old 04-29-2015, 08:26 PM   #36
Rewards Points: 295
What's the reason you can't pull it tight. I guess a thinner line wouldn't need to be pulled as tight as regular line,huh?
Old 04-29-2015, 08:58 PM   #37
hdavis's Avatar
Rewards Points: 3,984
Squeezes the braiding together, so it loses chalk.
hdavis is online now
kwunch (04-30-2015)
Old 04-29-2015, 10:26 PM   #38
Spyrus's Avatar
Rewards Points: 92
http://www.newborncaulkguns.com/cate...-tender-models
Spyrus is offline
The Following 2 Users Say Thank You to Spyrus For This Useful Post:
hdavis (04-29-2015), Xtrememtnbiker (04-29-2015)
Old 04-30-2015, 12:03 AM   #39
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Originally Posted by jimwalter View Post
still thick enough for framing?
those tajimas are damn near invisible on osb
Use black masons chalk......it's like a fine tipped sharpie line.
wallmaxx is offline
Old 04-30-2015, 06:42 AM   #40
tjbnwi's Avatar
The caulk tube at the end would be to heavy for me.
tjbnwi is offline
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
fine line bolt slot suspended ceiling diffuser Rich D. HVAC 4 01-03-2013 01:32 AM
airless fine finishing coin9961 Painting & Finish Work 2 12-15-2012 01:10 PM
Fine glass too hard to shoot. Betterblast Sandblasting 20 08-25-2012 08:35 AM
Adding Chalk line chalk to touch up mud AARC Drywall Drywall 20 04-12-2009 06:12 PM
