Cap Stapler - Tools & Equipment - Contractor Talk
Cap Stapler
Old 08-10-2014, 05:06 PM   #1
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
Cap Stapler
What is everybody using?
Windows on Washington
WindowsonWash is offline
Old 08-10-2014, 05:15 PM   #2
MDjim's Avatar
Trade: General Contracting/Insurance Repair
Re: Cap Stapler
I have the bostich. Grabbed it one day cause its the only one sold around here. It's kind of awkward and heavy. But it's the only one I've ever used so I don't know how that compares to others. And somehow I always end up with a ton of caps around and no staples.
MDjim is offline
Old 08-10-2014, 05:16 PM   #3
Artworks's Avatar
Trade: Renovations & Construction
Rewards Points: 354
Re: Cap Stapler
I have a Stinger 3/8 cap stapler for syn. roof underlay. Works ok but sometimes you pull a string caps when they wont cut apart, don't know if its tool / caps or way hold it sometimes. Way more secure than staples only and faster than hand nailing underlay.
IF IT WAS EASY, EVERYONE COULD DO IT !
Artworks is offline
Old 08-10-2014, 06:19 PM   #4
gillisonconstru's Avatar
Trade: General Contractor/ Carpentry
Rewards Points: 344
Re: Cap Stapler
I trashed 2 of the Bostitch cap staplers, I was reluctant to try another gun by Bostich but they talked me into this one it keeps up bump nailing and is an all around great gun no complaints. Highly recommend it...
http://bostitch.com/default.asp?CATE...%3B+Cap+Nailer
gillisonconstru is offline
Old 08-10-2014, 06:55 PM   #5
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Cap Stapler
I use the Bostich cab stapler also.
works good for us. Broke a stinger in a week.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 08-10-2014, 07:03 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 5,445
Re: Cap Stapler
I have the Button Kap brand stapler, and the nailer. Neither one has worked for me in the last five years. I gave up and returned to had capping.
Easy Gibson
Warren is offline
Old 08-10-2014, 07:50 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Cap Stapler
We've had good luck with the bostich. They do need repaired about once a year. I complained and they sent a whole box of the replacement parts I needed.
I also tried the hitatchi but don't like the coils of caps
jlsconstruction is offline
Old 08-10-2014, 08:40 PM   #8
kyle_dmr's Avatar
Rewards Points: 998
Re: Cap Stapler
Been using the hitachi for 4 years. Regular amount of repair I would say. We run about 40 boxes of caps and nails a year through it. Ended up purchasing a second one recently as they have been discontinued and mine was in for repair.
I only buy the hitachi brand nails though. The knock offs have given me tons of problems and winter time is even worse for them. They are extremely expensive nails, and gun, but doing houses with all foam board exterior is well worth it to me. I figure it's 3x faster to gun them than handnail
kyle_dmr is offline
Old 08-16-2014, 10:47 AM   #9
Steve'sSon's Avatar
Trade: Mostly remodel carpentry. We're a very diversified crew, there isn't much we haven't done.
Rewards Points: 116
Re: Cap Stapler
We use stingers.
They're ok. Have some quirks. They're better now than they were a few years ago.
We use the auto loading version. The trigger version was a little more reliable at first but then the triggers start getting really stiff.
Steve'sSon is offline
Old 08-16-2014, 03:57 PM   #10
mako1's Avatar
Rewards Points: 1,094
Re: Cap Stapler
I use the Bostitch.All my guns are Senco except for this cap stapler.Worked flawlessly for three boxes of 5000 and now the caps don't want to shoot right.Get a lot of staples with no caps.
mako1 is offline
Old 08-23-2014, 08:55 AM   #11
BNL Builders's Avatar
Rewards Points: 122
Re: Cap Stapler
We use the grip rite cap stapler. 1/2" crown 5/8 length staples. I like how small it is. I also like that the staples are laser welded together. Holds same amount of staples as caps.
BNL Builders is offline
Most versatile flooring stapler Spencer Flooring 12 11-12-2013 12:47 AM
Soffit stapler mastafunk Tools & Equipment 14 07-21-2013 07:13 PM
Primatech flooring stapler PaulPrice Flooring 14 07-04-2011 01:45 PM
Duo-Fast Floor Stapler Repair Kit? HandyHails Flooring 4 10-17-2010 08:52 PM
Bostitch Model H2B hammer stapler bigblack'74 Tools & Equipment 0 04-12-2010 04:59 PM
