Buildclean Review - Page 4 - Tools & Equipment - Contractor Talk
Buildclean Review
Old 03-20-2016, 06:20 PM   #61
Grunt
LI-Remodeler's Avatar
Trade: Residential Remodeler
Rewards Points: 320
Re: Buildclean Review
I'm currently in the market for air filtration. I've been doing my research and BuildClean doesn't come close to others for same price or less.
What is the clean-room classification for BuildClean? There is very limited information on their web page on specifications and that doesn't sit well with me.
I need real filtration that can do real volume, not something that is superficial and looks good in the middle of the room.
LI-Remodeler is offline
Old 03-21-2016, 12:55 AM   #62
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
What CFM are you thinking BiuldClean has 600.
charimon is offline
Old 03-21-2016, 05:25 AM   #63
Grunt
Rewards Points: 320
looking into 1000 cfm with a minimum of a cleanroom classification of ISO 5
The Following User Says Thank You to LI-Remodeler For This Useful Post:
charimon (03-21-2016)
Old 03-25-2016, 10:23 AM   #64
madmax718's Avatar
Trade: General
Rewards Points: 3,276
You'd need quite a few filter units to try and replicate an ISO 5- let alone the dust you'd create during a job. You could use a few ducted units to bring filtered air in, and a few filters running the air out.
Its unrealistic in a portable job site situation to try and obtain such levels of filtration. The amount of air you would have to move to try and collect those tiny particulates in way above 600cfm, unless the room was particularly tiny.
One of the stipulations of air filtration is that enough air must be physically moved for the filter to pickup particulates. you can have a super hepa filter, but if it moves 1cfm, you cant clean the air 12 feet away.
madmax718 is offline
Old 04-09-2016, 08:01 AM   #65
Grunt
Rewards Points: 320
I agree and that's one of the reasons why I invested in a larger machine that can move air. Novair 2000. Used it for the first time this last week on a restoration/painting job and it performed above my expectations at the lower level of 1000cfm, on high level 2000cfm it's a beast. Not loud at all and easily portable with two guys.
It pulls high volumes of air so fast the dust has little time to settle. I wanted an air scrubber that can stay ahead of your work not have to catch up.
Metro M & L (04-09-2016)
Old 03-02-2019, 09:52 AM   #66
JDSpaceman's Avatar
Trade: Space Improvements
Rewards Points: 4
Good morning. I'm new to this blog.
How are these units running 3 years later?
Still worth the investment?
How long did the prefilters last? (last post had caked prefilter but still working)
Any other brand to check out if these aren't a "recommended buy"?
JDSpaceman is offline
Old 03-02-2019, 10:42 AM   #67
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 342
We still use ours on most jobs we do. One of them quit working last week but I believe it to be a sort of electrical issue as the gfci on the unit tripped and will not reset.
Pre-filters get cleaned several times a day on heavy demo (take this to mean plaster or masonry demo) We do our best to collect dust at the tool and minimize airborne dust in the first place.
On a kitchen remodel with any reasonable amount of demo filters get changed at the end of the job. Smaller jobs we don't bother tossing the filter if there is still life left in it.
Early on we made the mistake of trying to blow out the pre-filter a bunch to save money and then the Hepa filter ends up doing more of the work and it's a lot more expensive to replace than the pre-filter.
Xtrememtnbiker is offline
Old 03-02-2019, 10:54 AM   #68
JDSpaceman's Avatar
Rewards Points: 4
how much is a HEPA filter? life span in days or weeks of run time?
do you think that GFCI is covered under warranty? or fixable yourself?
Old 03-02-2019, 11:33 AM   #69
Rewards Points: 342
Hepa filter is $150. Pre-filters are $25.
It's really hard to say on the hours of run time because it depends a great deal on what level of dust you're creating. If you're gutting a big kitchen with plaster (which we just did) by the time you're done you might as well throw that filter away and put on a new one, and this is after using a cordless leaf blower to blow it out many times.
Not sure on the warranty. I'll be trying to take care of that next week. I'm far too busy to try to fix it myself so either they will take care of it under warranty or I'll be sending it in.
Old 03-02-2019, 09:27 PM   #70
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,526
I vacuum pre-filters every night before leaving... and replace them every bad dusty job.
mstrat is offline
Old 05-14-2019, 08:27 PM   #71
J.C.'s Avatar
Rewards Points: 242
Thumbs down
I got a buildclean a few months ago and figured I'd give my review. I'd say customer service seems to be severely lacking. The short version of the story is I kept getting an Error 2 and had a hard time getting a response from buildclean. After I did talk to them, it seems to just be a faulty prefilter and they said they would replace it. Well, it's been over a month now with no replacement filter and no response back from them. This is my first and last BuildClean.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 05-15-2019, 01:05 PM   #72
Rewards Points: 342
That is odd. Quite a different experience than I have had with the customer service.
We have had two units replaced for free (not sure what that says about the units...?) including the one that was out of warranty.
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
J.C. (05-15-2019)
Old 05-15-2019, 02:06 PM   #73
Remodeling GC
kevjob's Avatar
Rewards Points: 412
I have my Ermator A600 x2 for 3 years now and never an issue with any of them, if you are interested.
https://www.amazon.com/Pullman-Ermat.../dp/B01LZ43WXE
I bought my second one for 635.00, first one was closer to 800.00
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
J.C. (05-15-2019)
Old 05-15-2019, 07:49 PM   #74
J.C.'s Avatar
Rewards Points: 242
Have you called them or emailed them? I've mainly emailed but have also called them once. It's been the "product manager" I've been in contact with.
What type of problems have you had with your units?
J.C. is offline
Old 05-15-2019, 08:41 PM   #75
Rewards Points: 342
Always called, never emailed.
First unit was some sort of error code that was a known issue for them and they replaced that unit. Second unit was they had a bad batch of GFCI's a few years back, also a known issue and they replaced that unit.
The bad GFCI unit was out of warranty but they replaced it anyway and since it was out of warranty I didn't have to send it in. You better believe it's got a GFCI from off the shelf at Lowes in it now...
J.C. (05-16-2019)
Old 06-05-2019, 08:00 PM   #76
J.C.'s Avatar
Rewards Points: 242
Thumbs down
Thought I should update my post. I heard back from Kevin Dompke on 5/16, the "product manager," that I've been in contact with since the beginning. He thanked me for the reminder and said, "Yes, I will ship the filter out today." Three weeks later and still no filter.
J.C. is offline
Old 06-06-2019, 08:14 AM   #77
Dan_Watson's Avatar
Rewards Points: 2,748
Two units running here for years without issue. We bought the first one in 2015 and the second in 2017.
Dan_Watson is offline
Old 06-07-2019, 11:30 AM   #78
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
He didn't say which "today."
EricBrancard is offline
Old 06-07-2019, 06:51 PM   #79
J.C.'s Avatar
Rewards Points: 242
Well, it took waaaaaaaaaaay longer than it ever should have and was a much bigger pain in the a** than it should have been but, I have a replacement filter. He actually ended up shipping 5 of them to me on June 5 and I received them today.
J.C. is offline
The Following 2 Users Say Thank You to J.C. For This Useful Post:
overanalyze (06-07-2019), Xtrememtnbiker (06-07-2019)
Old 06-07-2019, 08:42 PM   #80
tjbnwi's Avatar
Rewards Points: 4,734
This is nothing, try getting information, warranty, services, parts from Laguna.
tjbnwi is offline
Website review if you have the time TLHWindows Websites and SEO 35 09-16-2013 12:48 PM
Deck Construction @ Winery: Review Our Plans? dutchswan General Discussion 14 05-23-2013 12:14 PM
Website Review Input tonyc56 Websites and SEO 12 01-02-2013 05:26 AM
Agreement Not to Review EcoStar Remodel General Discussion 10 06-04-2011 05:06 PM
