Bits And Common Screws Storage - Tools & Equipment - Contractor Talk
Old 09-17-2019, 07:16 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,633
Has anybody put together a single storage container for all the bits and screws commonly used? Was it as good as it sounds, theoretically?
I'm thinking of something to replace the juggling act of multiple bit cases, plus the most common fasteners.
Drill bits, drive bits, countersink, torx, square drive, vix bits, magnetic, extenders, cutting bit, rotary rasp, etc...the whole enchilada.
What else am I missing at the moment?
MarkJames is offline
Old 09-17-2019, 07:48 PM   #2
Tom M's Avatar
Rewards Points: 4,406
Re: Bits And Common Screws Storage
Cant do it. I have small zip bags of bits, bit assortment holders and stack of screw assortments and still grabbing new stuff occasionally with no home.
Tom M is online now
Old 09-17-2019, 07:50 PM   #3
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,600
No excuse to not have a bit.... period. We all keep the usual in small box or in bags:
T15 T25.T40 3/16 1/4" impact predrill. Tappered predrill. 2" Phillips which never gets used.
Sent from my E6810 using Tapatalk
CityDecks is offline
Old 09-17-2019, 07:51 PM   #4
CityDecks's Avatar
Trade: Deck Builder
Originally Posted by CityDecks View Post
No excuse to not have a bit.... period. We all keep the usual in small but box or bags:
And God help you if you don't out my chitt back.
Old 09-17-2019, 07:53 PM   #5
CityDecks's Avatar
Trade: Deck Builder
The SDS has #3 Phillips and 5/16 for tapcons and 25+/- each in Lil DeWalt tstak container in bottom of tstak included every possible but bit we would ever use.
Old 09-17-2019, 08:00 PM   #6
MarkJames's Avatar
I forgot some....paddle bits, masonry bits, hex drivers, angle bit holder, flex bit holder... might as well throw in a set or two of hex wrenches.
Old 09-17-2019, 08:00 PM   #7
CityDecks's Avatar
Trade: Deck Builder
In cordless tstak labled Hilti #1 has. Guide rail plate ( track saw guide rail plate) and blade behind plywood.
Also holds 6.5" sirc. 2- impacts. 1/ high-speed charger. And 4/ batteries.
Hilti #2 tstak is my go-to with one Impact. 3 batteries. 1/ high-speed charger. 1- sirc. Keep the 4th in truck if/ when needed. Also have Hilti 12v in truck for ipe when there's a lot of predrilling the 12v is super light and makes so easy.
Router and jig combo. Loaded with everything I could ever use. Addition accessories in truck. Added when needed.
The Following User Says Thank You to CityDecks For This Useful Post:
MarkJames (09-17-2019)
Old 09-17-2019, 08:01 PM   #8
CityDecks's Avatar
Trade: Deck Builder
Forgot there is the right angle tight space driver extension in tstak with cordless GRABNGO'S
Old 09-17-2019, 08:02 PM   #9
CityDecks's Avatar
Trade: Deck Builder
Right angle tight space extensions in both Hilti #1 and #2 tstak
Old 09-17-2019, 08:06 PM   #10
CityDecks's Avatar
Trade: Deck Builder
Id have to quit. Couldn't do it. God give strength I don't have the patience.
Tom M (09-17-2019)
Old 09-17-2019, 08:17 PM   #11
Tom M's Avatar
I too have put Tstaks to good use for bits. The drawer ones
Tom M is online now
Old 09-17-2019, 08:21 PM   #12
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 14,003
Screws and fasteners are in a Milwaukee Packout organization box and bits are kept with the Makita 10.8v drills and a Milwaukee bit assortment box.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Bull Trout (09-19-2019)
Old 09-17-2019, 08:38 PM   #13
CityDecks's Avatar
Trade: Deck Builder
The drawers are great. I'll did up my plumbing kit. Thought and tried to go deep drawer with jig saw and deep drawer for router but after playing with it for few it worked out great by having the 2.0 batteries and there Mini charger that does 12v and 20v. Bug space saver. With 3- 2.0's I never run out.
Old 09-17-2019, 08:43 PM   #14
CityDecks's Avatar
Trade: Deck Builder
T... Plumbing kit.
Calidecks (09-17-2019)
Old 09-17-2019, 09:00 PM   #15
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 738
I use the Milwaukee stuff too...
"Your problem does not constitute an emergency on my part"
Little Giant Siding & Construction
Our face on the book
CScalf is online now
Old 09-17-2019, 09:07 PM   #16
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,613
Bits are a piece of cake compared to fasteners. For instance, I carry 4-5 different lengths of plain old deck screws, all of which take the same bit.
In my case, I have an ancient steel punchcard file cabinet in the van, and 1 lb boxes of screws and nails fit in the drawers quite handily. I wouldn't want to try putting that collection into plastic cases for toting into a house.
Tinstaafl is offline
Old 09-17-2019, 09:40 PM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 21,528
Mike.
_______________
Calidecks is offline
Old 09-17-2019, 09:47 PM   #18
LRG WoodCrafting
Leo G's Avatar
That's exactly what I do.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 09-17-2019, 10:15 PM   #19
Capra aegagrus
Tinstaafl's Avatar
I suspect I carry a considerably larger assortment than you, Leo. I can be working on cabinetry one day, decking the next, and plopping Tapcons anywhere in between. Structural lags, Redheads and whatnot.
Not to mention the electrical and plumbing stuff.
Old 09-17-2019, 10:22 PM   #20
LRG WoodCrafting
Leo G's Avatar
You need more Packouts then. Just bring in the one you need.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
