Best Rust Remover/Preventer For Metal - Tools & Equipment - Contractor Talk
Old 11-06-2016, 09:57 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
By keeping my tools in a pole barn, they take on rust.
Mainly surface rust. Bits & all sorts of various metal tools.
Other than basic "rust remover in spray can" -- suggestions?
Anything I can drop them in rather than doing individually?
artinall is offline
Old 11-06-2016, 10:12 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Best Rust Remover/Preventer For Metal
Submerge them in evaporust. Becareful if the tool has other non-ferrus parts are the stuff can damage certain materials.
Since I'm a sucker for Henkel products I'd spray on a little Maxi-Coat to prevent further rust. Just wipe it down the second you spray it or the coating will be really thick.
Inner10 is offline
Old 11-06-2016, 10:18 AM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,522
I have been cleaning up and "restoring" some old hatchets and axes recently.
Soaking in white vinegar works well and is inexpensive.
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 11-06-2016, 10:42 AM   #4
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 60
Cheap option
Defenestrate is offline
Old 11-06-2016, 11:14 AM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Fluid film will change the way you think about rust prevention forever...at least for me it did.
Best Rust Remover/Preventer for Metal-2012-superduty-055a.jpg
supersealconstruction.com
superseal is offline
The Following 4 Users Say Thank You to superseal For This Useful Post:
Eyeway! (12-04-2016), JAH (11-06-2016), rrk (11-06-2016), Tom M (11-07-2016)
Old 11-06-2016, 11:20 AM   #6
Inner10's Avatar
I'd really like to do a side-by-side between Maxi-Coat, Fluid Film, Krown, Rust Check, Rust Block and Corrosion Free.
Inner10 is offline
Old 11-07-2016, 09:18 PM   #7
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Originally Posted by Defenestrate View Post
I saw that a while back and checked pricing. $50k+!!
Rustbucket is offline
Old 11-08-2016, 06:14 AM   #8
bywater's Avatar
Trade: Country Contractor
Rewards Points: 38
I have the same problem with tools rusting. When we get to the time of year with cold nights and warm days the water will just condense on the tools inside the tool box. I found good old muratic acid from the hardware store works well. I just put an inch or two in the bottom of a plastic toolbox and let them soak for a half hour or so. Works great but leaves raw bare metal that will rust again in a second so paint or boiled linseed oil is a good idea afterwords.
bywater is offline
Old 12-02-2016, 11:02 PM   #9
G.C.
T.Overbey's Avatar
Rewards Points: 18
I've used Evapo-rust and Bullfrog rust remover, Bullfrog is pretty good, has an inhibitor to prevent 'flash rusting' after cleaning. I like the Evapo-rust better though.
I treat my tools with boiled linseed oil cut with a very small amount of turpentine. Use a very thin
coat and it'll harden up good. Doesn't take much, and I always have some around for finishing anyway
T.Overbey is offline
Old 12-03-2016, 08:32 AM   #10
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
for larger tools use a ****ter wax ring wipe it on then remove all of it you can.i do all of my cast iron table tops never rust. i have a shed full of old cast iron tools
pappagor is offline
Salt remover and rust inhibitor recomendations daniels_gt Sandblasting 13 05-10-2016 05:24 AM
Industrial Prep: Removing built up rust JakethePainter Painting & Finish Work 9 06-05-2014 07:20 AM
reappearing rust stains Diamond D. Masonry 9 07-17-2010 01:03 AM
