Best Rotary Laser 2019 - Tools & Equipment - Contractor Talk
Old 05-29-2019, 04:02 PM   #1
duburban's Avatar
Trade: building
Rewards Points: 1,772
Bosch, topcon, pls, other?
My Bosch 3 Axis split line just doesnít cut it outdoors at any distance.
duburban is offline
Old 05-29-2019, 06:33 PM   #2
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
Re: Best Rotary Laser 2019
I have a Bosch and it's great fr me.
The Hilti brand are supposed to be good but pricey.
dave_dj1 is offline
Old 05-29-2019, 06:38 PM   #3
tgeb's Avatar
Rewards Points: 420
Of those you listed, I'd take the TopCon.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
griz (05-29-2019)
Old 05-29-2019, 07:38 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 576
Topcon is a good choice so is Spectra.
This will no doubt turn into a Ford, Chevy, Dodge debate....
griz is online now
Old 05-29-2019, 10:01 PM   #5
duburban's Avatar
Trade: building
For my needs Iím in the sub $1000k range.
The topcon rl 5ha looks great.
400m is plenty of range.
Whatís up with the slopes? If I was cutting a 5% grade Iíd set it and just grade stake down a constant 4ish feet (standing height) to target grade?
I was into bosch lasers for a minute but their new top shelf is suffering in the reviews. The one with the automatic receiver finding.
duburban is offline
Old 05-30-2019, 12:26 AM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,796
Stabila Off Road, hands down.
Mike.
_______________
Calidecks is online now
Old 05-30-2019, 06:11 AM   #7
duburban's Avatar
Trade: building
Mike.
_______________
Just looking at the specs I see it has less range and a lower IP65 protection rating BUT they seem to be marketing this laser as something that can really take job abuse, are there other features that set it apart?
duburban is offline
Old 05-30-2019, 07:45 AM   #8
tjbnwi's Avatar
Rewards Points: 1,604
Does it have to be rotary? I have a 360ļ*fixed plane laser that uses a receiver.
tjbnwi is online now
Old 05-30-2019, 09:26 AM   #9
GC/carpenter
Calidecks's Avatar
Three things. Mine fell in a pool and worked fine after. The other is the last reciever has inches readout. So you can actually tell exactly how much you're off level. The third is the actual elevation rod. You can adjust the reciever up and down without loosening the reciever clamp. Little things but that's what's always the deal breaker. Imo.
Mike.
_______________
Old 05-30-2019, 06:38 PM   #10
duburban's Avatar
Trade: building
Tom,
I have a bosch 3 plane fixed red laser and it just doesnít have the range outside (even with receiver).
I did look for a rotary from the Beiter company Iíve seen you recommend. What do you like about that company? They do seem to have great value and accessories.
duburban is offline
Old 05-30-2019, 06:39 PM   #11
duburban's Avatar
Trade: building
Mike.
_______________
Fell in a pool! Thatís awesome, stabila would have bought that footage if you had it. That is worst case scenario second to being run over.
I didnít like the form factor but itís growing on me.
duburban is offline
Old 05-30-2019, 08:27 PM   #12
tjbnwi's Avatar
Tom,
What I really like is the three power options, all included in the kit I go. It sets up easily, can lock it for pitch work.
Accessories are very helpful.
tom
Old 06-01-2019, 01:59 PM   #13
duburban's Avatar
Trade: building
Man that stabila LAR 350 looks good!
What I like about it is the vertical point laser and the ability to use the unit in its side. Itís not perfect but this does open up some potential to square up large foundations and the like.
Has anyone found a good squaring laser for outdoors?
I see stabila has a la180 squaring laser but Iím not convinced it has more capability than my cheaper Bosch split line laser which canít really kick it outside at any range
duburban is offline
Old 06-02-2019, 06:55 PM   #14
duburban's Avatar
Trade: building
Anyone have a Hilti PR 30 ? Looks like the cats ass
duburban is offline
Old 06-04-2019, 08:24 AM   #15
duburban's Avatar
Trade: building
Check out this robot... incredible tech. Nice work hilti. If they could just make a drill that wasnít 8 miles long.
duburban is offline
Old 06-04-2019, 09:26 AM   #16
GC/carpenter
Calidecks's Avatar
Should be a good tool for 21k.
Mike.
_______________
Old 06-04-2019, 01:12 PM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 976
Yep.
It's great for sewer lines or drains as well.
Just set it for your 2% and go down the trench grading it out.
Old 06-07-2019, 12:33 PM   #18
tgeb's Avatar
Rewards Points: 420
I used my laser set @ 2% for some pipe work just this week.
www.gebcon.com
tgeb is offline
Seven-Delta-FortyOne (06-07-2019)
Old 06-09-2019, 09:07 PM   #19
duburban's Avatar
Trade: building
So I made a little splurge on the stabila LAR 350. I really wanted the Hilti pr 30 but it would cost $1000 more and not come with a stAnd and grade rod.
Iím going to start here but I feel like Iím buying old tech because of the red vs green laser.
Iím taking a breath and letting go of the red/green because Im really using this for as-built measuring for design work. I wonít be doing a ton of layout as thatís someone elseís responsibility.
Red or green I doubt Iíd be able to see the plumb dot when used in the vertical position.
The stabila LA180 May satisfy long range layout which I feel should be possible with laser tech instead of total station.
duburban is offline
Old 06-09-2019, 09:23 PM   #20
GC/carpenter
Calidecks's Avatar
That rod was a huge surprise. It's fantastic. Also the reciever is another awesome surprise.
Mike.
_______________
