Best Circular Saw Blades For Battery Life - Tools & Equipment - Contractor Talk
Old 11-17-2017, 07:02 PM   #1
MrCreosote's Avatar
Trade: Masonary
Rewards Points: 118
I don't care about cut quality on typical woods found in box stores (and the occasional older wood encountered in roofing and remodeling.)
I'm not sure if more teeth is harder on the battery... but I am sure the geometry of the cutting edge is definitely a player in battery life.
Or just buy a Diablo? Which one? (5-3/8in)
MrCreosote is offline
Old 11-18-2017, 08:55 PM   #2
Lettusbee's Avatar
Rewards Points: 1,498
Re: Best Circular Saw Blades For Battery Life
I've had good luck with Diablo, and the avanti brand does well for demo and framing work.
Lettusbee is online now
Old 11-18-2017, 11:36 PM   #3
IIISIGMAIII's Avatar
I have a ridgid gen5x (brushless model) cordless circular. And I just run a 24t blade. 60 and 4 tooth blades killed the blades but I also wasn't cutting wood so those were added variables.
IIISIGMAIII is offline
Old 11-19-2017, 02:52 AM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 492
5 3/8" ?? thats your problem right there. get a bigger and newer saw.
but thinner blades is generaly what you want. the diablos are fairly thin.
3bar is offline
The Following User Says Thank You to 3bar For This Useful Post:
SmallTownGuy (11-19-2017)
Old 11-19-2017, 07:54 AM   #5
SouthonBeach's Avatar
Rewards Points: 1,155
A blade that’s sharp.
SouthonBeach is offline
Old 11-19-2017, 09:08 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Thin kerf.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Old 11-19-2017, 09:19 AM   #7
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Brushless makes a HUGE difference, IF you are using a brushed saw.
Peter_C is offline
Old 11-20-2017, 12:15 AM   #8
Sisyphus's Avatar
Trade: Renovation and property management
Rewards Points: 1,027
More teeth slows the saw down, probably harder on the battery. I assume you'd want the minimum number of teeth engaged that will give you the desired finish.
Sisyphus is offline
Expensive diamond blades Windycity Masonry 18 06-28-2016 09:08 PM
Matching new blade to new circular saw. Darfyddi Carpentry 9 04-11-2016 08:05 PM
Saw blades. 3one5 Tools & Equipment 2 02-03-2016 11:47 AM
Wet saw blades lifestooshort81 Tiling 34 12-02-2012 12:43 AM
Bosch blades on Multimaster. rayh78 Tools & Equipment 4 10-18-2010 06:38 PM
