Beach No.1 Ceiling Mounted Scroll Saw. - Page 2 - Tools & Equipment - Contractor Talk
Old 12-19-2013, 12:11 AM   #21
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,824
Re: Beach No.1 Ceiling Mounted Scroll Saw.
Originally Posted by PrestigeR&D View Post
BS ~ 1/4" PRJ/3TPI
we OWWM stick together...
B.,
So I need to cut the blade, fish it through a hole then weld it back together on each one?
Yes, I realize I could make a cut through the top back of the corbel, but I don't wanna.
This will cut it just fine. It ain't no delta.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-19-2013, 12:14 AM   #22
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,345
Closed back. Bandsaw won't do it unless you have a penetration cut which will weaken the structure.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-19-2013, 12:18 AM   #23
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Lightbulb
BS!
You want a video...\\
(Chest pumping Arn)\\
Ill do it.....
no way on that machine,,,,,,,
not happening,,,,,,
BS ~ HANDS DOWN!
B, (patiently waiting for a response)..
PrestigeR&D is offline
Old 12-19-2013, 12:24 AM   #24
I like Green things
Ok, why can't the beach cut a 2" thick piece of wood to look like the picture posted?
Warner Mill Works
Facebook
YouTube
Old 12-19-2013, 12:27 AM   #25
Railman's Avatar
Trade: Railing
Rewards Points: 1,157
Warner,
You sure have a knack for finding interesting machines!
It looks like that thing has about an 8" stroke! The cut should clean out nicely on thick material as long as you get the right blade. I'm guessing maybe about 6 to 8 tpi on a 1/4" blade would be a good place to start?
Have fun!
Joe
Railman is online now
The Following User Says Thank You to Railman For This Useful Post:
WarnerConstInc. (12-19-2013)
Old 12-19-2013, 12:36 AM   #26
Railman's Avatar
Trade: Railing
http://books.google.com/books?id=olo...0Beach&f=false
Look at pages 139 & 140
Old 12-19-2013, 12:45 AM   #27
Wood Craftsman
Arrow
not going to happen.....
short blade .......
Frikin way..........
B.
Old 12-19-2013, 12:51 AM   #28
I like Green things
Just how short do you think the blade will be?
Warner Mill Works
Facebook
YouTube
Old 12-19-2013, 12:56 AM   #29
Railman's Avatar
Trade: Railing
short blade .......
B.
Why would the blade be short? The stroke apears to be about 8", which should clean out the thick cut nicely. That's close to what a normal hand saw stroke is.
Old 12-19-2013, 01:02 AM   #30
I like Green things
I am thinking my blades will be somewhere around 16" long.
Arbor runs at 825 rpm, that should get me 825 cutting strokes per minute, cut and return per revolution.
Seems like it will cut what I want easily. I guess I will find out.
Warner Mill Works
Facebook
YouTube
Old 12-19-2013, 01:05 AM   #31
Wood Craftsman
Arrow
D,
I just don't think its going to be a salubrious outcome......
B, (Tooth direction master),,...sometimes ~Bater)
Old 12-19-2013, 08:09 AM   #32
LRG WoodCrafting
Leo G's Avatar
Yee of little faith.
That's why you have a festivus tree.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Railman (12-19-2013)
Old 12-19-2013, 08:51 AM   #33
Railman's Avatar
Trade: Railing
Blade speed for 825 rpm = 6" stroke x 2 x 825 rpm = 9900" blade travel per minute , div by 12 = 825 ft per minute blade speed. My 30" Tannny bs is around 3,000 ft per min. ...800 should be reasonable. The trick will probably getting the right blade & tension right. I'd start with a bimetal blade, possibly a heavier ferous duty blade with good set, & ground teeth.
Since the stroke is extremely long I don't see why it won't cut anything less than the length of the stroke, say a 6" stroke on 4" material. A Sawzall uses around a 1 1/8" stroke to cut 1 1/2" material fairly easily, albeit not in an ideal motion.
A good while back, I had a guy that wanted to come to work for me. He told me he had invented a recipricating lumber mill, & that it worked really well. If he got it to cut, yours should also.
You could also fashion a blank blade with sandpaper glued ( or maybe clamped) to both sides to sand out the interior cuts. The outer cuts could be done on a ribbon sander.
Have you measured the stroke........on the saw?
Joe
Old 12-19-2013, 09:48 AM   #34
Wood Craftsman
Smile
I'm sorry if came across as being negative. I'll shut up......
I hope it works out for you D,
PS (Leave my festivus pole out of this)......
B,
Old 12-19-2013, 09:51 AM   #35
I like Green things
If it was an oliver he wouldn't think it couldn't do it.
Of course I would have probably parted it out then....
Warner Mill Works
Facebook
YouTube
Old 12-19-2013, 10:23 AM   #36
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 6,762
If that was the case after the table saw deal Brian might have made a visit to Indiana!
As an aside would it be possible to use a resaw blade?
Two other things:
Where do you find the time to work on these things and get work done?
How do you actually locate these things?
Deckhead is online now
Old 12-19-2013, 10:27 AM   #37
tjbnwi's Avatar
Rewards Points: 3,986
Carvex, use the long blade, cut from both sides to make the corbels.
tjbnwi is online now
Old 12-19-2013, 10:29 AM   #38
I like Green things
While I don't doubt it would work, I am not making corbels for a 1868 farm house with my carvex.
They are only 2 1/2" thick.
Warner Mill Works
Facebook
YouTube
Old 12-19-2013, 10:32 AM   #39
tjbnwi's Avatar
Well then you only need to cut from one side.
(My first post was a meant to be a joke.)
If you we're closer I'd be asking to use one of your band saws. I'm going to end up modifying my horizontal to do some vertical work. Guess I should really go look at band saws.
Old 12-19-2013, 10:35 AM   #40
I like Green things
Two other things:
I can use whatever kind of blade I want, I am going to have to make them from bandsaw blade stock anyways. A course blade will require more sanding though.
I am doing some shop work so I fiddle with it a little during the day and then hit it hard after dinner until about midnight.
I have my sources to find these things.
Warner Mill Works
Facebook
YouTube
Crack at Peak in vaulted Ceiling Milhaus Drywall 21 11-04-2013 09:44 AM
Temporary Rafter Support for Clipped Ceiling TLyon Remodeling 17 09-12-2013 11:22 PM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 27 02-26-2012 11:01 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
3-way wiring- ceiling fan with remote for two-wire hookup hevnbnd Electrical 29 08-17-2009 10:28 PM
