Apron/Block Plane For Trimming And Miter Relief - Suggestions? - Tools & Equipment - Contractor Talk
Old 04-25-2015, 07:45 AM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
I've never used a plane. Just a tool I never purchased. I know a lot of guys use them with trim carpentry, specifically for relieving miters on casing.
Any recommendations?
Do you use a plane for anything while trimming?
Spencer is offline
Old 04-25-2015, 07:54 AM   #2
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,736
Re: Apron/Block Plane For Trimming And Miter Relief - Suggestions?
I like the Lie Nielson bronze #102 block plane. When running trim it lives in my vest and when I wore Oxy bags it lived in the leather hammer loop. I use it for relieving miters, changing miter angles, tweeking a scribe line, fitting rail parts, and about a hundred other random things.
Their rabbet block plane is also very useful but is a bit large to fit in my vest.
Justin Huisenga is offline
The Following 3 Users Say Thank You to Justin Huisenga For This Useful Post:
BlueRidgeGreen (04-25-2015), M.F Custom (01-06-2018), mikeswoods (04-26-2015)
Old 04-25-2015, 08:08 AM   #3
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 3,846
The Nielsen 102 is absolutely perfect....for the work you are describing.
But.....if I only had one block plane, that wouldn't be the one.
As a second dedicated light trimming plane it is unbeatable, but without an adjustable mouth, it is just too limiting to be my only block plane.
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is offline
Old 04-25-2015, 08:34 AM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 814
Great question Spencer! I also am curious. I have an old Stanley that gets used very little.
overanalyze is online now
Old 04-25-2015, 08:46 AM   #5
tjbnwi's Avatar
Rewards Points: 4,084
I like the Collins Bunny planes (I have a Stanley that the 102 is copied after). Just one of those things, they're so damn convenient to use.
tjbnwi is offline
Justin Huisenga (04-25-2015)
Old 04-25-2015, 10:03 AM   #6
Texas Wax's Avatar
Rewards Points: 1,770
The daily 'driver' is a stanley, probably 15 years old. Saved big money
Don't matter how fancy, how expensive, if they aren't sharp they don't work. Especially for reliefs on hardwood miters.
Belt sander is not sharpening it's abuse
Texas Wax is offline
The Following 4 Users Say Thank You to Texas Wax For This Useful Post:
Jswills76 (04-25-2015), Justin Huisenga (04-25-2015), m1911 (04-26-2015), overanalyze (04-25-2015)
Old 04-25-2015, 11:04 AM   #7
Joemack1's Avatar
Rewards Points: 382
Another vote for the lie Nelson block plane. I started out with a cheap Stanley and once I realized how much I needed it I upgraded to lie Nelson.
Joemack1 is offline
The Following User Says Thank You to Joemack1 For This Useful Post:
Old 04-25-2015, 12:14 PM   #8
hdavis's Avatar
Rewards Points: 4,260
Yes, learn how to evaluate, tune, and sharpen a plane in theory before you buy. Then walk through it all on the plane you buy.
hdavis is offline
Old 04-25-2015, 12:21 PM   #9
Hack
asevereid's Avatar
Rewards Points: 424
I use a Stanley 60 1/2 adjustable throat block plane.
Doesn't quite fit in my pocket, but it's in my bag.
I keep a sharpening kit in the truck to keep the edge keen.
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
Old 04-25-2015, 12:23 PM   #10
hdavis's Avatar
I'm not sure why that is - you're just taking thinner slices all the time vs thinner and thicker. If I need a health trim, I usually use a chisel (wielding it like a slick) and fine tune with the plane.
hdavis is offline
Old 04-25-2015, 02:49 PM   #11
Jswills76's Avatar
Trade: custom carpentry
Rewards Points: 836
I have more planes then I know what to do with but the ones I carry are a marples 60 1/2 and a record 102.
Jswills76 is offline
Old 04-25-2015, 04:20 PM   #12
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
I always have this small block plane for baseboard. Or pretty much anytime I'm doing trim and my workstation is more than 20' away.
mgb is offline
Old 04-25-2015, 05:56 PM   #13
Spencer,
Here are the ones I keep either on me, close to me, or in the van and their uses. Most are small or specialty planes. Many don't get a ton of use but when needed there is no substitute. They do the job better than a power tool for their intended purpose. I've never gotten into bench planes as for the most part I prefer to let power tools do the heavy lifting.
Lie Nielson 102. I've tried the Veritas apron plane but the Lie Nielson feels more natural in my hand. That's a big factor in choosing what you will use/purchase. Physically lay hands on them if possible.
Stanley 60 1/2 low angle and 9 1/2 standard angle. Low angle is best in end grain and standard works best on edge grain. Both are tuned up and sporting Hock irons. Adjustable mouths to take a larger bite if needed. I usually just use the 102.
Collins Bunny planes. Useful for fairing details on scarf joints and rail fittings.
Large spoke shave and small spoke shave. Also useful for rail fittings.
Rumbold butt plane. Useful for tweaking hinge mortises and random hardware. I'm too slow to hang doors efficiently with it.
Lie Nielson rabbeting block plane. Tweaking rabbets for a good fit or planing right up to an edge. Also very nice as a straight block plane.
Stanley 92 shoulder plane. Also works on rabbets but I keep it around because I can split it in half to use as a chisel plane to get into a corner.
Lie Nielson #95 edge plane. I can clean saw marks off a board edge faster than I can sand them off. There's a learning curve to this one but once you figure out how to set the skew on the iron and use it it's a time saver.
In my door box I also have a Lie Nielson butt plane and a Veritas version of a 171 small router plane for screwing with hardware.
If you get into planes you are going to need a means to sharpen them and learn how to do it otherwise they will just end up as cool looking paper weights.
Apron/Block plane for trimming and miter relief - suggestions?-planes.jpg
The Following 10 Users Say Thank You to Justin Huisenga For This Useful Post:
asevereid (04-25-2015), AustinDB (04-29-2015), kwunch (04-25-2015), M.F Custom (01-06-2018), m1911 (04-26-2015), overanalyze (04-25-2015), Philament (01-06-2018), Railman (04-25-2015), Spencer (04-25-2015), Xtrememtnbiker (04-25-2015)
Old 04-25-2015, 06:17 PM   #14
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 318
And what means is that Justin? I'm following all this because I have never used a plane.
I was gonna email you and ask you how you sharpen them, but then no one else would benefit from it.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 04-25-2015, 06:26 PM   #15
tjbnwi's Avatar
He hand hones and polishes his irons, never lets them get bad enough to use a grinder. I'd say he's kinda anal, but the kinda would be incorrect.
All of his cutting tools are scary sharp, which makes them very safe.
tjbnwi is offline
Old 04-25-2015, 06:28 PM   #16
Rewards Points: 318
I've never sharpened anything I own really. Sent saw blades to be sharpened.
Just got some nicer chisels and need to learn how to sharpen them.
Old 04-25-2015, 06:36 PM   #17
tjbnwi's Avatar
The DVD is about an hour and fifteen minutes.
tjbnwi is offline
Old 04-25-2015, 06:54 PM   #18
Livin the dream...
Spencer's Avatar
I have no problem dropping money on tools, but for some reason I have a hard time dropping $115 for a block plane. I guess I've just never used one so I'm wondering where I'm really going to use one.
What applications do you use a block plane in most for on site finish carpentry?
Spencer is offline
Old 04-25-2015, 06:58 PM   #19
You're gonna start a fight with that question
For the first grind on a chisel or iron I hollow grind it on a low speed wet grinder. I used to use a regular bench grinder but it's too easy to over heat and burn the edge. If you see a purple/black scorch mark you've just screwed up the temper and it won't hold an edge right. I then use a double sided Jap stone to flatten the back and hone the cutting edge. I used to do this freehand but recently purchased a Veritas honing guide to make it a bit easier and faster. I then go to a leather and plywood strop charged with stropping compound to polish the edge and back to a mirror finish. When I'm done I can shave with it without pulling hair. There are other techniques but I like these.
Unless I truly screw the edge I don't go back the grinder just the stone and strop on nicer tools. Tom's right the sharper the tool the safer it is. The only time I've ever sliced myself up is when something was dull.
What chisels did you get?
Old 04-25-2015, 07:11 PM   #20
tjbnwi's Avatar
The other day I had to back plane miters to get the joints to fit. They were cut on an out of calibration (not mine, not by me) miter saw, only pieces left so they had to be fitted.
Back side of baseboard on out side corners at times. Back planing an edge to get a good show side........
tjbnwi is offline
Miter saw aside from Kapex or dewalt Designed2Fail Tools & Equipment 17 02-16-2014 10:16 PM
Excellent use for old miter saw blades ThisCarpenter Tools & Equipment 53 04-15-2013 08:47 PM
New Saw! key-ok Tools & Equipment 16 02-18-2013 09:29 PM
Jack Miter Jig basswood Finish Carpentry 35 07-03-2010 11:27 AM
Miter folding with a cnc machine Gus Dering Finish Carpentry 35 11-30-2009 07:10 PM
