400' Laser - Tools & Equipment - Contractor Talk
400' Laser
Old 04-30-2012, 07:09 PM   #1
txgencon's Avatar
Rewards Points: 432
400' Laser
Looking for something that will shoot a laser up to 400'. Doesn't have to have a level feature. I just want it for setting fence posts. It would be nice if it would mount on a tripod but even that isn't an absolute must have. Any ideas?
txgencon is offline
Old 04-30-2012, 07:25 PM   #2
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
Re: 400' Laser
It sounds like you're looking for a laser range finder.
http://www.amazon.com/b?ie=UTF8&node=162019011
J L is offline
Old 04-30-2012, 07:31 PM   #3
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 606
Re: 400' Laser
you need a exterior laser, ck out bosch, dewalt, these are a whole lot easyer to see in that tx sun, miss lower greenville ave and deep elum!!!!!!!!!!!!!, frank talbots chille parlor on ceder creek,
sunkist is offline
Old 04-30-2012, 07:54 PM   #4
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 926
Re: 400' Laser
I think you will need a "Green Beam" for what you propose to do.
http://www.davidwhite.com/Laser_tools/483150G_1.html
I've never used one but as I understand they are more visible in daylight.
The one I refer to is capable of horizontal and vertical positioning.
www.gebcon.com
tgeb is offline
Old 04-30-2012, 07:57 PM   #5
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
Re: 400' Laser
water level
world llc is offline
Old 04-30-2012, 07:57 PM   #6
I'm on a boat!
J L's Avatar
Re: 400' Laser
Are you trying to measure out to 400' or are you trying to use it for a straight line? I'm kind of confused
J L is offline
Old 04-30-2012, 07:59 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: 400' Laser
i think he just needs a straight line..?
Tom Struble is offline
Old 04-30-2012, 08:00 PM   #8
txgencon's Avatar
Rewards Points: 432
Re: 400' Laser
I only want it for placement, no measurement capability needed. Basically, a replacement for piano wire.
txgencon is offline
Old 04-30-2012, 08:00 PM   #9
tgeb's Avatar
Rewards Points: 926
Re: 400' Laser
Originally Posted by txgencon View Post
I just want it for setting fence posts........ Any ideas?
He wants to set fence posts, needs to layout a strait line.
www.gebcon.com
tgeb is offline
Old 04-30-2012, 08:01 PM   #10
Trade: siding
Rewards Points: 20
Re: 400' Laser
whatever,i'm sure you would need a detector?
Old 04-30-2012, 08:02 PM   #11
Chuck
S.R.E.'s Avatar
Trade: Excavating, Clearing, Underground Utilities
Rewards Points: 506
Re: 400' Laser
A Pipe laser would work great. Cost might be an issue though.
http://www.topconstore.com/content/t...ser-green-beam
S.R.E. is offline
Old 04-30-2012, 08:04 PM   #12
tgeb's Avatar
Rewards Points: 926
Re: 400' Laser
If he works the fence third shift, any laser would be just fine.
www.gebcon.com
Last edited by tgeb; 04-30-2012 at 08:06 PM. Reason: Might have to replace his eyeballs twice a week, but....
tgeb is offline
Old 04-30-2012, 08:11 PM   #13
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: 400' Laser
The S3 krypton has a 85+ mile range. Im sure you could see that in the daylight. Must be a way to mount it to a tripod.
www.bcconstructionllc.com
BCConstruction is offline
Old 04-30-2012, 08:14 PM   #14
sunkist's Avatar
Rewards Points: 606
Re: 400' Laser
400 ft of piano wire gez how big is them texas pieano,s
sunkist is offline
Old 04-30-2012, 08:23 PM   #15
txgencon's Avatar
Rewards Points: 432
Re: 400' Laser
It comes on spools of 1000' just for the purpose I mentioned. You can pull it so tight it will have neglibible sag even at 500 feet. Also, it isn't affected much by wind. But it's a tad dangerous and you don't dare leave it up unattended for fear of someone walking into it. Hell, it's hard to stay off of it even if you're the one who stretched it. (BTDT)
A string would work for my application if it weren't for the wind.
txgencon is offline
Old 04-30-2012, 09:07 PM   #16
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Re: 400' Laser
Stick with the piano wire. The laser will just get obstructed with trees, leaves, legs, and leaning posts.
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
Old 05-01-2012, 09:11 AM   #17
Kgmz's Avatar
Re: 400' Laser
Get a rotary laser with the laydown feature. You can tell if it has this if it has a threaded hole in the side for the tripod mount, same as on the bottom. Next set the laser so it is shooting a beam about a foot away from your fence line. Get a short rod and the laser detector and measure both ends, adjust the laser as needed so distance is the same at both ends of fence line.
This way posts are not in way of beam, you can measure with detector at any height since it is a rotary and the beam is everywhere in the verticle line. And since it is a rotary laser the ground does not have to be level and can have a hill on it as long as the laser is on top of the hill, the beam covers everything in its verticle range limit.
Kgmz is offline
Old 05-01-2012, 09:30 AM   #18
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Re: 400' Laser
I have a hilti laser with a tripod.
The tripod is nice mine is from 4' to like 7' or something. You can get one that goes up to 12' tall. Has some spikes u can sink into the dirt too.
I have the interior laser but u can get the green one with the finders.
The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory. - Aldo Gucci
Rich D. is offline
Laser repair? Warren Tools & Equipment 12 03-19-2012 08:12 PM
Retrofitting Bosch Glide with a laser PPRI Tools & Equipment 37 12-17-2011 12:53 PM
rotary laser NjNick Tools & Equipment 5 11-14-2010 06:09 PM
Buying my first SCMS ... Laser VS. non Laser model? Yankee Bill Tools & Equipment 8 05-31-2010 09:20 AM
Laser Screeds tchawks81 Concrete & Paving 0 11-24-2008 01:02 PM
