3 Hp Router - Page 2 - Tools & Equipment - Contractor Talk
3 Hp Router
Old 12-08-2016, 07:40 PM   #21
tjbnwi's Avatar
Rewards Points: 3,484
Re: 3 Hp Router
Here is the picture of the MFS I was referring to in the PM.
Note the reference blocks. They're there incase I had to reset the MFS. Had to "move" the slot to where the red tape is to the upper left.
tjbnwi is offline
Motor (12-08-2016)
Old 12-08-2016, 09:36 PM   #22
Juan80's Avatar
Trade: General contractor
Rewards Points: 496
Re: 3 Hp Router
Tom,
You do some cool ****.
Thanks for your posts.
Charlie
Sent from my iPad using Tapatalk Pro
Juan80 is offline
Old 12-08-2016, 10:09 PM   #23
tjbnwi's Avatar
Re: 3 Hp Router
Originally Posted by Juan80 View Post
Tom,
Charlie
Thanks.
This is what happens when the architect and client do not communicate.
Finished product.
tjbnwi is offline
hdavis (12-09-2016)
Old 12-08-2016, 10:23 PM   #24
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,082
Re: 3 Hp Router
Originally Posted by tjbnwi View Post
Thanks.
Finished product.
I saw when you originally posted that and I was impressed. I hope you got compensated accordingly.
Inner10 is offline
Old 12-08-2016, 10:45 PM   #25
tjbnwi's Avatar
Re: 3 Hp Router
Damn right I did.
tjbnwi is offline
Old 12-09-2016, 06:29 AM   #26
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
Re: 3 Hp Router
That's the first I've seen of the MFS jig. I could find so many uses for it but I learned it's discontinued.
J L is offline
Old 12-09-2016, 06:33 AM   #27
Motor's Avatar
Rewards Points: 60
Re: 3 Hp Router
Tom,
Charlie
Very cool!
Motor is offline
Old 12-09-2016, 02:20 PM   #28
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: 3 Hp Router
I wanted to buy an MFS right as they were discontinued, but couldn't justify spending that much $$$ at the time, and still can't for some aluminum extrusions.
Here is an MFS 700 if someone wants it.
https://www.amazon.com/Festool-49261.../dp/B000BWFWP0
There are ways around it though. Acrylic can be cut and using double stick tape does a similar thing to the MFS. You can glue a second sheet of acrylic on top then use a follower bit to create any size of box you want that is movable. This allows one to do repairs on solid surface such as Tom performed above. My friend creates a jig on the CNC which also does the same thing. The MFS's biggest benefit is the scales etched into it and the ease of setting up any dimensions within it's range.
One of my favorite things about solid surface is the ability to repair it like no other counter top material. With a professional like Tom doing the repairs you literally never see it without someone pointing out the lines Of course scratches that would leave most counter tops ugly can be quickly sanded right out of a solid surface one.
Edit: This is a reasonable price for aluminum extrusions with numbers. Has both standard and metric systems. Although not as nice as the MFS it should function well enough. Router support on the cutting side might come into play and it look like they make a shoe for the router base.
https://www.amazon.com/Trend-VARIJIG.../dp/B001UQ5PDK
Vids in this one.
http://www.dm-tools.co.uk/product.ph...G#.WEsGxJLz1aU
Write up on the Trend Varijig
http://www.woodworkingcafe.com/forum...-Trend-VariJig
Peter_C is offline
Old 12-09-2016, 06:05 PM   #29
tjbnwi's Avatar
Re: 3 Hp Router
When they announced they were discontinuing the MFS I ordered a few more. Nice to have multiple pieces and sizes.
tjbnwi is offline
Peter_C (12-09-2016)
Old 12-09-2016, 07:15 PM   #30
I'm on a boat!
J L's Avatar
Re: 3 Hp Router
I'm sure it is
J L is offline
Old 12-09-2016, 07:39 PM   #31
I'm on a boat!
J L's Avatar
Re: 3 Hp Router
Vids in this one.
I do a lot of custom sized cut outs - typically for the plywood on the back of TV's we mount on vessels. Ideally they have radius inside corners. That means a square jig and a pattern bit. But all of the cut outs are different sizes for different situations.
I may be interested in the varijig. From what I've read the scale is on the middle of the extrusion so it doesn't really help you for exact measurements. I could deal with that.
Have you purchased any extrusions or do you still use shop build jigs?
J L is offline
Old 12-10-2016, 01:59 AM   #32
Peter_C's Avatar
Rewards Points: 412
Re: 3 Hp Router
I typically use strips of acrylic put down with double stick tape. If it wasn't for the cost I would have bought the MFS. At some point I think I am going to go ahead and order the Varijig and give it a try. Almost seems like it is being discontinued. Bummer I missed the $35 dollar blowout at Sears.
The quality seems okay, but I don't like how narrow the rails are. The router only touches the part where the tape measure is as the outboard sides are lower. Wish they made a filler strip for the outside part of the rails at least. So not nearly as stable as the Festool version, which has a wider deck for the router to ride on. This is overcome by using the foot on the router. As to adjustments if you look closely at the edge there is a gap to the ruler part. It appears fairly small, but is present none the less. Maybe a straight edge would help set the width accurately?
Peter_C is offline
Old 12-10-2016, 06:33 AM   #33
I'm on a boat!
J L's Avatar
Re: 3 Hp Router
Could it be used upside down to get a larger router surface? It looks like the bottom is flat the entire width. You could run into an issue with the bearings on a pattern bit but you'd just have to be aware of that.
J L is offline
Old 12-10-2016, 12:56 PM   #34
Peter_C's Avatar
Rewards Points: 412
Re: 3 Hp Router
These weren't really designed to use a bearing-ed bit, and the guide bushing can ride on either side, so flipping it wouldn't be an issue in that regard. If you can clamp it up, it should work. Trend does sell clamps that are designed to work with the Varijig and only slide into the bottom. Woodcraft has the clamps on sale, and they can be had from Amazon too.
https://www.amazon.com/Trend-CK-Vari...YN0NYSE4SAS9A0
https://www.amazon.com/gp/product/B0...A3BUJ4ZPESQSK2
http://www.woodcraft.com/product/152...clamp-kit.aspx
Another option would be to use some 1/8" aluminum and since the extrusion is 1/4" slots, you can just use nuts (t-slot if desired) and bolts to hold something like a 1" wide strip of aluminum on the outside edge to fill it in, thereby giving 2" of material support.
Peter_C is offline
Old 02-23-2017, 06:21 AM   #35
Motor's Avatar
Rewards Points: 60
Re: 3 Hp Router
Originally Posted by Motor View Post
Buying a 3hp router for plowing stair stringers and other heavy duty work. (Have several intermediate power routers.) Anyone have a recommendation? I'm considering the Festool 2200 but wondering if it's worth the coin.
As a follow up to this I bought a Festool 2200 router and just routed my first set of stair stringers yesterday. The 2200 is an awesome router and I highly recommend it for anyone doing this kind of work.
Motor is offline
The Following 3 Users Say Thank You to Motor For This Useful Post:
GregB (02-26-2017), J L (02-23-2017), Peter_C (02-23-2017)
Portable work table with router plate at HD platinumLLC Tools & Equipment 3 04-01-2016 08:30 AM
Looking for CNC Router for woodcarving recomemdations donschaeffer New Member Introductions 3 05-31-2013 05:31 PM
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
Router talk....101..... PrestigeR&D Tools & Equipment 94 12-16-2012 10:58 PM
