Zero Clearance Construction - Construction - Contractor Talk
Old 08-06-2010, 02:33 PM   #1
SantaFeSam's Avatar
35 Years in the business and I need help. I am about to design a two story residential building "adjacent" to a preexisting building. The new building will have a "new" exterior wall that is up against the existing wall and two stories high. How is this done? I am thinking someone is going to send me one of these "smilies" characters as an answer.
Of course a tilt up pre-finished wall would do the trick but is that the only way?
Any chance you could e-mail me direct until I get used to this forum? [email protected]
SantaFeSam
SantaFeSam is offline
Old 08-06-2010, 03:17 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,990
Re: Zero Clearance Construction
Don't know where you are located, but out here there would be a tremendous amount of firewall involved. Your engineering, code & design will probably dictate to you how the walls will be built. You seem to be doing just fine on the forum. Good Luck
griz is online now
Old 08-06-2010, 03:30 PM   #3
Rewards Points: 2,000
Not quite "zero," huh?
Maintenance, impossible.
Appearance, invisible.
Masonry is your answer.
neolitic is offline
Old 08-06-2010, 03:47 PM   #4
Anti-wingnut's Avatar
Rewards Points: 3,414
I have a guess!
Anti-wingnut is offline
The Following 3 Users Say Thank You to Anti-wingnut For This Useful Post:
griz (08-06-2010), PA woodbutcher (08-07-2010), Willie T (08-06-2010)
Old 08-07-2010, 11:51 AM   #5
SantaFeSam's Avatar
To those of you have replied to my inquiry - Thank You. It seems that all say- Masonry wall for zero clearance wall. Makes sense but expensive. By the way SantaFeSam is from "would you believe" Santa Fe, New Mexico. Come see us you will love it.
Old 08-07-2010, 12:22 PM   #6
PA woodbutcher's Avatar
Rewards Points: 1,000
Went though Santa Fe last month. A different sort of beautiful in an eastern sort of way Lots of brown though.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 08-07-2010, 10:45 PM   #7
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Round here all 0 clearance is concrete filled cinderblock
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Old 08-08-2010, 05:38 AM   #8
Joasis's Avatar
Rewards Points: 4,218
In your application, what else would you expect? Concrete, CMU, or even an ICF wall is about the only way.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
Old 08-08-2010, 06:02 AM   #9
Dan
ApgarNJ's Avatar
Concrete block all the way up would be good but then you'd be cutting it to match the roof pitch at the attic. is the roof pitched or flat? assuming it's pitched with residential.
What surface are you butting up against? If the roofs are being connected, then no weather should be getting there. Find out your fire wall codes in your area and maybe the existing has to be covered with a few layers of 5/8 rock then framed against, then connect the roofing and there will be no reason to access that area and maintain it, because it's not exposed.
ApgarNJ is offline
Old 08-08-2010, 06:23 PM   #10
Thom
thom's Avatar
Rewards Points: 4,748
pretty standard townhouse construction.
Must first assume that the existing building was constructed for this, with a rated exterior wall. If so, leave a 1" gap between buildings, frame and sheathe the outside of the wall with 5/8 before standing up. If you use platform construction, you must also rock the band with 5/8. Oftentimes the common wall is balloon framed, rocked, fire-taped, then stood up.
At the top, you will need a parapet with a common cap flashing.
thom is offline
New Construction Miller Painting & Finish Work 17 03-20-2011 01:44 PM
19 year old to make money in construction? supwd Business 56 08-07-2010 01:15 PM
Software- Construction Management Feedback modterry Business 5 12-16-2009 09:57 AM
CCD - and construction image Mike Finley General Discussion 6 08-31-2007 08:37 AM
