Wood Foundations - Page 5 - Construction - Contractor Talk
Wood Foundations
Old 05-02-2019, 01:00 PM   #81
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Wood Foundations
Originally Posted by hdavis View Post
I actually get to have my say, critics or no.
As for wood foundations and pilings, pilings are used for foundations all the time. If they're wood pilings, it's a wood foundation. Simple stuff. It's how and where wood is used that makes a difference.
I think only a few here have worked with PT exterior plywood, marine plywood (no PT), and just plain old plywood with exterior rating in marine applications. That's some practical experience.
Back to plywood again, are ya?
In other words, you have no practical experience with foundations, wood or otherwise. Just lots of Air Theory.
SmallTownGuy is offline
Old 05-02-2019, 01:19 PM   #82
hdavis's Avatar
Rewards Points: 2,488
Other than stone, brick, block, poured concrete, floating wood and padstone? No, no experience.
hdavis is online now
Old 05-02-2019, 01:32 PM   #83
John the Builder
right....
Old 05-02-2019, 07:44 PM   #84
TimNJ's Avatar
Rewards Points: 5,700
Let me just throw this into the argument.
About 10 years ago I bought 6X6's rated for direct burial and used them to build wife a raised garden bed.
Last year there was a huge nest of ants coming out of the ground along side one of them.
I went to dig up some of the ground to pour ant chemicals on them.
When I hit the side of the 6X6 that was below grade the shovel went right into it. It was all starting to rot and the ants were nesting in it.
Found a tag on one of the 6X6's that said "Lifetime Warranty".
I googled the company to contact them and they had declared bankruptcy. So, what happens if the company that supplies your wood cheats and then goes bankrupt?
Now just to be fair, I read somewhere months ago that around CT, RI, or MA, there was bad concrete that went into a massive amount of poured foundations. So I guess if the pressure treating company can cheat, so can the concrete company.
TimNJ is online now
Old 05-02-2019, 08:20 PM   #85
META's Avatar
Trade: General and Trades
Rewards Points: 5,880
My brother in law had the same thing happen to some big box treated lumber he used to build raised garden boxes. Was junk in a couple years.
META is online now
Old 05-03-2019, 11:24 AM   #86
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Well,unlike the wood failure surprise down the road,each and every truckload of concrete could be tested at independent labs.,to insure the concrete meets the required design parameters. Most commercial jobs require it and I highly recommend it for residential work as well. Doing so,will catch a problem BEFORE you pile a quarter of a million dollars worth of labor and material on top of a defective foundation.
fjn is offline
hdavis (05-03-2019)
Old 05-03-2019, 02:15 PM   #87
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,028
It was the aggregate IIRC, something about it having some mineral in it that reacts over time and degrades the integrity of the concrete. So it wasn't even the concrete company cheating, but an unforseen problem that nobody had experienced before and so didn't even know to test for.
If I got that wrong, please correct me!
SPG is offline
The Following User Says Thank You to SPG For This Useful Post:
TimNJ (05-03-2019)
Old 05-03-2019, 02:48 PM   #88
hdavis's Avatar
Most of the PT lumbet I see in big boxes is junk, and all the local yards witches to the same cheap source. Anything good is a special order now.
Old 05-03-2019, 04:31 PM   #89
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
Wood meant for wood foundations has a very high level of the older good CCA stuff and must be specifically stamped for use in wood foundations. It isn't anywhere close to the crap the box stores sell.
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
hdavis (05-04-2019), META (05-05-2019)
Old 05-03-2019, 05:25 PM   #90
TimNJ's Avatar
That sounds right. So then it wasn't a concrete company cheating.
Thanks for that.
Feel sorry for all those homeowners though.
TimNJ is online now
Old 08-19-2019, 02:25 AM   #91
prorabnn's Avatar
Trade: agross
Rewards Points: 8
Good day. I saw your argument. In the photo there are 2 buildings. Alexander Nevsky Cathedral in Nizhny Novgorod, year of construction 1866 and Alexandria Column in the city of St. Petersburg, year of construction 1834. Both of these structures stand on a wooden foundation. For the foundation, oak logs, previously soaked in water, were used. The foundation was made of oak. It is better to connect logs with a wooden dagger (in the photo). In Russia, itís cheaper to make a foundation of concrete. 1 cubic meter of concrete costs $ 50; a cubic meter of oak is approximately $ 200. Convenience and durability on the concrete side.
Wood Foundations-.jpg   Wood Foundations-drevo78-ispolzovanie-nagelei-ris-2-1024x486.png   Wood Foundations-107.jpg
prorabnn is offline
The Following 4 Users Say Thank You to prorabnn For This Useful Post:
hdavis (08-19-2019), Idothat (08-19-2019), META (08-26-2019), Rio (08-19-2019)
Old 08-19-2019, 09:12 AM   #92
Designer/Contractor
Rio's Avatar
Rewards Points: 524
If it's cheaper to make the foundations for those beautiful reasons out of concrete why do you think they were made out of wood?
Rio is online now
Old 08-19-2019, 09:17 AM   #93
prorabnn's Avatar
Trade: agross
Rewards Points: 8
when they built a church and a column, concrete and reinforcement were not invented. currently cheaper and easier to build from concrete
prorabnn is offline
The Following User Says Thank You to prorabnn For This Useful Post:
Rio (08-19-2019)
Old 08-19-2019, 09:54 AM   #94
hdavis's Avatar
Thanks for the oak log foundation detail.
Leveling wood subfloor - engineered wood buckling Al11 Flooring 5 08-16-2016 06:22 AM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
Permanent Wood Foundations SteelCity Construction 4 05-13-2008 03:26 PM
