Wood Foundations - Page 2 - Construction - Contractor Talk
Wood Foundations
Old 04-13-2019, 07:22 PM   #21
META's Avatar
Trade: General and Trades
Rewards Points: 3,074
Re: Wood Foundations
Originally Posted by fjn View Post
Originally Posted by META View Post
Interesting..
I should look into that.
This is just one of several a good friend ,boat enthusiast and engineer shared with me.
https://www.boatus.com/seaworthy/mag...less-steel.asp
So, we need to look into comparisons between stainless and galvanized fasteners in low oxygen environments.
META is offline
Old 04-13-2019, 07:32 PM   #22
fjn's Avatar
Trade: mason
Rewards Points: 10,498
The trouble with galvanized in both of our field is that all it takes is to nick the coating off one spot and Wham,there is the chink in the armor.
I often wondered at the logic of hitting the head of a galvanized nail with a hammer. The very spot closest to the weather now is left vulnerable.
fjn is offline
SmallTownGuy (04-14-2019)
Old 04-13-2019, 08:08 PM   #23
META's Avatar
Theoretically, the bigger concern on wood foundations may be the lumber treatment and how it reacts to the fasteners, being in a perfect world, the outer vapor barrier should be keeping fasteners dry.
Regarding galvanized fasteners being compromised during application, that is also similar to the damage on GRKs, and other coated screws when being driven.
META is offline
Old 04-13-2019, 11:47 PM   #24
Designer/Contractor
Rio's Avatar
Rewards Points: 1,708
Wow, great article, very informative.
Rio is online now
Old 04-14-2019, 02:55 PM   #25
fjn's Avatar
Trade: mason
You know Rio; I found that article very informative and also very scary ! In the masonry field,stainless steel has been kinda projected as the belt and suspender approach for masonry anchors. It looks like in reality,it could be one of the least viable materials to use.
As I previously stated,I would definitely classify an anchor embedded in mortar to be low oxygen.
fjn is offline
Old 04-14-2019, 03:38 PM   #26
Designer/Contractor
Rio's Avatar
I know, it really came as a surprise to me and now I wonder what, if anything, would be a belt and suspenders fastener?
Rio is online now
Old 04-14-2019, 03:49 PM   #27
fjn's Avatar
Trade: mason
Boy,you are not kidding.
fjn is offline
Old 04-14-2019, 04:21 PM   #28
Designer/Contractor
Rio's Avatar
Thinking maybe back to hot dipped galvanized?
Rio is online now
Old 04-14-2019, 04:43 PM   #29
META's Avatar
Kind of why we need to see some real world studies between the two, IMO.
META is offline
The Following 3 Users Say Thank You to META For This Useful Post:
fjn (04-15-2019), Fouthgeneration (04-15-2019), Rio (04-14-2019)
Old 04-16-2019, 12:41 AM   #30
Sisyphus's Avatar
Trade: Renovation and property management
Rewards Points: 957
.... I found that article very informative and also very scary ! ....
Scary was the first thought I had too. I've been relying on stainless steel clamps and fasteners in underground (and other) locations for years. I'd hate to have to pull up a well because a clamp or foot valve failed (BTDT).
Sisyphus is offline
The Following User Says Thank You to Sisyphus For This Useful Post:
fjn (04-16-2019)
Old 04-16-2019, 02:28 AM   #31
hdavis's Avatar
Rewards Points: 1,692
I always used copper nails on wooden boats.
Double hot dipped galvanized nails will take a smooth face hammer blow without compromising the zinc. This, however, does depend on the manufacturer.
Every single grip rite galvanized gun nail I have used has poor adhesion of the zinc to the nail. It will shear off easily. Any exposed heads are easily compromised, if they weren't compromised when driven.
I don't think titanium would corrode, but who wants to buy titanium hardware.
hdavis is online now
Old 04-16-2019, 02:30 AM   #32
hdavis's Avatar
I ran into the stainless hose clamp, but the screw on it wasn't stainless issue. The screw rusted out in a year on a radiator hose.
The Following 3 Users Say Thank You to hdavis For This Useful Post:
fjn (04-17-2019), Rio (04-16-2019), Sisyphus (04-16-2019)
Old 04-16-2019, 05:44 AM   #33
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,266
yup. Seen that a bunch.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 04-16-2019, 03:33 PM   #34
fjn's Avatar
Trade: mason
Stainless hose clamps below grade may or may not be a concern. Reason being,in other articles I read,the stainless will appear outwardly,to be intact,however,for lack of better description,it breaks down inwardly on let's call it a molecular level. That is the insidious reality the boating industry uncovered. The swivels for rigging along with the doohickeys ropes are wrapped around etc. look fine until.........they are not. From what I read regarding boats (I'm not a boater) years ago,bronze was the material of choice. Stainless displaced it because bronze needed polishing,stainless almost always "looked good ".
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
hdavis (04-16-2019), Rio (04-16-2019)
Old 04-16-2019, 08:01 PM   #35
Sisyphus's Avatar
Rewards Points: 957
A local water system here had to dig up a lot of the lines because gear clamps failed, screws rusted out. Sad... I think it was just an oversight the 20 cents per clamp saved by not going "all stainless" wouldn't have mattered to the original contractor.
I've seen both types of clamps (stainless screw & regular screw) mixed together in the same bin, I check the labels.
Sisyphus is offline
The Following 4 Users Say Thank You to Sisyphus For This Useful Post:
fjn (04-17-2019), hdavis (04-16-2019), META (04-16-2019), Rio (04-16-2019)
Old 04-17-2019, 12:50 PM   #36
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,262
I haven't seen a wood foundation before but I'm curious. How do you level it if it's sitting on gravel?
KennMacMoragh is offline
Old 04-17-2019, 01:19 PM   #37
META's Avatar
The gravel bed needs to be level, or foundation walls are istalled on footings.
META is offline
Old 04-17-2019, 04:52 PM   #38
How do you get a level gravel bed? We're talking +- 1/8" accuracy is what I like to see for height. It would be hard to do with a rake.
Old 04-17-2019, 05:39 PM   #39
fjn's Avatar
Trade: mason
That is a good question,however,a gravel base is all you get with Superior Walls pre-cast concrete foundations also.
fjn is offline
Old 04-17-2019, 05:39 PM   #40
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,081
A Plate tamper/vibrator.... a shovel, the 2x8-10- 12" treated mud sill.
Tamp rock, set plate, check level, Similar to screeding concrete bases, Repeat as needed, Drive in rebar elevation pins, avoid drain tiles, screed to pins, don't molest pins, or recheck as needed.
I'd "tea bag" the rock in clayey soils to add decades of flow through the tile and rock and reduce earth movement/settlement.
Fouthgeneration is online now
Leveling wood subfloor - engineered wood buckling Al11 Flooring 5 08-16-2016 06:22 AM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
Permanent Wood Foundations SteelCity Construction 4 05-13-2008 03:26 PM
