Wood Foundations - Construction - Contractor Talk
Wood Foundations
Old 03-17-2019, 03:41 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 314
Wood Foundations
So I've seen several books detail wood foundations for full excavated basements. Basically a treated sheathed stud wall on strip footings, waterproofed and backfilled. Seems attractive from a price point but i would have serious concerns about durability. Any of you guys building wood foundations?
bwiab is offline
The Following User Says Thank You to bwiab For This Useful Post:
TEnglish14 (04-14-2019)
Old 03-17-2019, 05:06 PM   #2
NGCExcavation's Avatar
Trade: General Contractor/Excavation
Rewards Points: 38
Re: Wood Foundations
They're relatively common in a community near here. I've worked on a couple.
The ones i've had to work on were wrapped in vapor barrier instead of a real waterproofing membrane. Hence why I was working on them.
The big thing about them is that you've got to get your waterproofing details right. No spray on crap like concrete, real SA waterproofing membranes. If it's done correctly though, I see no reason why they wouldn't last indefinitely.
Typically we see them backfilled with clear stone almost to grade. That's fantastic from a drainage standpoint. No one ever does that with concrete.
I'd consider building one if cost was an issue on a project.
NGCExcavation is offline
The Following 3 Users Say Thank You to NGCExcavation For This Useful Post:
bwiab (03-18-2019), greg24k (03-19-2019), ScipioAfricanus (03-18-2019)
Old 03-17-2019, 06:22 PM   #3
diplomat
Golden view's Avatar
Rewards Points: 1,042
I've built a couple.
As said above, it's all in the details.
PT wood.
Waterproof the wood for redundancy.
Keep the waterproofing dry for redundancy.
Golden view is offline
The Following 5 Users Say Thank You to Golden view For This Useful Post:
bwiab (03-18-2019), greg24k (03-19-2019), Rio (03-17-2019), ScipioAfricanus (03-18-2019), TEnglish14 (04-14-2019)
Old 03-17-2019, 09:02 PM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 766
They're listed in the IRC (International Residential Code), quite a bit of general information on them in there, was just glancing at it and saw there's also a category for wood floors on grade! Will have to read up on that just to see what they have about it.
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
bwiab (03-18-2019)
Old 03-18-2019, 08:14 AM   #5
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,166
My buddies house is 30+ years old with a wood basement and has had no problems at all. Can't imagine they are all that much cheaper, considering how inexpensively some of the concrete basement subs work?
Fishindude is offline
Old 03-18-2019, 08:17 AM   #6
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
They "can" work good until they fail.
When the waterproofing/drainage on a poured wall fails, you end up with some wet walls/slab. When same happens with wood, rot and movement.
SmallTownGuy is offline
Old 03-19-2019, 07:20 PM   #7
Donohue Const's Avatar
Rewards Points: 1,712
have some around here
I have built a few of them
kinda like anything, build it right and it will last a long time
warmer and less damp feeling then concrete
I have considered it for my house
but I think icf is the best
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following 2 Users Say Thank You to Donohue Const For This Useful Post:
Golden view (03-19-2019), META (04-13-2019)
Old 04-02-2019, 11:51 AM   #8
johnpegal's Avatar
Trade: Professional Contractor
Rewards Points: 4
I don't know exactly how long a wood foundation will last, but I know that the most common options to wood are poured concrete and concrete blocks, and I have seen those foundations fail in homes ranging from 10 to 50 years old.
johnpegal is offline
Old 04-02-2019, 06:54 PM   #9
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,531
Small Town Guy: Not for Throw away Wood basements, but, the ones I brick veneered were far straighter and flatter then ANY low bid concrete foundation.....
The better built ones are built on Top of washed rock "french" drains under every wall that has perforated tile running through it to daylight, with frost tie downs on the tile discharges.
Tea bag the rock in filter cloth of course to add decades of service.
The "baseplate" needs a Engineer or competent builder to figure its width needed, as using a barn sill plate or double or triple plate to spread out point load on the treated plywood wall panels that are't any where near as stiff as concrete or even block walls.
By their nature, all wood basements are the cheapest to finish, the first time,
Fouthgeneration is offline
Old 04-02-2019, 07:04 PM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,270
I bought an investment property that the block foundation was caving in on and replaced it with a PWF. It worked great for my situation. The waterproofing details have to be spot on. I used my moisture meter to see if the ply or studs had any moisture in them 6 years later...nope...4-7% even at the bottom. Made me feel good.
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
hdavis (04-02-2019), Xtrememtnbiker (04-02-2019)
Old 04-03-2019, 10:08 PM   #11
SPG's Avatar
Trade: Don't take trades, cash only.
Rewards Points: 1,090
I know that they're an accepted method in the mid west, but I think here in the PNW it might be a hard sell since the home inspectors and real estate agents haven't dealt with them.
Any of you guys who've built 'em get pushback when it's time to sell the house?
SPG is offline
Old 04-04-2019, 11:40 PM   #12
Stunt Carpenter's Avatar
Rewards Points: 2,474
My parents have a wood foundation on an addition the built in 2000. Amazing how much warmer it is over a concrete basement.
The basement shares in floor heat with the bathroom above and the basement looses so little heat we had to add a electric baseboard heater to the bathroom above because the floor heat was on so little.
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
hdavis (04-05-2019)
Old 04-07-2019, 08:57 AM   #13
Trade: Masonry
Stunt Carpenter @12: Hot water heat, reverse/slow the water flow so it just heats the bathroom..instead of the seldom used basement. And or insulate basement ceiling...
High density foam under the basement floor ?
Put your load bearing concrete /CMUS inside the rain screen and insulation blanket, your structure will last centuries if it stays dry and and doesn't ever suffer any large daily temperature excursions. And the 50-100 tons of wall and floors act very large thermal mass that reduces wear on HVAC systems.
Old 04-07-2019, 08:27 PM   #14
The problem is the thermostat that calls for heat to that zone is in the basement so it never calls for the heat.
Old 04-08-2019, 04:08 AM   #15
Trade: Masonry
@# 20 : lazy man, install a wireless t-stat?
Old school, run a wire, and add a (Programmable) t-stat?<300.00$.
Somebody short stroked the HVAC for the addition....IMO
Run the hot feed to in between the floor piping, install the "new" zone valves there, what the HVAC should have been originally, plumb returns as needed.
You might need a one way valve or two
Old 04-13-2019, 12:14 PM   #16
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Check back with us in another 60 !
fjn is offline
Fouthgeneration (04-13-2019)
Old 04-13-2019, 02:26 PM   #17
META's Avatar
Trade: General and Trades
Rewards Points: 6,408
I've personally framed a wood foundation and my uncle has designed and built a few for himself. We used marine grade plywood and stainless fasteners for the below grade areas. Most of these walls were full 9' height.
One issue my uncle had on a home was an undersized stud for a tall wall which slowly began to crown inward from backfill pressure.
All said, having framed over 100,000 sqft of wood buildings, I would consider it for my home..and even the basement floor. However, I would carefully calculate stud sizing for all walls...proper drainage and vapor barriers.
META is online now
The Following 2 Users Say Thank You to META For This Useful Post:
overanalyze (04-13-2019), Rio (04-13-2019)
Old 04-13-2019, 06:51 PM   #18
fjn's Avatar
Trade: mason
Some info. I recently came across regarding stainless,coming from the marine industry was quite disconcerting. It appears that if stainless is in a low oxygen environment,it breaks down internally and fails sooner than if left exposed to the atmosphere. It has concerned me in the masonry field. Joint re-enforcement embedded in mortar I would classify as low oxygen. Same as wood buried.
fjn is offline
Old 04-13-2019, 07:07 PM   #19
META's Avatar
Interesting..
I should look into that.
META is online now
Old 04-13-2019, 07:13 PM   #20
fjn's Avatar
Trade: mason
Originally Posted by META View Post
Interesting..
This is just one of several a good friend ,boat enthusiast and engineer shared with me.
https://www.boatus.com/seaworthy/mag...less-steel.asp
fjn is offline
The Following 3 Users Say Thank You to fjn For This Useful Post:
META (04-14-2019), Rio (04-13-2019), Sisyphus (04-16-2019)
Leveling wood subfloor - engineered wood buckling Al11 Flooring 5 08-16-2016 06:22 AM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
Permanent Wood Foundations SteelCity Construction 4 05-13-2008 03:26 PM
