Why Is Wood Rotting ? - Construction - Contractor Talk
Old 03-24-2012, 05:06 PM   #1
SKC's Avatar
Trade: Carpenter and General contracting
Rewards Points: 25
I just looked at a pergola job I did 5 years ago and witnessed a condition I been seeing more of the past 5 years than in my previous 40 years.
Wood 5-14 years old rotting, and not in any of the areas an experienced carpenter would expect to see. Exterior wood window sills with completly unnoticable rot in the middle of the sill not where casings meet sill (typical). Might notice a slight paint blister or nothing, but poke with a finger and through it goes, no logical or possible explanation of why water penetrated.
6x6 best quality Doug fir posts sitting on typical metal post brackets.
Based with 1x6 and cap moulding, no wood touching grade on a paver patio, rotting , pushed a thin screwdriver 4" into it 2 1/2" above base cap. Doesn't make sense
The window job which was Marvin I installed in 1998, allegedly used a wood preservative (supplied to them by PP&G) to treat the woods from which the windows were made actually caused the rot. Thier were lawsuits and so on.
I am beginning to see some common issues with this rot in un-expected areas, a fair amount of what looks like mildew on same job area but not always seen at specific rotted area, sometimes no visible signs at all, sometimes what looks like paint blister.
I am wondering if anyone else is witnessing similar what appears to be unexplained rotting wood.
I am beginning to suspect these newer acrylic and latex paints are not only not doing thier intended job of protecting the wood from moisture but wicking and or trapping it ???.
I have been at this and seen enough over the years to explain most.
Lately I am puzzeled with what I am seeing, it's not making sense.
I also heard possibly newer growth trees used for making this wood from is a possibility. Been around myself long enough to have noticed the decline in lumber quality. ???
Please share any similar experiences or possible explanations.
I also believe in Good quality "oil base primers" for all exterior wood to be painted.
I am searching for others who are puzzeled by this and thier thoughts.
Thanks and looking forward to any responses or thoughts on this topic>
SKC is offline
Old 03-24-2012, 05:17 PM   #2
bconley's Avatar
Trade: Kitchen and bath design+remodel
Re: Why Is Wood Rotting ?
Doug fir isn't going to cut it outside unless it is treated or old growth VG.
If you want it to last use cedar, redwood or some of the tropical hardwoods and pay attention to the details and maintenance.
bconley is offline
The Following User Says Thank You to bconley For This Useful Post:
SKC (03-25-2012)
Old 03-24-2012, 05:37 PM   #3
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
I think it's partly due to "genetically engineered" wood. The new fast growth wood has been altered to grow fast. This leaves it with wider growth rings, more porous cell structure.
This allows moisture to enter more easily. Not much one can do unless you want to search out old growth lumber.
katoman is offline
The Following 3 Users Say Thank You to katoman For This Useful Post:
B.D.R. (07-23-2012), otislilly (06-18-2012), SKC (03-25-2012)
Old 03-24-2012, 06:08 PM   #4
Builder of Stuff
Young_Buck's Avatar
Rewards Points: 290
Our available wood is crap, and there's nothing we can do about it in the next 150 years.
Young_Buck is offline
Old 03-24-2012, 06:08 PM   #5
duburban's Avatar
Trade: building
Rewards Points: 1,796
are all sides coated?
duburban is offline
Old 03-24-2012, 07:10 PM   #6
Railman's Avatar
Trade: Railing
Rewards Points: 1,159
It all started when they took all the chemicals out of the paint that controlled the little bugs that cause rot, somewhere around the late 70's. It affects everything in the weather.
Joe
Railman is online now
The Following User Says Thank You to Railman For This Useful Post:
Gary H (03-26-2012)
Old 03-25-2012, 09:19 PM   #7
SKC's Avatar
Rewards Points: 25
That I think is just possibly part of the problem, (the new growth woods)
SKC is offline
Old 03-25-2012, 09:20 PM   #8
SKC's Avatar
Rewards Points: 25
Yes all sides coated and well mainted.
SKC is offline
Old 03-25-2012, 09:24 PM   #9
SKC's Avatar
Rewards Points: 25
You're right I have first hand witnessed the diminished quality of our typical wood supplies over the past 45 years.
SKC is offline
Old 03-25-2012, 09:31 PM   #10
SKC's Avatar
Rewards Points: 25
Joe
I agree, to be more specific, I have noticed this mold/mildew/black spotting on the exterior acrylic and latex paints mostly in the past 5 years on projects 5-14 years old. I have been and still am a believer of quality oil based primers on all exterior wood.
The chemical content of paints I am sure changes often , beginning to see negative effects of it.
SKC is offline
Old 03-25-2012, 09:34 PM   #11
SKC's Avatar
Rewards Points: 25
I agree with you , I have first hand witnessed the diminished quality of our typical wood supply over the past 45 years, using new/younger growth trees, and possibly the geneticaly enginered stuff.
SKC is offline
Old 03-25-2012, 09:41 PM   #12
SKC's Avatar
Rewards Points: 25
Hey guys thanks for your responses, are you seeing much or any of the puzzeling rot that leaves you with no apparent conclusion of water penetration thru well painted window sills or other areas, making you suspicious of the paints and the woods being used, due to lack of any other explanation.
SKC is offline
Old 03-25-2012, 09:57 PM   #13
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
you can't have ''mild''slopes of 5-7 degrees on horizontal members like sills and drip caps anymore,you need to slope at least 15 degrees to shed water asap
we need stop using so much caulk trying to seal every crack,it don't work and can do more to trap water than keep it out
use the right wood species for the issue at hand will go a long way
when all else fails switch to pvc
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
parkers5150 (05-13-2012), superseal (03-26-2012), Winchester (03-26-2012)
Old 03-25-2012, 10:08 PM   #14
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
How about a whole house made from pvc?
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 03-25-2012, 10:20 PM   #15
Trade: siding
Rewards Points: 20
hemp
Old 03-25-2012, 10:22 PM   #16
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Wood is crap nowadays, and painting it is WORSE especially all 4 sides. Water WILL find a way in and when it's sealed on all 4 sides it just stays in and rots from the inside out.
I love when I see a deck with a painted frame because I know they shortened the life 5-10 years when they painted it.
As others have said look for better materials, manmade, steel, aluminum, etc.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
Old 03-25-2012, 11:21 PM   #17
duburban's Avatar
Trade: building
Interesting point. A double vapor barrier principal. Anyone else agree with this?
What about priming all sides of clapboards? I'll be doing this in a week or two.
duburban is offline
Old 03-26-2012, 12:48 AM   #18
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
new growth wood is nothing like what wood used to be.
Sapwood soaks up lots of water and rots fast.
Even if painted on all sides water will find a way to wick in and then the paint stops it from drying. Like Tom said, caulking is a culprit too, it might stop lots of water from getting in, but it also stops it from getting out.
IMO, instead of painting maybe try semi-solid or solid stains that are more "breathable" and use more naturally resistant types of wood.
PVC is also a great choice IMO, though I generally use western red cedar.
Winchester is offline
Old 03-26-2012, 01:07 AM   #19
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
I recently rebuilt some basement door openings out of fir (historic) and replaced some sills/sub-sills out of thermally modified/pt.
I would be happiest to switch to this for exterior wood replacement.
http://www.accoya.com/
I just found a supplier out of Chicago that will do STL drops.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 03-26-2012, 04:51 AM   #20
Big Shoe's Avatar
Rewards Points: 2,110
Ditto................All or nothing.
Big Shoe is offline
bright nails in pressure treated wood (copper) forrest1848 Construction 27 05-28-2018 12:20 PM
Wood over 1/2" ply. jjhomes Flooring 29 03-31-2010 09:55 PM
Elm Wood Greg from K/W Contractor Swap 0 03-22-2010 02:49 PM
Commercial wood framing mckellarman Commercial Construction 2 05-06-2009 05:11 PM
Buckled Wood Floor LNG24 Flooring 2 11-17-2008 11:35 PM
