Where To Find A Hanger Of This Type? - Construction - Contractor Talk
Old 09-03-2013, 06:42 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
i have looked every place i can think of for this. thought it would be a simple purchase but clearly not.
I need a hanger like this
but it needs to be able to accept a standard 2x8 so that i can connect it to a brick wall to support one side of a pergola.
Any ideas. i have gone throug about 10 simpson books and the only ones are can find are like above and only do a min of 3.5" beams.
www.bcconstructionllc.com
BCConstruction is offline
Old 09-03-2013, 06:52 AM   #2
Joasis's Avatar
Rewards Points: 944
Re: Where To Find A Hanger Of This Type?
You could always go to a sheet metal shop and have one fabricated. I have not see simple hangers like that in many years, and if Simpson doesn't list them, you will spend more time looking then just getting them made to order.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is online now
The Following User Says Thank You to Joasis For This Useful Post:
BCConstruction (09-03-2013)
Old 09-03-2013, 06:53 AM   #3
tjbnwi's Avatar
Rewards Points: 2,040
Looks like an LUC hanger to me;
http://www.strongtie.com/products/co...U-U-HU-HUC.asp
By the way, code does not allow you to hang anything off a brick veneer wall.
tjbnwi is online now
BCConstruction (09-03-2013), kambrooks (09-03-2013)
Old 09-03-2013, 06:57 AM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
It almost looks like a concealed flange joist hanger, punch that into Google.
Inner10 is offline
Old 09-03-2013, 07:17 AM   #5
kambrooks's Avatar
Rewards Points: 572
Luc26z?
Kameron Brooks
www.iFixHomeImprovement.com
kambrooks is offline
The Following User Says Thank You to kambrooks For This Useful Post:
Old 09-03-2013, 07:31 AM   #6
tjbnwi's Avatar
After taking another look at the Simpson page I linked, it appears that they recommend the HU series for masonry walls. The HU does not come in a concealed flange (HUC) at nominal lumber widths.
Old 09-03-2013, 07:32 AM   #7
building Contractor
FHS's Avatar
Rewards Points: 160
I may have a couple of those, ill look when I get back to my jobsite.
Tim Fuchs Construction
FHS is offline
The Following 2 Users Say Thank You to FHS For This Useful Post:
BCConstruction (09-03-2013), Buildernick (09-07-2013)
Old 09-03-2013, 08:59 AM   #8
Trade: Construction
I couldn't find nothing in my code book concerning it but I called The permit office and they said they have no requirements on pergolas being attached to brick. Almost every deck in this town is attached to the brick so a pergola is the least of their worries lol
Called Simpson and they spec'd the HU28c and said it will work fine for this situation.
Would prefer something a bit more heavy duty.
Old 09-03-2013, 09:14 AM   #9
tjbnwi's Avatar
The HU is a 14 ga. hanger. It is a little heavier than the LU.
R703.7.3 does not allow any vertical load except self weight on a brick veneer wall. Your AHJ may have an amendment to the code that allows it. Again this applies to a brick veneer wall.
http://publicecodes.cyberregs.com/ic...003_par026.htm
Old 09-03-2013, 09:25 AM   #10
Trade: Construction
nope no amendments here. The code says deck has to be free standing but every single house I have ever worked on has them attached to the brick.
Here's the current house deck I'm working on. every house in this area has them done the same. They are $1+m homes to.
they also allow porches to be built like that too. not sure what the code is for porches being connect to veneers but around here all of them are.
Old 09-03-2013, 10:32 AM   #11
tjbnwi's Avatar
Attachment 98803
Appears as if they are just not enforcing the code then, assuming they have adopted one. Code states nothing can be attached.
Old 09-03-2013, 10:46 AM   #12
Trade: Construction
Inspectors never pull them on it. In 5 years of being here I have only seen 2 built right. One I built and another a couple months back on a real nice house.
Old 09-03-2013, 11:06 AM   #13
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Our hd has those hangers
jlsconstruction is offline
Old 09-03-2013, 12:42 PM   #14
kambrooks's Avatar
Rewards Points: 572
Same here
Kameron Brooks
Old 09-03-2013, 12:58 PM   #15
Trade: Construction
I tried there but no stick in either one of them.
Old 09-03-2013, 01:07 PM   #16
Box Builder
Morning Wood's Avatar
Rewards Points: 10,298
Just have one fabbed up out of stainless. Or paint a steel one. Won't last like a stainless one though.
Morning Wood is online now
Old 09-04-2013, 07:35 PM   #17
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
It is a concealed flange hanger. Lumber yards who deal with engineered floor systems will most likely have access to them. I got 2 today from my lumber yard when dropping my LVL's. I referenced my Simpson catalogue and it has them named "HUC412" i am pretty sure the "HUC" is the description and the numbers are dependant on beam specifics. Hope this helps?
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 09-06-2013, 09:58 PM   #18
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 506
It's my understanding that local AHJs can only have amendments that are more strict, not looser. But selective enforcement is something most guys won't fuss about if it's in their favor...
Tinstaafl is offline
Old 11-17-2013, 11:00 AM   #19
maninthesea's Avatar
Trade: High Pressure Air
Rewards Points: 30
could you double them up and run e thin kerf blade across the end of your 2x8's?
maninthesea is offline
Old 11-17-2013, 11:06 AM   #20
Dan_Watson's Avatar
Rewards Points: 2,748
Why? The brick will fail before that hanger...
Dan_Watson is offline
Test - How many terrible practices can you find ??? theflynner Roofing 28 08-08-2019 11:01 AM
How did you find your cabinet person? Jason Abbott Remodeling 7 01-11-2013 10:24 PM
Want to find a good talented designer and or architect. Greg from K/W Architecture & Design 22 08-12-2012 10:45 PM
Making a Dollhouse Bookcase. Suggestions on paint type and finishing... rdr8887 Painting & Finish Work 9 06-24-2012 10:37 PM
Dramatically Increase Your Sales Home Services Marketing & Sales 29 05-07-2009 11:42 AM
