What About Inverters ? - Construction - Contractor Talk
Old 05-31-2015, 10:09 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,350
Can someone fill me in on 12 vdc to 120 vac power inverters attached to a vehicle ?
Can I run a 7 1/4" saw or 1/2" drill intermittently ? That's about all I need.
Any damage to the battery or alternator that I should know about ?
I think ~ 1500 / 3000 watt is what I'm looking at.
Thanks for the advice.
We Fix Houses is offline
Old 05-31-2015, 11:35 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,011
Re: What About Inverters ?
Yes you can run those pcs of equipment. I recommend a separate battery to operate the inverter. Get one that can produce 3000 watts continuous. Get a battery that is about 100AH's You'll need welders cable that's about 3/4" thick, I think it 0000 gauge.
I ran a chopsaw all day long. It was able to operate my 1HP compressor.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
We Fix Houses (06-01-2015)
Old 06-03-2015, 05:51 AM   #3
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Second battery should be a deep cycle and keep the cables as short as possible. Get a battery isolator so you don't kill both batteries while using and it will still be charged with alternator. 3000 watt I'd overkill, all you need is 20 amps for any single tool 20 amps x 120v = 2400 watts. Very few tools hit actual 20 amps so a 2000 or 2200 will be fine as long as its a quality unit. Also look for a true sine wave inverter don't buy a modified if you plan on charging batteries or plugging in any electronics.
Its an expensive proposition and I've done it once, never again. I just buy small small 400 watt for drill battery or notebook charging and a generator for anything bigger.
-Dennis
WarriorWithWood is offline
Old 06-03-2015, 08:05 AM   #4
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
I concur, I have a small inverter in the truck I can charge a few batteries with. If I have to run a power tool all day I have a little 2000w inverter generator that is easy on gas and really quiet.
Inner10 is offline
Inverters and battery chargers overanalyze Electrical 43 01-25-2012 10:17 PM
12 volt power inverter size?? killzoneq2 Electrical 68 03-16-2010 08:25 PM
unlikely ground wire requirement newenergy NEC Discussion 11 09-28-2009 03:26 PM
power inverters ? painterofeveryt Electrical 4 02-22-2006 03:37 PM
