Weep Screed Air Holes - Construction - Contractor Talk
Old 09-05-2008, 02:43 PM   #1
Project Manager
LaurieC's Avatar
Trade: Custom Home Builder
Rewards Points: 150
I have a unique situation where a HO wants to continue the stucco below the weep screed. No problem, except that the stucco will block the holes on the bottom of the weep screed. I need to come up with something to stick in the holes that will bio degrade, or that can be removed, or cut off, so that the holes aren't blocked. I thought about a straw (actually the boss did) but it's too flimsy and the stucco guys will bend them all to hell. Any good suggestions?
LaurieC is offline
Old 09-05-2008, 04:13 PM   #2
Tscarborough's Avatar
Rewards Points: 1,460
Re: Weep Screed Air Holes
All HO want to extend the stucco below the weep screed. The correct answer is, "No!".
Tscarborough is offline
Old 09-05-2008, 05:28 PM   #3
Project Manager
LaurieC's Avatar
Rewards Points: 150
Always? I've never had one ask before...oh well. That's what I'm here for- to learn.
LaurieC is offline
Old 09-05-2008, 07:07 PM   #4
Rewards Points: 2,000
Old trick for brick was cotton
clothesline gooped up with
vaseline.
Don't know much about stucco.
neolitic is offline
Old 09-05-2008, 08:21 PM   #5
Weep screed is a relatively recent innovation, created to address a specific weakness of traditional stucco. The key to it's value is that it is placed at the bottom edge of the stucco, and is not covered by other construction, dirt, or anything else. If the design is such that too much foundation is exposed (rare, since the design usually is tailored to allow the minimum exposure), then the design should be changed (also rare), or the owner must accept the performance limitations of the stucco itself.
Jobsite re-engineering of proven wall systems seldom ends well.
Old 09-05-2008, 08:22 PM   #6
j_builder's Avatar
Trade: Specializing in residential remodeling
Rewards Points: 250
Not if the stucco coat is applied with a thin layer of cement glue adhesive/trowel float the 1st stucco coat/spray on the 2nd stucco coat with a drywall hopper...try a sample board first to find the right texture/air setting before applying any to the house.
This way no weeper's will be blocked. My stucco man gave me a life time guaranty (H/O's or mine) which ever goes first . I've had other stucco men just use a paint brush to apply the stucco, that didn't last a lifetime,so I had this guy redo it, still there after 10 years.
j_builder is offline
Old 09-05-2008, 08:33 PM   #7
That is a good solution. Simply apply a matching finish coat below the weep. Soil and water exposure will limit the life of the finish, but it will not impact the integrity of the stucco above.
Old 09-08-2008, 07:00 AM   #8
stuccoman's Avatar
Rewards Points: 25
Although there are holes in the weepscreed they are not the primary weepage point.
The very front edge of the screed is when the stucco shrinks back away from it and forms a crack. With that said do not let a painter paint or seal the crack.
http://amico-lath.com/lath/foundation_weep_screed.htm
stuccoman is offline
Old 09-18-2008, 07:13 PM   #9
j_builder's Avatar
Rewards Points: 250
Laurie how did you solve or resolve this dilemma?
Old 09-29-2008, 03:50 PM   #10
HatMan1's Avatar
If it was my responsibility i would lower the weep screed. remove the stucco up a little and do it right.
HatMan1 is offline
Old 10-01-2008, 11:53 AM   #11
GC
NICKPAUS's Avatar
Rewards Points: 150
Where I am located weep screed must be 4" above finish grade.
NICKPAUS is offline
Weep Holes wmhenley Masonry 16 05-11-2008 08:39 AM
need advise on wrapping wdw and weep holes AustinDB Windows, Siding and Doors 2 04-21-2008 10:07 PM
What the heck? Holes in basement floor Terrence Remodeling 4 06-13-2007 01:06 AM
Weep Screed and t1-11 bmartin Carpentry 4 09-26-2006 08:00 PM
Weep holes Bigbricklayer Masonry 25 06-04-2006 01:18 PM
