Tilt Deck Trailer For My Mini Excavator?? - Construction - Contractor Talk
Old 02-02-2019, 06:17 PM   #1
Earthmover7947's Avatar
Trade: Excavating
Rewards Points: 6
I'm looking to purchase a tilt deck trailer for my mini excavator. I'm thinking I would need a 16,000 GVW trailer to be legal. I checked out my local trailer dealers and they had several options, such as PJ, Load Trail, Big Tex, etc. They were all similarly priced. My one concern on them is the frame construction. They are using 6" channel frames and I'm not sure if they will hold up. This dealer also had B & B, or Behnke trailers. The cost is higher, but the frame construction and overall craftsmen ship, seems to be better. Specs of trailers are below:
https://www.pjtrailers.com/trailers/...6-inch-channel
https://loadtrail.com/trailers/tilt-...e=Tilt%20Decks
https://www.bigtextrailers.com/16tl-...-bed-equipment
https://behnkeenterprises.com/trailertypes/tiltbeds/
I did also notice, that Behnke offers a 20,000 GVW tilt, which the others do not. I'm not sure if I need the extra capacity, but could come in handy if I was hauling additional attachments.
Any experience, opinions, etc. on these brands would be appreciated.
Earthmover7947 is offline
Old 02-02-2019, 06:47 PM   #2
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,635
Re: Tilt Deck Trailer For My Mini Excavator??
I say the operators over the decades determine the survival of bumper pull trailers. Untrained idiots WILL destroy any piece of iron, even on with 8 or 10" C channel frames instead of 6"...
Center of Gravity of the load over the wheel width will determine the stability of the trailer and towing rigg. Thus the 2" lower deck might actually survive longer then ditch/ rollover hunting high deck....
Gather tare weights, and type and quality of steels used.
Compare the tilt bed pins and centering devices, Is your tow vehicle small enough you'll need to use jacks EVERY time you load the mini-hoe?
If so run them up and down several times....
Are the tires a common size that = a reasonable replacement cost? spare throw in?
Avoid triple axle trailers as they are very hard on tires in tight spaces and even axle parts/suspension springs.
Make sure your trailer is DOT legal(weight,Brakes & tire ratings) when you have all the accessories you need loaded...spare buckets, tamper, and fuel.
Fouthgeneration is offline
Tiled deck pschieuer Construction 16 10-21-2015 03:16 PM
Tilt Bed Trailer txgencon Vehicles 37 12-18-2014 04:44 PM
Track came off mini excavator? realelectrician General Discussion 21 08-19-2014 10:48 PM
Mini Excavator info wanted TODD MITCHELL Tools & Equipment 4 04-16-2011 09:19 PM
Mini Excavator Question magnet Excavation & Site Work 2 08-29-2008 07:15 PM
