Strange Stud Shadows On Interior Walls - Page 2 - Construction - Contractor Talk
Old 01-10-2010, 12:01 PM   #21
Zinsco's Avatar
Rewards Points: 250
Re: Strange Stud Shadows On Interior Walls
They are using one of those portable ionizer "air fresheners" that ionize air molecules. The denser materials are receiving a slight charge and are attracting dirt.
Zinsco is offline
Old 01-10-2010, 12:10 PM   #22
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
It's thermal bridging.
There are seveal things that cause it and even more things you can do to fix it. If it can be completely corrected.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
nEighter (01-11-2010)
Old 01-10-2010, 12:10 PM   #23
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
how do you post pictures
Chris@Sunrise is offline
Old 01-10-2010, 01:00 PM   #24
freemason21's Avatar
Trade: carpentry and painting
with the post a picture button
freemason21 is offline
Old 01-10-2010, 01:09 PM   #25
Rewards Points: 2,000
Originally Posted by CHB70 View Post
I have a customer who thought they had some water damage. I went to check the roof, but when I arrived they showed me the problem on the inside walls.
Every place there is a stud on outside and inside interior walls they have shadows showing the stud outline. I have a pic attached
https://www.contractortalk.com/attach...1&d=1263141540
Google "thermal bridging."
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Old 01-10-2010, 09:33 PM   #26
d-rock's Avatar
Trade: carpentry/drywall/plaster
Rewards Points: 250
i've seen this before as well.......it was in a haunted house ...it wasn't thermal anything..it was THE DEVIL !!!!
d-rock is offline
Old 01-10-2010, 09:37 PM   #27
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Ding ding ding
Only Warner and Neo got this right.
that is exactly what this is and considering the OP's location I would suspect a little too much humidity in the house too.
naptown CR is offline
The Following User Says Thank You to naptown CR For This Useful Post:
Old 01-10-2010, 09:46 PM   #28
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Originally Posted by tcleve4911 View Post
Thank you Alex Trevek...............
its Trebek i think your thinking of Alex tyvek
Tom Struble is offline
Old 01-10-2010, 09:46 PM   #29
Atlanta Remodeling
bdoles's Avatar
Trade: Home Repairs and Remodeling
Rewards Points: 154
A good article on thermal bridging and ghosting.
http://www.carlisle-syntec.com/docum...alBridging.pdf
bdoles is offline
Old 01-10-2010, 09:48 PM   #30
Trade: siding
Rewards Points: 20
Originally Posted by naptown CR View Post
Ding ding ding
Only Warner and Neo got this right..
they are so smart
Old 01-10-2010, 09:51 PM   #31
Teetorbilt's Avatar
I have seen similar things with screw heads in wood or metal studs and along baseboards. With the screw heads I could see some sort of static charge. The base problem eludes me.
Albert Einstein
Teetorbilt is offline
Old 01-10-2010, 09:54 PM   #32
Trade: siding
Rewards Points: 20
you can see it sometimes too on vinyl siding,with the right conditions you can see where the nails are by the condensation
Old 01-10-2010, 10:07 PM   #33
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
The higher thermal conductivity of the frame members reduces the temperature of the wall surface. The cooler wall surface absorbs thermal energy of adjacent air molecules. The water vapor fraction of the air gas mixture is condensed from gas to liquid due to the reduction in kinetic molecular energy. The polarity of water molecules makes it the universal solvent with opposite ends of the molecules attractive to positive and negative ions of assorted fine particulate matter present in the air. This results in an accretion of dust.
Cheers,
Basswood
basswood is offline
Old 01-10-2010, 10:13 PM   #34
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Cheers,
Basswood
Thank you professor Basswood, for that well thought out and informative post.
loneframer is offline
Old 01-10-2010, 10:18 PM   #35
Artisan Carpentry
basswood's Avatar
Also known as "Ghosting due to Thermal Bridging."
Cheers,
Bass
basswood is offline
Old 01-10-2010, 10:24 PM   #36
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 354
Cheers,
Basswood
Thats what I was gonna say. Dang you Bass you plagiarized my post! (wow plagiarized is hard to spell!)
Easy Gibson
Warren is online now
Old 01-10-2010, 10:35 PM   #37
Sluggin away
FremontREO's Avatar
Trade: Dihydrogen monoxide remediation/GC/REO/Insurance
Rewards Points: 550
heres those ghosts frozen
FremontREO is offline
Old 01-10-2010, 11:03 PM   #38
Artisan Carpentry
basswood's Avatar
I knew you were going to say that... so I just had to beat you to it.
Later man,
Bass
basswood is offline
Old 01-10-2010, 11:06 PM   #39
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 980
Professor: How can I tell which end of a molecule I'm looking at?
Tinstaafl is online now
Old 01-10-2010, 11:07 PM   #40
Geometrist
Warren's Avatar
Rewards Points: 354
just look in the genes!
Easy Gibson
The Following 2 Users Say Thank You to Warren For This Useful Post:
Tinstaafl (01-10-2010), Zinsco (01-10-2010)
fiberock aqua tough board on 25 gage stud Miked55 Drywall 8 02-06-2010 11:50 AM
Lag Bolts in Metal Stud motomoto General Discussion 21 12-22-2009 10:11 AM
Malco Stud notcher bellemech Contractor Swap 1 08-20-2009 02:54 PM
how do you estimate steel stud framing? Wensdy Framing 8 07-21-2009 09:18 PM
Jack stud question billderboots Framing 45 12-31-2008 07:13 PM
