Stainless Steel On Galvanized Unistrut - Construction - Contractor Talk
Old 09-11-2020, 12:40 PM   #1
boileredup's Avatar
Rewards Points: 22
Hi all,
There was an issue with the specs where the design had called out our electricians unistrut to be stainless steel on a galvanized cooling tower. What would be the best way to remediate this? Or do we need to get all new galvanized unistruts?
Stainless Steel on Galvanized Unistrut-ab7f9448-4d94-43eb-8fcf-c74e3224126c.jpg   Stainless Steel on Galvanized Unistrut-img_0484.jpg   Stainless Steel on Galvanized Unistrut-img_0477.jpg
boileredup is offline
Old 09-11-2020, 06:41 PM   #2
rustyjames's Avatar
Re: Stainless Steel On Galvanized Unistrut
The best way to remediate this is to use what's called for in the specs. and that's to use the stainless strut. Makes no difference if the tower is galvanized. You'll probably need to use stainless hardware that's related.
rustyjames is online now
Old 09-16-2020, 03:58 PM   #3
Half-fast Eddie's Avatar
Trade: Commercial project management
Rewards Points: 124
The closeup picture of the mounting bracket shows you have installation issues too. There should be a couple of threads showing above the nut.
Half-fast Eddie is online now
The Following User Says Thank You to Half-fast Eddie For This Useful Post:
rustyjames (09-16-2020)
Old 09-16-2020, 06:10 PM   #4
rustyjames's Avatar
Good catch. Also that beam clamp in the pic above that should have a locknut.
Old 09-17-2020, 05:30 PM   #5
FurstyFurst's Avatar
Rewards Points: 4
If you believe it to be an issue submit an RFI to the Owner or Architect. If there is a change in cost just be prepared to give a change order.
FurstyFurst is offline
Old 09-17-2020, 06:19 PM   #6
Mike-B's Avatar
Rewards Points: 1,262
Looks like that strut, the strut straps, and the strut "L' is the typical electogalvanized finish. The hardware appears to be zinc plated
Might want to double check the specs to see if all the hardware meets the requirements.
Mike-B is offline
Old 09-18-2020, 04:24 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 12
They aren't going to pay extra for anything that's in the existing spec book.
Mike.
_______________
Calidecks is online now
rustyjames (09-18-2020)
Old Today, 10:37 AM   #8
Rewards Points: 124
Mike.
_______________
No, but if there is any question with regard to what is expected to be installed, a written RFI is the proper way to document.
Calidecks (Today)
