Slab Help! - Construction - Contractor Talk
Slab Help!
Old 12-06-2004, 10:48 AM   #1
KnightofTexas's Avatar
Slab Help!
I don't know who to call.I want to install laminate flooring in my home,but my cement slab has a serious slope as you walk towards the back door,(about 2 3/8" unlevel). I would like to get this fixed before I put the new floor in.Any suggestions?Can cement be poured to level this out?And if so,what do I do about my sliding-glass door?I want a new door,preferably french style.But wouldn't the new door have to be raised to meet the new height of the floor?Looks like a huge project,huh? I want it done right.Please help!
KnightofTexas is offline
Old 12-06-2004, 08:50 PM   #2
Teetorbilt's Avatar
Rewards Points: 2,000
Re: Slab Help!
Any idea of the cause of this slope? If the slab is settleling, this needs to be addressed first and halted. I see many poor slabs but not THAT bad.
Teetorbilt is offline
Old 12-06-2004, 09:07 PM   #3
TimWieneke's Avatar
Rewards Points: 250
Re: Slab Help!
Can something like this be mudjacked? I've heard of it being done on exterior slabs.
Tim
TimWieneke is offline
Old 12-06-2004, 09:17 PM   #4
PipeGuy's Avatar
Trade: underground
Re: Slab Help!
Originally Posted by KnightofTexas
I don't know who to call...Money is no object.
When may I start?
There's a fairly recent thread about fixing a similar slab for similar reasons. Take a look see.
PipeGuy is offline
Old 12-06-2004, 09:42 PM   #5
Re: Slab Help!
No, the slab was poured sloppily. There's no need for foundation repair.I did look at Mattox.com.They have stuff that would work that you pump into place and it self-levels up to 3". I did see the other thread about this,thanks.
Old 12-06-2004, 11:17 PM   #6
Teetorbilt's Avatar
Re: Slab Help!
Before I spent any money I'd call the contractor back and have him rectify it. 2 3/8" is bizarre! I couldn't do that poorly drunk and blindfolded.
Old 12-06-2004, 11:41 PM   #7
General Contractor
hatchet's Avatar
Re: Slab Help!
Grypcrete is definately a viable solution - but don't let them fool you into thinking it's self-leveling. You still need to "help" it get level. Anyway - that's another issue. As you stated - the biggest issue with that is the door thresholds. Maybe, by chance they overframed the rough opening for your existing sliding glass door by 2-3/8"
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 12-07-2004, 01:50 AM   #8
Teetorbilt's Avatar
Re: Slab Help!
Hatchet, I always do that just in case that there are drastic changes to be made. LOL
Note to self; All trimmers are to have 2-3/8" clearance on perimeter. That ought to do it! Can't blame improper construction on me, I left them PLENTY of room. Hehehehe!
Old 12-07-2004, 09:28 AM   #9
Re: Slab Help!
This is an older house,not new.I didn't have it inspected before I bought it.
I've learned an expensive lesson.I was in a rush to get in a new house because I sold my old one and school was starting.I wanted this new school district. I know,make fun of me now.
Old 12-07-2004, 10:01 AM   #10
Re: Slab Help!
Anyone heard of or used the Level-Right product from Maxxon?You pump it into the room and smooth it out with a squeegy. www.maxxon.com
Old 12-11-2004, 04:06 AM   #11
Old Mudder's Avatar
Re: Slab Help!
Yes . but thy have differnt grades of it . some you can be hand poured some have to be pumped . if dun right . it works. if not it's a pan .
Old Mudder is offline
Old 12-11-2004, 08:07 PM   #12
bartov's Avatar
Re: Slab Help!
sub floor it if u have the height
if not just shim the low spots
bartov is offline
Old 12-12-2004, 01:48 AM   #13
Teetorbilt's Avatar
Re: Slab Help!
I think that I have an answer, and yes, it will be a project. Please elaborate on the home construction. Block, stick? Drywall interior? Stud or lath depth, as much as you can provide. I read a lot and fast so give it your all.
Old 12-26-2004, 11:03 AM   #14
IowaEric's Avatar
Re: Slab Help!
We've fixed situations like this just pouring concrete, but if its the interior of your home that you're considering, I don't know how viable an option that is to you. Sub-flooring it would be somewhat time-consuming, but it's probably the option I'd go for.
IowaEric is offline
Old 12-30-2004, 05:32 PM   #15
pondman's Avatar
Rewards Points: 150
Re: Slab Help!
Being an old house.... something comes to mind. Is it possible this room was added on after the original home. Was it an outdoor patio at one time.
I know it sounds stupid but it has been done before. Just a thought.
pondman is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 12:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 04:24 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-01-2007 11:38 PM
Fiber reinforced slab cost in central NJ gschotland Masonry 0 11-18-2006 02:27 PM
Basement slab question n74tg Masonry 5 05-26-2006 03:38 PM
