Should Sill Overhang Over Foam Insulation? - Construction - Contractor Talk
Old 04-20-2019, 03:45 PM   #1
JRremodelers's Avatar
Rewards Points: 72
Hi guys,
I'm a licensed GC here in MN and will be embarking on my first NEW build which also happens to be my personal residence. As a remodeler for many years, my foundation expertise is limited to what i've been reading and basic construction practices.
Anyways, As a GC i will be subbing out most trades and i could always ask them and will be asking them but would like opinions of others.
So my question, In MN we are required to insulate poured foundation wall from head to toe. so basically from bottom of footing to the sill plate. I attached a picture i found on the internet which would mimic exactly what i plan to do. My sill plate (2x6) will be hanging over at least 2 inches to cover foam. I see no other way around it? Take a look at picture and give me your thoughts. is this common practice? i certainly don't want from to sit past the sheathing as i foresee rotting of sheathing
JRremodelers is offline
Old 04-20-2019, 04:18 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,034
Re: Should Sill Overhang Over Foam Insulation?
Don't know others thoughts, but I would want a lot more then a 2x6 sill plate in that situation. Only gives you 3.5 of the plate on the concrete wall, which is placing the anchor bolt real close to the out part of the wall.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
META (07-03-2019)
Old 04-20-2019, 06:04 PM   #3
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 874
If you’re lucky and your foundation guy doesn’t place it too far in so it misses the plate altogether.
I’d put the sill even with the outer edge of the crete wall.
Big Johnson is offline
Old 04-20-2019, 07:36 PM   #4
TimNJ's Avatar
Rewards Points: 5,674
I would set it so my sheathing edge is even with the foundation foam.
Then when you put your siding on, it protrudes past the foundation foam.
TimNJ is offline
Old 04-20-2019, 11:37 PM   #5
Rewards Points: 72
But if water ever got behind siding it would find a way behind sheathing and foam. But I suppose a flashing would prevent that
Old 04-21-2019, 03:36 AM   #6
ksc1's Avatar
Rewards Points: 140
Have you considered using the rigid foam on the whole exterior? It will be costly but will payback pretty quickly.
ksc1 is offline
The Following User Says Thank You to ksc1 For This Useful Post:
Tom M (04-21-2019)
Old 04-21-2019, 05:59 AM   #7
builditguy's Avatar
Rewards Points: 1,958
First, I would use a 2x8 for the sill.
Your diagram shows the insulation on the exterior. Is that code in MN? Insulating the foundation is standard. Also has to be done to comply with the 2012 Energy Act. It is extremely rare for me to see insulation on the exterior of a foundation. It could be because we are in different climates.
Insulation from footing to sill is on the inside.
Also, it only shows 1 1/2" of foam which is way less than required.
As to your question, "Is this common practice"
Since I don't see insulation on the exterior, in my area I would say it's not common practice.
To see siding overhanging foundation. Yes it is common practice and has to be.
builditguy is offline
Old 04-21-2019, 06:01 AM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 56
Generally, that foam stops at the grade. 2" required her I believe.
Easy Gibson
Warren is online now
Old 04-21-2019, 06:10 AM   #9
TimNJ's Avatar
Yeah, flash it.
TimNJ is offline
Old 04-22-2019, 01:25 PM   #10
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 156
That is one of the worst details I have ever seen - like others said 2x8 minimum & flashing. No I would not overhang the foam below at all - sorry I can't find the one shareable detail I had on how to do this but I found 2 others online that while not the best are more workable than above:
https://i.pinimg.com/originals/07/af...4514facd73.jpg
https://i.pinimg.com/736x/22/9d/8d/2...2003ebb552.jpg
I would have full termite shield shown in one pic but would have sill shown in other which lines up with edge of concrete // especially as in your climate you need exterior foam sheathing all the way up the walls to (yes you do need the break)
SLSTech is offline
Old 04-22-2019, 04:10 PM   #11
Donohue Const's Avatar
Rewards Points: 1,638
most flash it
1- 1/2" is not enough to meet the energy code that is in your drawing unless your putting some inside the wall also
some jurisdictions wont allow you to "cantilever " the sill plate out like that. it moves the bearing point out off the foundation and they dont like that
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 04-22-2019, 08:35 PM   #12
TimNJ's Avatar
Should use a sill plate to equal the thickness of the pour and foam.
With ICF, they allow the sill to meet the edge of the ICF around here.
TimNJ is offline
Old 04-22-2019, 09:29 PM   #13
icf they allow plate to hang flush to outside here to, but that's only 2"
energy code says you need 3" of foam on foundation (r15)
most try to put it all on the outside so they are not forced to drywall the basement walls
Ryan
Old 04-22-2019, 11:06 PM   #14
Bull Trout's Avatar
Rewards Points: 118
The top row of icf is tapered so the sill isn’t resting on 2” of foam
Bull Trout is offline
Old 04-23-2019, 08:41 AM   #15
Randy Bush's Avatar
ICF -2.5 per side for a total of 5" of foam.
Old 04-23-2019, 09:20 AM   #16
but not at the top
Ryan
Old 04-23-2019, 10:02 AM   #17
Randy Bush's Avatar
but not at the top
All the ones I have ever messed with where. Like so many things are a lot of different options.
Sent from my SAMSUNG-SM-J327A using Tapatalk
Old 04-23-2019, 03:42 PM   #18
right lots of different ones, I dont really do many icf's, not sure why I always think it a 2" foam
Ryan
Howdy from Stellrr Insulation & Spray Foam in Austin TX stellrrinsulate New Member Introductions 2 04-19-2017 01:13 PM
Should you pay more for a quality insulation job? ecworks Insulation 8 12-10-2012 10:02 PM
Thinking of expanding into spray foam insulation d-rock General Discussion 2 03-21-2012 04:03 PM
