Setting Posts In Concrete - Construction - Contractor Talk
Old 06-28-2010, 09:08 PM   #1
randybelk@comca's Avatar
Trade: CONTRACTOR
Rewards Points: 25
Hey folks,
I have a customer wanting to build a carport. Lots of structural problems to resolve. wants it 22' by 30' all clear span. His idea is for it to have large Douglas Fir beams. No cieling just huge trusses. 3 large dormers down the 22' side on each side. 30' wide to get 3 cars wide. Wants to use 3 8x8 posts at each corner.
This thing is not attached to anything. Stands by itself about 24' from the house with a 5' breezeway connecting the house and carport.
Now then, I think I need to set these posts in concrete, but I wonder if there is some kind of boot or sleeve I can use to keep the concrete from eating away at the post. Usually those things eat away right at the top of the concrete.
Any Ideas.
I wont even get started on what I need for a beam to support the 30' span.
Gonna need an engineer!
randybelk@comca is offline
Old 06-28-2010, 09:27 PM   #2
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Rewards Points: 12
Re: Setting Posts In Concrete
When did concrete start eating wood?
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
The Following User Says Thank You to Willie T For This Useful Post:
neolitic (06-28-2010)
Old 06-28-2010, 09:50 PM   #3
AustinDB's Avatar
Rewards Points: 1,242
maybe after you customer sees the estimate for engineer's fee and the tall steel I beams, he'll think twice and be happy with an extra post at the halfway point.
AustinDB is online now
Old 06-28-2010, 09:53 PM   #4
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,314
The only time I've ever seen a post in concrete for a house is inside a garage. For a carport; I've never seen that, I've only ever seen them either on piers or on top of the slab. I think the post would rot doing it the way you explain it, even with a boot.
But why would you want to set the posts in concrete ? Doesn't sound normal.
KennMacMoragh is offline
Old 06-28-2010, 10:24 PM   #5
Rewards Points: 2,000
Any one ever seen a pole barn?
neolitic is offline
The Following 3 Users Say Thank You to neolitic For This Useful Post:
BuiltByMAC (06-28-2010), Framer53 (06-29-2010), JustaFramer (06-28-2010)
Old 06-28-2010, 10:28 PM   #6
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
As Neo said Pole Barn. We have built up to 16 foot side walls with the poles just buried in the ground no need for concrete.
I don't understand or I am reading it wrong when you say you need a beam to span the 30 foot? Usually you just run a 2x12 on each side of the posts to carry your trusses.
bhock is offline
Old 06-28-2010, 10:48 PM   #7
Kgmz's Avatar
Looks like he only wants 4 posts at each corner, and that is why the 30 foot beam to carry the trusses.
No way I would do this without a engineer. Think about the lateral loads, you will have all that weight sitting on just 4 posts and they will look like toothpicks holding that up. Whats to keep it from folding over.
It can be done, but like mentioned earlier you are going to have to use steel posts and probably lightweight steel trusses. Think about a gas station canopy and then think about what is holding those steel posts in the ground, deep and a lot of concrete.
Kgmz is offline
Old 06-29-2010, 04:08 PM   #8
Trade: CONTRACTOR
Rewards Points: 25
Ok, guys, the customer wants total of 12, 8x8 posts. 3 posts on each corner. sort of L shaped deal. 3.5 inches between posts.
The reason for concrete was to hold the thing in the ground. One might get a good windstorm and pull the thing loose. it is open all the way through. The ends are not closed off. Could possibly get a lot of up draft in a good storm.
Old 06-29-2010, 04:30 PM   #9
dprimc's Avatar
Rewards Points: 598
I would think it would be engineered for some sort of post base like a Simpson CB88 or something. That would be set in the concrete and the post would get bolted to it.
At least around here anyway.
dprimc is offline
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
Setting fence posts on top of concrete retaining wall Tim C. Decks & Fencing 7 06-04-2009 07:16 AM
Embedding W10 beam in concrete footing Greg Di Construction 31 02-20-2009 08:45 AM
Tampa, FL. Concrete Forklift Ramp Needed phattractor Help Wanted or Looking For Work 0 02-10-2009 02:26 PM
tunneling under concrete wireless General Discussion 5 01-13-2009 06:45 PM
