Reinsulating From Outside, Vapor Barrier? - Construction - Contractor Talk
Old 02-08-2009, 08:34 PM   #1
bumpy's Avatar
I am re-siding an older house, so therefor am removing all of the old siding and the sheeting underneath, exposing it down to the studs. I will be insulating from the exterior of the house using batt insulation. Any recommendations on creating a vapor barrier. I don't want to use a spray foam.
This house is located in WI so extreme temperatures play a factor.
bumpy is offline
Old 02-08-2009, 08:36 PM   #2
Rewards Points: 2,000
Re: Reinsulating From Outside, Vapor Barrier?
Not from your side of the wall.
neolitic is offline
Old 02-08-2009, 10:54 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
spray vapor barrier paint? maybe that aluminized sw stuff?
Tom Struble is offline
Old 02-08-2009, 11:31 PM   #4
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Cut and place the vapor barrier between each stud in direct contact with the drywall and tape the edges to the stud, replace the insulation and finish your work from there...
Or use rigid insulation on the outside prior to installing new siding, easier and better results.
Chris
Chris Johnson is offline
Tags
insulation , remodel , residing , vapor barrier
