To Rebar Or Not Rebar An Existing Basement Pour? - Construction - Contractor Talk
Old 01-09-2020, 02:18 PM   #1
Truckie214's Avatar
Trade: General
Rewards Points: 4
23x44 existing cinder block foundation. The homeowner has put in and compacted around 20 ton of gravel which is now even with the top of the footer. He is planning on a 4 inch concrete pour, which is 4 inches above the footer. Installed a hydro channel French drain to a sump, and 10 Mil poly. His “concrete guy” said he’s not doing rebar because he doesn’t need it as the floor will have no load, but this sounded odd to me. Is this something that is normal or not?
Truckie214 is offline
Old 01-09-2020, 04:43 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: To Rebar Or Not Rebar An Existing Basement Pour?
Why not mat it along with some fiber glass, That's a big slab with no reinforcement and I hope there are some cuts.
Still "Shakin" the tree boss
sunkist is online now
Old 01-09-2020, 04:46 PM   #3
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,104
It varies between locations what people do in these circumstances, but I've rarely ever put rebar in a 4" thick slab, would typically reinforce with 6x6/10ga wire mesh. If the base is nice and level and properly compacted, and you saw cut enough control joints in the right locations, you could get by with zero reinforcement and not have a problem.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
mrcat (01-09-2020), rustyjames (01-09-2020)
Old 01-09-2020, 07:40 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 10,276
Id put mesh in it and Id use standoffs.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Fouthgeneration (01-09-2020)
Old 01-09-2020, 07:42 PM   #5
Box Builder
If he isnt going to use mesh or rebar Id at least put fiber in the mix. That is what I did in my basement slab. It cracked quite a bit though, but I was laying sleepers over it and subfloor.
Old 01-09-2020, 07:58 PM   #6
AustinDB's Avatar
Rewards Points: 1,420
If I was providing a proposal on something a homeowner prepared, I would be concerned.
Did he compact every 4" and is there proper moisture to allow for the compaction? Is he calling you if the slab cracks to claim you messed up?
AustinDB is offline
Old 01-09-2020, 08:41 PM   #7
Bull Trout's Avatar
Rewards Points: 118
how is it that you are the general and are not doing site work or concrete?
Bull Trout is offline
Old 01-09-2020, 11:38 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,383
Crazy talk: add an inch of crete, to a Full 5" not the standard 3.5" (four inch nominal) slab on grade....
Galvanized WWF???
Spec 5000PSI, nearly watertight....
Flood cure slab with a few inches of water, by plugging drains....
Install 2-3" of Styrofoam board under slab to cut utility costs FOREVER, reduce HVAC wear through added thermal mass.
I'd slope the floor to the drain(s) myself, .25-.50 % or an inch max in ~16 feet, the basement mud shower being one of the floor drains.
Hire one or two extra cement masons to trowel finish the WHOLE floor even the edges and all embeds.300-6000$ well spent IMHO
Beer and taxi rides for the finishers?
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Dirtywhiteboy (01-10-2020)
Old 01-10-2020, 09:00 AM   #9
Railman's Avatar
Trade: Railing
Rewards Points: 889
Fourth,
He said 10Ga as in 10 gauge, not galvanized.
Regardless of what you put in slab, just make sure to either use zip strips, or cut floor joints when done. Typically they go centered out from stanchion poles.
Railman is offline
Old 01-10-2020, 09:19 AM   #10
builditguy's Avatar
Rewards Points: 1,956
What exactly are you building? I can't figure it out. Floor has no load? Is it a patio? If it's a garage floor, cars will be a load. If it's a driveway, cars will be a load.
For a basement floor, I don't do any rebar, wire, or fiber. There is no load. If you don't cut it, it will crack crazy. Going to crack, no matter what. I usually cut it, so it doesn't look bad. If you have cracks going crazy, people don't like it.
When I pour regular 4000# white rock, I will use 6x6 wire mesh. I prefer the mats. The rolls are a pain.
Sometimes we will use 1/2" rebar in a 2' x 2' grid pattern and tie all connections.
When I use fiber mesh, I don't put in any reinforcement. I do cut (or buy) 1/2" rebar, 2' long. I plan out my control joints. As we pour, I will drop in the rebar across the control joint, before bull floating. I hate it when we forget. Much harder to get them in and looking good.
Fiber is great for strength. The problem I've seen is guys not putting reinforcement at the control joints. When it cracks, those 2 slabs will no longer be connected and will eventually be different heights.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
Railman (01-10-2020)
Old 01-16-2020, 04:44 PM   #11
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 682
Waste of money, I've never seen a grid in a basement floor.
What would the point of it be? You won't be driving on it regularly.
NYCB is offline
Old 01-16-2020, 04:45 PM   #12
NYCB's Avatar
Rewards Points: 682
Was it cut after it was poured?
NYCB is offline
Old 01-16-2020, 04:46 PM   #13
NYCB's Avatar
Rewards Points: 682
If your sub base is moving that much you might want to hire a new grade guy.
NYCB is offline
Old 01-16-2020, 05:28 PM   #14
Box Builder
Yes. I flooded it for a couple days and then cut it. It wasnt an ideal setup. There was no floor framing above it and the sun hit it hard. Also there was a delay on the trucks so that joint obviously cracked. It basically dried out too fast from the get go even though I flooded it out. Not a big deal as stated though. Luckily it was my own home.
