R Zip Sheathing - Custom Doors? - Construction - Contractor Talk
Old 07-02-2019, 06:33 PM   #1
JRremodelers's Avatar
Rewards Points: 72
So with R zip sheathing are you guys opting for custom doors? or just adding to the jamb?
JRremodelers is offline
Old 07-02-2019, 07:52 PM   #2
diplomat
Golden view's Avatar
Rewards Points: 702
Re: R Zip Sheathing - Custom Doors?
I have almost never been able to use a standard 6 9/16 jamb door.
Golden view is offline
Old 07-03-2019, 04:46 PM   #3
META's Avatar
Trade: General and Trades
Rewards Points: 5,844
Really depends on the R value you're ordering, and the lumber width used....
https://insulateyourbuild.com/
I just got finished framing an R Zip 2x4 with 1.5" panel home and installing doors and windows. The biggest issue is the foam being compressed from over driven nails on cut out areas...or, the panels not being properly set tight to framing members. There are generally more irregularities on the exterior due to the Zip sheeting thicknesses and minute differences between slightly weathered foam to "new" foam/zip panels.
A trim carpenter would want the framers to check the thickness of wall at cut out areas in order to best keep any potential extension jambs consistent..or window and doors to closely meet interior coverings.
META is offline
Old 07-04-2019, 04:44 PM   #4
RichVT's Avatar
Rewards Points: 1,081
As far as I am able to determine, custom width jambs are only available in primed, finger jointed pine which will rot out in no time.
RichVT is offline
Old 07-05-2019, 09:57 AM   #5
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 884
Pretty sure I’ve ordered/bought them in pvc.
Thermatru sells a composite jamb, which I’ve ordered in 6-9/16”.
Big Johnson is offline
Old 07-05-2019, 10:00 AM   #6
Rewards Points: 884
https://www.thermatru.com/globalasse...rame_final.pdf
Old 07-05-2019, 10:01 AM   #7
Rewards Points: 884
Back when wrapping everything in aluminum was still popular I made my own custom extensions as they didn’t have to match the factory jambs.
Old 07-05-2019, 12:08 PM   #8
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
I've never seen it be an issue. Is it that much of a difference for you?
It's been 7/16" OSB here for some time and never an issue.
dave_dj1 is offline
Old 07-05-2019, 06:37 PM   #9
RichVT's Avatar
Right now I'm working on a door that has 8 9/16" jambs (2 X 6 wall with 2" of foam).
The original finger jointed jambs rotted out in less than 8 years and caused thousands of dollars in damage under the door because the door was not flashed properly (no sill pan).
I got a 6 9/16" PVC replacement jamb kit from Royal Mouldings and added 5/4 PVC jamb extentions to the exterior. I could not find a jamb in that width in anything but finger jointed pine so I was forced to build it myself.
RichVT is offline
Old 07-05-2019, 07:09 PM   #10
dave_dj1's Avatar
I'm sorry, I just re read the op and totally missed the "R"
carry on......lol....
I haven't crossed that bridge yet so I am paying attention to see what the consensus is.
dave_dj1 is offline
Old 07-05-2019, 07:46 PM   #11
Rewards Points: 884
Why? Isnít the purpose of 2Ē foam to avoid needing 2x6 framing?
Old 07-05-2019, 10:04 PM   #12
Bull Trout's Avatar
Rewards Points: 118
Sometimes
Sometimes it is used when doing an air passive system
Bull Trout is offline
Old 07-06-2019, 03:13 AM   #13
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,383
The Idea of surface mounted foam insulation is that the studs no longer act as "short circuit" for heat flow(gain or Loss).
My home would have the NON-Flame able insulation between TWO layers of sheathing for long term rigidity and protection of foam from varmit/ bug&bird damage. that could occur for years out of sight behind the rain screen.
Love the split 2" x 6" or 8" stud idea, with or with out foam over the truss pins, eliminating the need for surface foam to meet current E guidelines.
Out side the BOX, 2 x 3 s on 24" C to Cs both sides of a 2 x 6/8 plate/sill with continuous blocking at 2-4-6 feet above FFL using 5/8ths fiber glass gpy board...
Fouthgeneration is offline
