-   Construction (https://www.contractortalk.com/f4/)
-   -   R-38 Insulation install - incorrect installation (https://www.contractortalk.com/f4/r-38-insulation-install-incorrect-installation-386242/)
Mickey1 02-20-2018 11:58 AM
I was recently called out to a home that was purchased four years ago..contractor bought it to flip. Put an addition and renovated the kitchen and adjoining bathroom. The drawings indicate 2 x 8 roof frame. 3/ 12 roof. No air baffles were noted on drawings. The drawings indicate R-30 fiberglass insulation. This was crossed out and R-38 was written in.
When I looked in kitchen every light fixture (ceiling is raised) including the ones at highest point have water stains, the joint tape is coming off. The accessable attic had 1/4 of frost on every piece of lumber including roof.
I know R-38 cannot be packed into a 2 x 8 roof frame cavity. It creates a moister build up. But WHAT IS THAT CALLED? When insulation is compacted, no air baffles, cold from roof acting on moisture from inside home entering this cavity there is No form of R value BUT What IS IT CALLED? Thank you.
Tom M 02-20-2018 12:28 PM
Pick up the phone and call the architect. They never learn. I swear to they are getting lazy
Philament 02-20-2018 12:42 PM
I think you might be getting terms mixed up, but the technical term for this manifestation is called Interstitial Condensation.
If you're referring to an unvented roof assembly, sometimes people refer to the as "hot roofs"
Morning Wood 02-20-2018 07:11 PM
You need to verify what type of insulation the R38 is? Hot roof can't be done with fiberglass alone. Well, maybe, but not in a solid sawn rafter.
Pangdev 02-23-2018 12:49 PM
Sounds like a mess.
wmullis0 03-15-2018 08:41 PM
Dense pack?
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
