QUESTION: Residential Framing In NJ- Metal Studs - Construction - Contractor Talk
Old 06-30-2012, 03:04 PM   #1
maa48's Avatar
Sorry if this comes off as a stupid question... my experience has been solely in commercial construction in NYC
I've noticed that all interior home framing in NJ is done in wood. Is it against code to frame interior walls in metal studs? If not, why is wood preferred over metal in the residential world?
maa48 is offline
Old 07-01-2012, 01:44 AM   #2
3bar's Avatar
Trade: carpenter
Rewards Points: 492
Re: QUESTION: Residential Framing In NJ- Metal Studs
wood walls are quieter. wood is more commonly available. running romex wire through wood doesnt require conduit(unless local code requires it). wood is easier to fasten drywall, trim, cabinets to.
sure, you could do metal interior walls, as long as they're not load bearing.
3bar is offline
Old 07-01-2012, 07:05 AM   #3
slowsol's Avatar
Rewards Points: 2,248
It's typically cheaper and faster to frame the whole thing in wood, instead of switching to metal for just interiors.
-John
slowsol is offline
Old 07-01-2012, 08:40 AM   #4
Friend's Avatar
Trade: cabinets and green building
Rewards Points: 160
Metal studs transfer heat and cold a lot faster. Oh sorry, I see now that you said interior walls.
Friend is offline
Old 07-01-2012, 09:09 PM   #5
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Metal studs-
Cost more
Transfer vibrations more (noise)
Transfer heat and cold
Need gromets to run romex
Harder to hang things like cabinets
Harder to run electric and plumbing
Yea you can use metal but why would you? It's not practical
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 07-02-2012, 11:29 AM   #6
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
No stupid questions here...
Metal is typically used to achieve fire ratings and to meet commercial occupancy codes. It's not necessary in a single family residence unless you (or HO) wants to spend the extra money. Metal frame takes a bit longer to install vs wood (typically), the work flow is different (track floor & clg, install wall studs, hang ceiling frame from top down). The only real benefits I've seen using G.M.S. is fire resistance and you're able to keep walls almost perfectly plumb (wood bows and twists). As others have said, it's easier to install rough-in using wood. Metal frame needs grommets, clips, etc.
NINZAN STUDIO is offline
Old 07-02-2012, 10:57 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,082
When you weigh all the pros and cons you will quickly discover that it boils down to price, here wood is close to half cost.
Inner10 is offline
Old 07-02-2012, 11:33 PM   #8
Dirtywhiteboy's Avatar
Rewards Points: 10,102
If I could use wood I would. When I can't use wood metal works fine.
Dirtywhiteboy is offline
Old 07-06-2012, 06:36 PM   #9
TimNJ's Avatar
Rewards Points: 4,470
I have friends in commercial and when i was building my house they talked me into going with metal on the interior partitions.
It was fast, easy, electrical and plumbing were not that big a deal, and of course the deciding factor back in '94 was that metal was way cheaper than wood at the time.
As was stated already, no bowing studs or popped screws in the metal studs.
TimNJ is online now
Old 07-27-2012, 08:28 PM   #10
scottktmrider's Avatar
Trade: carpenter/drywall
Rewards Points: 295
I have did alot of basements in metal which i find easier because the floor is usually up and down and with metal its alot easier to stick frame it,rather than build the wall on the ground than stand it up.
The real problem is residental is you have to put wood backing in for doors,any kind of trim etc.
But its usually easier for the other trades they can run wires and such through the holes.
scottktmrider is offline
Question about size of metal studs for framing a wall SpyGuy Construction 9 05-09-2012 04:18 PM
shelf supports into metal studs cleveman Carpentry 17 04-17-2012 12:34 PM
Metal & wood framing price BASIC1 Carpentry 2 09-26-2011 06:55 PM
Metal framing question texaspride73 Carpentry 5 12-12-2008 05:51 PM
Metal framing for basement and drop cieling joliet_man Framing 8 10-31-2008 05:40 PM
