Paslode Framing Gun Fires Two Nails - Construction - Contractor Talk
Old 05-27-2006, 02:52 AM   #1
iqcbuilders's Avatar
Question
Can anybody help my paslode gun keeps firing two nails every now and then ,does anybody know what could be causing this
The gun is about two years old
The nails are 3" and are not full round head,
Also we are using two other nail guns and they are working fine so can't be the nails
I took the gun apart and gave it a good clean out. after the clean, I tested it by firing about 15 nails, went fine so i was hoping it fixed it but it is still doing it, possibly less often but still doing it
iqcbuilders is offline
Old 05-30-2006, 09:57 AM   #2
RowdyRed94's Avatar
Rewards Points: 150
Re: Paslode Framing Gun Fires Two Nails
Worn parts or incompatible nails.
RowdyRed94 is offline
Old 05-30-2006, 03:51 PM   #3
fettycan's Avatar
Rewards Points: 25
some times the full round head nails do that in older guns
fettycan is offline
Old 05-30-2006, 07:58 PM   #4
Bone Saw's Avatar
Trade: decks
Rewards Points: 2,076
are you putting nails in over 3.25", that will happen if you try to put 3.5" in it, also I have had bad boxes of nails that were collated slightly at wrong angle, if those 2 scenarios don't fit, I don't know? also I have had nothing but problems with the paslode full head nails for the imct
Bone Saw is offline
Old 06-05-2006, 10:53 PM   #5
erik edlund's Avatar
Rewards Points: 75
IQC,
It's how you place the gun. If you don't have a firm 'set' you'll occasionally fire two shots... annoying, but commonplace...
erik edlund is offline
Old 06-12-2006, 10:29 AM   #6
RowdyRed94's Avatar
Rewards Points: 150
Erik, I believe you're talking about bounce shooting. I think that's a seperate issue.
Old 06-20-2006, 10:13 PM   #7
Rewards Points: 75
Rowdy,
Oh... new term, glad you told me, Thanks.
Old 06-21-2006, 07:55 PM   #8
ContractorTalk Flunkie
dayspring's Avatar
Have you cleaned your gun?
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 06-22-2006, 06:13 PM   #9
Tom R's Avatar
Rewards Points: 2,036
I kind of agree with the 'collation' theory, - - either bad angle (like bonesaw said), or the spacing or even the 'thinness', - - did'ja get the nails from H.D. ??
If so, - - there's your answer!!
Tom R is offline
Old 06-22-2006, 06:35 PM   #10
Teetorbilt's Avatar
Rewards Points: 2,000
Isn't this what will put nails in your head at odd angles?
In this case, maybe it's hitting on a fellow workers wife.
Albert Einstein
Teetorbilt is offline
Old 06-22-2006, 07:40 PM   #11
Tom R's Avatar
Now that's what'cha call a 'NUMB-SKULL'!!
Tom R is offline
Old 07-12-2006, 09:29 PM   #12
arnheimacres's Avatar
iq - I've had the same problem. Anxiously awaiting an answer.
arnheimacres is offline
Old 07-12-2006, 09:44 PM   #13
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
What causes the gun to fire two nails at the same time is the driver is hitting the second nail instead of the first one and driving both at once. The head of the second nail will catch the first and drive it in. Either the channel that the driver follows is sloppy or the nails are the wrong size or the nails are going to far down and letting the driver contact the second instead of first nail. Check all scenarios.
Dave.
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 08-23-2006, 06:10 PM   #14
kiwibuilder's Avatar
Hell o to you all, new to here and i come from down under in New Zealand. Having same prob with my finishing gun. Glad i found this forum and enjoying reading your comments and possible fix tips.
kiwibuilder is offline
Old 09-05-2006, 08:04 PM   #15
deox719's Avatar
Trade: general contracting
Same thing happened to me. The problem was I was using the wrong Degree of nails. I was using 28 degree when I was supposed to be using21 degree.
Frank
deox719 is offline
Old 09-22-2006, 06:42 PM   #16
d.janvrin's Avatar
Rewards Points: 25
Same Prob "PASLODE" Brand (off brands fit but wrong angle ) also never Throw gun from roof peak while standing on ladder 32ft high gun will not work again EVER !!! One other problem ive had I Never knew gas cartrage was dated with exp date They are and WONT work if out date ??? ( miss fires shoots 2 nails at once have to push in out 3-4 times to fire etc )learn new stuff about them every time i bring in for repairs Personally I Think They "SUC!!.
d.janvrin is offline
Old 10-02-2006, 09:55 AM   #17
Builder, Remodeler
thill's Avatar
Trade: Builder, Remodeling Contractor
Rewards Points: 25
Paslode are guns are awesome, in my opinion.
Big Dave hit the answer.
* Use name-brand nails
* Check that the nose of the gun is closed and that the hex screws or latching system is really keeping it tightly closed
* Make sure your driver blade isn't bent or mushroomed
* Make sure the nose of your gun isn't bent or cracked.
Sometimes, one of the above reasons will cause a nail not to fire properly, and then fire two nails on the next trigger pull. Take your gun to the shop if you can't figure out the cause. Generally doesn't cost much, and should fix the problem.
Good luck.
-TH
thill is offline
Paslode impulse framing gun problem's tmerring64 Tools & Equipment 19 03-26-2011 07:52 AM
Nails popping on aluminum rake board cover Cad-Man Roofing 11 04-11-2007 03:34 PM
Paslode nails cdac Tools & Equipment 9 07-22-2006 06:26 AM
30/34 degree Framing Nails Remington Tools & Equipment 2 04-13-2006 07:18 AM
