Outriggers? Outriggers? We Don't Need No Stinkin' Outriggers. - Construction - Contractor Talk
Old 02-09-2015, 04:26 PM   #1
txgencon's Avatar
Rewards Points: 432
Well, maybe one will do.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 02-09-2015, 04:27 PM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Outriggers? Outriggers? We Don't Need No Stinkin' Outriggers.
I know nothing about roofs. What's a outrigger?
www.bcconstructionllc.com
BCConstruction is offline
Old 02-09-2015, 04:47 PM   #3
txgencon's Avatar
Rewards Points: 432
I'm marked the one outrigger they put in. I use a 2x6 every 2' and block both sides between the end rafter and the fly rafter and a 2x4 under the outrigger in the support bay for any overhangs more than 8" up to 20".
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
BCConstruction (02-09-2015)
Old 02-09-2015, 04:51 PM   #4
Texas Wax's Avatar
Rewards Points: 1,662
Technically they should have broke the fly rafter on the outrigger..but I'm gonna shut up. Not every framing crew is as tight as I'd like.
Texas Wax is offline
The Following 2 Users Say Thank You to Texas Wax For This Useful Post:
griz (02-09-2015), SmallTownGuy (02-09-2015)
Old 02-09-2015, 04:54 PM   #5
Trade: Construction
Ok that makes sense now. So it's ok cutting the truss/rafter to run the outrigger through for the support?
Old 02-09-2015, 05:14 PM   #6
txgencon's Avatar
Rewards Points: 432
You're only supposed to notch the end rafter the depth of the outrigger (also called lookout or outlooker by some). That rafter isn't compromized because you have rake studs supporting it.
Here is a picture of what happens if the fly rafter isn't supported properly. It is very common to just build a "ladder".
Note the gradual dip at the lower end. The main ridge keeps it from dipping at the top. This is on a 12" overhang.
txgencon is offline
Old 02-09-2015, 05:16 PM   #7
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 343
I don't do outriggers on anything less than 12" Plenty of tight blocking, and your fine.
Easy Gibson
Warren is offline
The Following 6 Users Say Thank You to Warren For This Useful Post:
banderson3nc (03-05-2015), griz (02-09-2015), NJGC (02-10-2015), slowsol (02-10-2015), SmallTownGuy (02-09-2015), Texas Wax (02-09-2015)
Old 02-09-2015, 05:18 PM   #8
Unger.const's Avatar
Rewards Points: 2,906
I've heard the outriggers referred to as "look outs" either way I love it when a home owner calls and points out how the gable ends are drooping and how cheap it would be to fix it......lol
Unger.const is offline
Old 02-09-2015, 05:26 PM   #9
txgencon's Avatar
Rewards Points: 432
Originally Posted by Warren View Post
I don't do outriggers on anything less than 12" Plenty of tight blocking, and you're fine.
Perhaps on less that 12" you can get by. The problem (as I see it) is getting the blocking "tight". I watched these guys for a bit cutting the blocks freehand (not even using a speed square as a guide). They seemed only intent on having something there with no regard for a tight square fit or any understanding of what "tight" meant.
The problem I have with blocking alone is that you are depending on a connection that is an end-nailed one. Those simply pull out too easily.
txgencon is offline
BlueRidgeGreen (02-11-2015)
Old 02-09-2015, 05:39 PM   #10
txgencon's Avatar
Rewards Points: 432
It's a real bitch even if you don't have to remove the roofing and decking. I've fixed some by removing the soffit and finish fascia, inserting some tight fitting blocking and running long carriage bolts through the fly rafter and end rafter. This requires someone getting in the attic to install the washer and nut and tighten the nut. This is a good spot for using torque washers.
I'd like to hear other fixes people have come up with.
txgencon is offline
Old 02-09-2015, 08:14 PM   #11
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
Why not order the gable truss dropped 3 1/2" or even 5 1/2" and run lookouts on edge. We've done some OH's around 4' where we would have the gable and the first truss dropped so the lookout goes back 47 1/4". Don't more people work this way?
Framer87 is offline
The Following 3 Users Say Thank You to Framer87 For This Useful Post:
overanalyze (02-10-2015), slowsol (02-10-2015), thom (02-11-2015)
Old 02-09-2015, 08:19 PM   #12
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Framer most of us do that. But Warner is right, on 12' or less overhang a ladder is fine.
Built lots of houses that way and have yet to see any dropping.
Framer53 is offline
Old 02-09-2015, 08:37 PM   #13
kiteman's Avatar
Rewards Points: 16
That's a stick built roof for one. I never liked putting my last rafter on the inside of the wall and gable studs outside it. I like having lots to nail my "box" to. He's also got a solid 2x under the tail and his ridge run all the way out. He'll prolly have subfascia for help, too. And, if he does it like me, there will be one or two more that he cuts in as he sheets his way up.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 02-09-2015, 08:46 PM   #14
Framer87's Avatar
Trade: Framing
Don't think he builds like you, a lot of shoddy work going on there
Framer87 is offline
Old 02-09-2015, 08:52 PM   #15
txgencon's Avatar
Rewards Points: 432
Originally Posted by kiteman View Post
... And, if he does it like me, there will be one or two more that he cuts in as he sheets his way up.
I can assure you that isn't going to happen on this one. He may get some help with the ornamental support at the tail, but I'm betting these guys would have done it the same way without the ornamental bracket.
txgencon is offline
Old 02-09-2015, 09:04 PM   #16
VinylHanger's Avatar
Rewards Points: 10,166
We've always run them at 4 feet up the gable end. I thought that was standard practice every where. Doesn't matter if it is a 6 inch over hang or a 2 foot one.
VinylHanger is offline
Old 02-09-2015, 10:38 PM   #17
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,170
Most here do a ladder for 12" then use dropped ends for anything wider, but then do 24 " spacing on the 2x outriggers.
Randy Bush is online now
Old 02-10-2015, 01:16 PM   #18
Like your idea. But how does the rafter tail work if it's dropped?
Old 02-10-2015, 01:45 PM   #19
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
It just stops at the wall. No tail
jlsconstruction is offline
Old 02-10-2015, 03:18 PM   #20
stacker of sticks
Rewards Points: 590
I've never actually seen a gable truss like this, but I guess they are an option. Outriggers? Outriggers? We don't need no stinkin' outriggers.-imageuploadedbycontractortalk1423599496.379341.jpg
don't need no stinkin' Kapex... m1911 Tools & Equipment 42 01-24-2015 02:57 AM
We don't need no stinkin flashing jar546 Carpentry 21 09-05-2013 04:36 PM
Don't Need No Stinkin' Engineerin' Kowboy General Discussion 6 01-11-2013 10:53 PM
Don't Need No Stinkin' Tiltout basswood Finish Carpentry 48 10-21-2009 08:18 PM
Am I in the wrong? Stinkin Internet Lead generators! snciwz8 Marketing & Sales 8 07-31-2008 11:28 AM
