Outdoor Mantle Support - Construction - Contractor Talk
Old 05-31-2018, 10:50 PM   #1
sefiroxx's Avatar
Trade: remodel/handy
Rewards Points: 152
Anyone have a more permanent solution. Holding a 6x12x60 cedar mantle outdoor. Original is 2x2x4 pressure treated nailed together with 8" in the masonry and 4" in the mantle. Is there a better 4x4 solution? PVC other?
sefiroxx is offline
Old 05-31-2018, 11:02 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,900
Re: Outdoor Mantle Support
to clarify, you want to attach a mantel to the masonry wall?
i don't get the 4x4/pvc question.
griz is online now
Old 05-31-2018, 11:08 PM   #3
rblakes1's Avatar
Rewards Points: 3,920
I think he's looking to replace a 12" long 4x4 that is set into the masonry wall and was used to support the mantle.
I'm not sure if he's looking for alternative fastening ideas or just a better 4x4
Sent from my SM-N910V using Tapatalk
rblakes1 is online now
The Following User Says Thank You to rblakes1 For This Useful Post:
griz (05-31-2018)
Old 05-31-2018, 11:11 PM   #4
Fire up the BBQ
griz's Avatar
if so have some nice steel corbels made up.
try drilling steel rods into the masonry and set them with epoxy.
griz is online now
Old 05-31-2018, 11:55 PM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,763
I hate mantles, because veneer fireplaces are weak, compared to the two or three adult/teenaged drunks can apply to an oversized mantle.
masonry korbels with a steel L bracket, 3/8" X 4" wide with ~8" horizontal leg and 12" plus turned with structural wood screws into 2 x 12" blocking install behind the drywall.
The steel bracket hidden by the wood/ stone lintel..
A few french "hooks" as formerly used to hang cabinets might an answer.
A chunk of oven or kiln dried cedar or redwood could be used to replace the fire damaged old "wood" brick, the mounts cut with reverse wedge/dovetails, and maybe a counter sunk lag screw to increase the load capacity.
Fouthgeneration is online now
Old 06-01-2018, 10:05 AM   #6
rblakes1's Avatar
If you want to reuse the 4x4 setup, you could wrap it in blueskin, that's thin enough it shouldn't have an effect on it fitting back in and would add to longevity
Old 06-01-2018, 11:02 AM   #7
madmax718's Avatar
Trade: General
Rewards Points: 3,276
whats wrong with steel square tubing set 12" in and set with mortar?
madmax718 is offline
Old 06-01-2018, 02:28 PM   #8
sefiroxx's Avatar
Rewards Points: 152
Thanks for the responses.
Need to reuse the mantle (custom, matching other wood work, weighs 50lb)
Like the L bracket concept but not sure a 6" bracket would support the load long-term.
Likely will go a replacement pressure treated option (unless I can find some accoya)
sefiroxx is offline
Support for 5 ton fireplace in house moved to new location Nancy Beck Framing 8 07-24-2014 04:27 PM
RenoWorks Support Forum Nathan Technology 16 02-18-2014 10:57 PM
Temporary Rafter Support for Clipped Ceiling TLyon Remodeling 17 09-12-2013 11:22 PM
Moving a Roof Support mediaman Framing 14 01-03-2013 10:03 AM
Looking for support of a great cause loneframer Off Topic (Non Trade) 0 06-16-2012 05:43 AM
