OSB Vs. Plywood TG Subfloor - Construction - Contractor Talk
Old 02-28-2014, 10:44 AM   #1
hack of all trades
dielectricunion's Avatar
Trade: Electrician
Rewards Points: 2,196
The lumber yard I just ordered joists, LVL beams and sub flooring from doesn't even stock TG plywood for subfloors. This is in Indiana.
My friend working with me is from NY and is very partial to plywood so we were planning on ply. Guys at the yard made it sound like ply was inferior and not even worth stocking. I like that OSB is cheaper and doesn't warp, but otherwise feel like ply is somewhat superior.
Is this a regional thing, politically/market based, or is there something I don't get about the magic of OSB?
I do mostly smaller rehab jobs, and handyman type work, so my experience with new construction trends is limited.
dielectricunion is offline
Old 02-28-2014, 11:22 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: OSB Vs. Plywood TG Subfloor
This will be VERY interesting.
fjn is offline
Old 02-28-2014, 11:51 AM   #3
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Just ask for Advantech and never look back. I can show you Advantech with close to a year of weather exposure that looks new after running a sander over the top.
EricBrancard is offline
The Following 5 Users Say Thank You to EricBrancard For This Useful Post:
Dan_Watson (03-04-2014), hdavis (02-28-2014), loneframer (02-28-2014), overanalyze (02-28-2014), pinwheel (03-04-2014)
Old 02-28-2014, 11:54 AM   #4
SfcLee's Avatar
Trade: General contracting
These days plywood delaminates a lot. It is stronger but too many headaches for me so I use osb for floors, walls , & roof.
SfcLee is offline
Old 02-28-2014, 12:02 PM   #5
KAP's Avatar
Trade: Custom
Rewards Points: 39,768
Order 3/4" and it doesn't matter...
KAP is offline
Old 02-28-2014, 12:03 PM   #6
hack of all trades
Trade: Electrician
I would have thought that glue and manufacturing technology would have improved with time rather than decline, but I haven't been around long. If you have to leave it out in the rain, I'd imagine osb would swell up and ruin even more quickly.
Old 02-28-2014, 12:08 PM   #7
SfcLee's Avatar
I have ordered several bunks( a stack about 60) for jobs here & there where the plywood is out of square by 3/4". Georgia Pacific. Osb 3/4" t&g is the stuff to use
SfcLee is offline
Old 02-28-2014, 12:34 PM   #8
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Advantech is far superior than anything I've seen on the market for sub-floor.
Plywood is problematic with delamination with repeated exposure to wetting. In some cases, I've seen delamination right off the stack from the lumberyard.
In this time of farmed lumber, veneers in plywood just aren't as stable as I would like them to be. OSB panels are stiffer and flatter than plywood, IME.
loneframer is offline
Old 02-28-2014, 12:37 PM   #9
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Where in ny is your buddy from? I haven't seen a sheet of ply on a job site in years
jlsconstruction is offline
Old 02-28-2014, 12:42 PM   #10
Azwoodman's Avatar
Trade: Hardwood Flooring/Demolition Services
Rewards Points: 28
http://hardwoodfloorsmag.com/article...d=228&zoneid=2
Enough said...
Azwoodman is offline
Old 02-28-2014, 12:45 PM   #11
stacker of sticks
Rewards Points: 590
Originally Posted by Azwoodman
Sorry I quit reading it after it said max thickness for osb and ply is 3/4. Who ever wrote that clearly doesn't hVe a clue
Old 02-28-2014, 12:51 PM   #12
hack of all trades
Trade: Electrician
we grew up together in Irvington NY. He's in the union but has been out of work for a while. He worked with his father a lot growing up who was an old timer involved in a big range of trades. I was in Chicago for a while and I guess I saw a fair bit of osb being used as subfloor.
Old 02-28-2014, 12:53 PM   #13
Azwoodman's Avatar
Rewards Points: 28
2) Thickness:....Read this paragraph completely. These are quoted NOFMA guidelines so you couldn't be more wrong in stating the person who wrote this doesn't have a clue.
Old 02-28-2014, 12:59 PM   #14
hack of all trades
Trade: Electrician
It said minimum, but they didn't mention that 1 1/8" stuff, what is that called? Probably fun to carry...
Old 02-28-2014, 04:03 PM   #15
ADKCarpenter's Avatar
Trade: FinishCarpenter/framer/restoration
Rewards Points: 75
I get my 1 1/8 sheets from advantech. Its durability is flawless with the crappy weather i have around here.
Heres a good site for specs
http://www.huberwood.com/advantech/p...ntech-flooring
ADKCarpenter is offline
Old 02-28-2014, 05:02 PM   #16
hdavis's Avatar
Rewards Points: 1,172
Think again, if it's Advantech. I have some sitting with a cut edge in ground contact for about 3 years now. The plywood is toast.
Last I checked, Advantech had a higher span rating than the equivalent plywood - I can tell you it's definitely heavier than plywood.
I became a believer about 6 years ago, but I still have test pieces around outside. You never can tell when a good product is going to take a turn for the worse.
hdavis is offline
Old 02-28-2014, 05:31 PM   #17
stacker of sticks
Rewards Points: 590
My mistake, I'll re read it tonight
Old 02-28-2014, 09:23 PM   #18
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
I would never use plywood for a subfloor again. Advantech and other premium OSB flooring is far superior in weather resistance and stiffness. I've never had a problem with Advantech. I've overlaid full house floors with underlayment just to cover up plywood that had de-laminated while rained on in the framing stage.
Rob1954 is offline
Old 03-01-2014, 05:02 PM   #19
Head Light Bulb Changer
66 Shelby's Avatar
Trade: Renovation/Home Repair
Rewards Points: 216
Dammit! Now I'm starting to think that Advantech might actually be a good product. I'm slow to change sometimes. I've always used ply instead of OSB whenever budget allows. I guess strides have been made in the technology. I remember when the first generation of OSB T&G came out. It was absolute crap. You could sneeze on it and it would swell up. NOFMA said no way for HW installs. When I re-sided my house (with Hardi) I used 1/2 ply to sheath the whole thing, instead of OSB. Cost me more, but I know it ain't falling off anytime soon.
66 Shelby is offline
Old 03-04-2014, 07:55 PM   #20
FRAMERBEN's Avatar
Trade: Framer/Remodeler
Rewards Points: 170
Advantech all the way! Just space it accordingly.
FRAMERBEN is offline
how can I remove 3/8 plywood that someone full glued to the plank subfloor? larrykane Flooring 10 04-19-2013 09:32 PM
Should i put a membrane between the concrete topping over plywood subfloor 160AB Carpentry 19 02-05-2012 09:40 AM
mortar bed on plywood subfloor 1Master Tiling 9 06-14-2009 08:24 PM
New plywood subfloor over concrete slab jeffaah Construction 5 10-17-2008 11:33 AM
