New Project Help - Construction - Contractor Talk
New Project Help
Old 05-08-2010, 07:33 PM   #1
wyattgreen's Avatar
Trade: Residential Outdoor Co
New Project Help
Hello all and thank you for any assistance. I have a project I am working on for a customer building a food shelter which will be 4' underground. Sitting on top will be a 4x8 shed (Same dia for the shelter). I am needing to tie the bottom floor together with the cmu wall. I have come up with 2 options however not to confident on the design.
1. Notching out the block where the cells will be filled allowing the 2x8 floor joists to sit inside then pooring the cell so that the top of the joist is flush with the top of the cmu then 3/4 decking, then building the shed on top.
or
2. Simply laying a 2x8 flat on top of the cmu wall using tap cons at the fill cells then building out a frame and securing to the top plate.
Any ideas or suggestions would be greatly appreciated.
wyattgreen is offline
Old 05-08-2010, 09:02 PM   #2
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Re: New Project Help
Why would you not use anchor bolts or hurricane straps like building a house?
NJ Brickie is offline
The Following User Says Thank You to NJ Brickie For This Useful Post:
dakzaag (05-08-2010)
Old 05-09-2010, 09:54 AM   #3
stacker's Avatar
Trade: masonry
Rewards Points: 542
i agree with the anchor bolts.simple and easy.
stacker is offline
Old 05-09-2010, 02:19 PM   #4
wyattgreen's Avatar
so attach a 2x8 to the inside of the block where the top of the 2x is flush with the top of the block using anchor bolts?
Old 05-09-2010, 03:59 PM   #5
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
What kind of work do you do? What is an "outdoor residential co"? Is the block existing? Or will it be all new work?
Old 05-09-2010, 10:06 PM   #6
wyattgreen's Avatar
First... no engineer, no permits... I have a customer who wants me to build a 4' high x 10' x 8' food shelter underground with a shed built on top. I have built plenty of sheds however this will be a first for me. I have a block contractor who will be completing all the footers, cmu and slab. I made a little drawing to ask the question of the best method to securing the shed to the cmu wall. Have a look... any input would be great thanks.
Old 05-10-2010, 01:12 PM   #7
mics_54's Avatar
Trade: contractor
I bet they have a book with prescriptive methodology addressing this concern applicable to your locale (we don't know where that is for some reason).
Personally I prefer to place a treated mudsill between the masonry and the wood framing.
mics_54 is offline
Old 05-10-2010, 02:39 PM   #8
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
This thread looks familiar
http://www.contractortalk.com/f48/ne...ct-help-78167/
Old 05-10-2010, 02:43 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Originally Posted by NJ Brickie View Post
Threads merged.
Angus
angus242 is offline
Old 05-10-2010, 03:53 PM   #10
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Knucklehead likes multiple choice.
A.inside
B.outside
C.on top of
D.none of the above
knucklehead is offline
Old 05-10-2010, 03:58 PM   #11
Looks like if you do the inside it would leave a gap .
How will you get down there?
Old 04-28-2011, 07:07 PM   #12
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
a food shelter? What do they think is gonna happen to the world
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Over-Engineer Kills Project Tim Garrison PE General Discussion 97 02-19-2010 12:26 PM
Customer freaks out and refuses to cooperate after successfull completion of Project! eModPro Business 38 02-03-2010 05:58 PM
A Multi Million Dollar Construction Project and The Project Superintendent's Position Buildtek Health & Safety 3 02-01-2010 11:57 PM
Need help with college project! CMstudent General Discussion 23 02-18-2009 10:31 AM
